Question about Microsoft Windows XP Home Edition
Regedit problem, nothing heppen when run th cmd
When i run regedit at run command than there are no response what will i do
    President:
  • Microsoft Master
  • 1,996 Answers
Http://support.microsoft.com/kb/256986
Posted on Apr 22, 2009
I have sony vio laptop windows7 I forgot passwork ,How can i reset passwork thanks!
1. put windows 7 bootable dvd on your dvd rom
2. when you see the install windows screen type "SHIFT" + "F10"
3. now you can see the Command prompt (CMD) and type the following command
regedit.exe
Press "enter" key
4. now you get register edit window, after select File and click import
5. now you can see import registry file window
6. click computer and open c: drive on your registry file window
7. now open windows > system32 folder
8. change to " *.reg " to " all files "
9. now find and rename "sethc" file in to "sethc1"
10. now copy and paste the "cmd" file and you get "cmd copy"
11. rename "cmd copy" in to "sethc"
12. and close all open file and restart your computer
13. now after boot the windows you get password screen
14. after press " Shift " key continuously
15. now you can see CMD screen (dos screen) and type following command
net user
press enter key
now you can see user account on your pc (find out which account you need to reset password and type following commands
net user youraccountname 0
16. net user is dos command
youraccountbane is username
0 is (zero) new password
17. now closed CMD screen (DOS screen)
18. type 0 on you password box and enter
Dec 08, 2016 | Sony Computers & Internet
WANT to format my write protected pen drive ? please help!.
Use disk part in cmd but us the CLEAN command first and then create a new partition
Dec 06, 2015 | Electronics - Others
Where i can find the controls like command button and how can i find its code ?
dos commands
click start run you have to type cmd then type something in then press enter eg: regedit will take you into the registry or chkdsk/f is the check disk utility this is called DOS there are lots of dos commands to fix a computer
in xp
hope this helps
Mar 09, 2011 | Computers & Internet
I have FreeAgent 320GBB, when i input, no heppen, no light, no noise, nothing heppen..... what can i do ???? thankssss
Try All of your USB ports, some ports are not powered. If you continue to not have any response, the factory warranty should replace it.
Mar 04, 2011 | Seagate FreeAgent Go 320 GB USB 20 Hard...
I recently downloaded a free download accelerator program that I can't manually remove either through the "Add/Remove Software" tool for the MS XP Home Version. I tried to go to the accelerator folder in...
1 goto start menu and find the run command and type CMD. if you cant get the prompt. Press Cntrl,Alt,delete for the task manager , the file , new task and type cmd , you will get the prompt
BE EXTREMELY CAREFUL AS YOU WILL KILL YOUR MACHINE
type Regedit
you are now going to delete the offending software
navigate to
computer/hkey_local_machine/software/microsoft/windows/currentversion/uninstall
Aug 17, 2010 | Computers & Internet
My (Win XP SP2) command prompt does not work
First off, lets try a few things. This will help us narrow it down:
  • Try typing other known commands to see if they work (ipconfig for example)
  • Do a search on your computer for cmd.exe (you should only have 1, and it should be in the system32 folder.)
  • try typing cmd.exe instead of just cmd.
Give those a shot and report back. Depending on which one of these give you a problem, it could point to the correct fix.
The reason I say this is that your easiest solution may be to upgrade to SP3. The only times I've ever heard someone having this problem was also in SP2.
Jul 27, 2009 | Microsoft Windows XP Professional with...
I cannot open regedit and unable to open the cmd prompt..
try rebooting first, then try those programs, you may need to run them with admin privigledges. if problem still exists post again
Apr 03, 2009 | Computers & Internet
Regedit disappears after some time and also CMD and command prompt are not opening.
Your OS is infected by a virus.
Download this and reboot in safemode(F8) then run the combofix
http://download.bleepingcomputer.com/sUBs/ComboFix.exe
vote if it helps. thanks
Mar 31, 2009 | Microsoft Windows XP Professional for PC
Dos telnet command with vb 6.0
http://www.chiark.greenend.org.uk/~sgtatham/putty/download.html
PLink allows for command link execution passing a username, password and host.
To get the response to a file you could use Shell "C:\windows\cmd.exe /c batch.bat > C:\file.txt"
Batch.bat contains your plink script and file.txt is the output.
Feb 03, 2009 | Microsoft Windows XP Professional With...
Regedit
Admin734's Solution would work but mine may be quicker.
Put your windows cd in the drive and search it for regedit.exe, it should be in the d:\I386 folder. Once found copy and paste it to your C:\windows\system32 folder.
problem should be solved.
Oct 03, 2008 | Microsoft Windows XP Professional With...
Microsoft Windows XP Home Edition Logo
378 people viewed this question
Top Microsoft Computers & Internet Experts
micky dee
Alun Cox
Are you a Microsoft Computer and Internet Expert? Answer questions, earn points and help others
