Question about Canon i9900 InkJet Photo Printer
Not printing at all!
The printer stopped putting out ink. The Head moves I hear it "printing" but nothing is coming out, just a blank sheet of paper. I printed out 3 papers with color right before it just stopped printing anything at all. I cleaned the seperate carts and removed any dry ink from the print head, but still wont print. I tried the hold form feed 4 times to see if that would work and it didnt.
  • Anonymous Jun 01, 2008
    My i9900 sounds like it's printing but there is no ink. My inks are full, in the correct order and canon brand. I've done the maintenance from the print box - cleaned, deep cleaned, check alignment etc. Every time it runs a check it sounds like it's printing but nothing comes out. I've tried holding the button and letting the yellow button blink 3 times. I've checked each ink to be sure they are full and inserted properly and I've been searching for help on the net. Help, it's driving me crazy. Mary W.
  • Anonymous Jul 17, 2008
    Everything been working fine, replaced an ink tank recently always with Canon Ink. I printed tow and a third 11" x 17" pages. the 1/3 being when the problem started. Page 3 has 4 inches of the image then goes to white with 3 bands of lesser ink in the transition.
    I get the      Error Number : 1485
    This print head is the wrong type. Replace with the proper print head.
    Nothing has changed. How did the head go wrong? What do I do now?
    Problem Solver:
  • 35 Answers
Change your cartridge and then try again
Posted on Sep 24, 2007
SOURCE:
My Dell A920 prints blank paper.
Inkjet printers need to be used frequently to prevent inkdrying out in the print head nozzles.
If the print head cleaning maintenance routine does not clear the blockages,then print head needs replacing, but it may be expensive.
It may be more cost effective to buy a later model and better printer thanreplace the print head.
Mar 01, 2012 | Dell A920 InkJet Printer
My printer print without no writting , paper just come out blank and it's new ank model hp d500
Hi, If you didn't used your inkjet printer for a long time the most common problem is that the nozzles of the print head are clogged with ink, so no ink can go down to the paper and that's why you see a blank sheet of paper. What you can do is Deep Head Cleaning from the printer properties menu a couple of times. If this does not help you will need to replace the print head
Sep 14, 2011 | Canon PIXMA MP780 All-In-One InkJet...
Installed new printhead,took new ink I had just put in old printhead and put it back in new printhead. Will print nothing.just spits put blank 4x6 photo paper it says to load in to get calibration.Then it...
The document specs of your printer is given below:
Document & Media Handling Max Original Size Legal (8.5 in x 14 in) Original Type Sheets Min Copy Size 3.5 in x 5 in Max Copy Size Legal (8.5 in x 14 in) Standard Media Capacity 100 sheets Output Trays Capacity 50 sheets Document & Media Handling Details Input tray - 100 sheets size: 3.5 in x 5 in - Legal (8.5 in x 14 in) ¦ Output tray - 50 sheets size: 3.5 in x 5 in - Legal (8.5 in x 14 in) ¦ ADF - 3.94 in x 5.9 in I would rather suggest to take a print in normal A4 size plain paper and see what you get. Please revert back Suspected 1) paper scanner faulty not able to judge paper.
Sep 10, 2011 | Kodak EASYSHARE 5100 All-In-One Printer
Blank paper comes out when print is pressed
Can you hear the print head moving??
If so then ink has run out OR is dry in print head, go into Printer software and locate "printhead clean".
If print head is not moving maybe fault internally.
Mar 23, 2010 | HP LaserJet 1015 Printer
Printer prints blank pages
The print head is a part of the printer itself and unlike other printers, you cannot remove it or soak it without ruining your printer. So just try the print head cleaning option and perhaps replace cartridges, especially if you are using a third party or refilled cartridge which can clog even if it is full.
Mar 02, 2010 | Brother MFC 240C All-In-One InkJet Printer
How do you remove printhead from kodak easyshare printer to install new one?
Hello my friend
First make sure that your print head is your problem before replace it
This is how you replace it
  1. If your printer is not powered on, press ON.
  2. Lift the printer access door and wait for the carriage to move to the access position.
  3. Remove any paper that may be loaded in the printer.
  4. Remove both ink cartridges and set them aside.
  5. Unlatch the used printhead.( Lift the button in the center)
  6. Lift the used print head out of the
  7. carriage.
  8. Take out the new print head from its bag
  9. Remove the 3 plastic protective shields.
  10. Place the print-head into the carriage.
  11. Push firmly against the back wall of the print-head until you hear a loud snap
  12. Insert the black ink cartridge into the print-head.
  13. Press down on the ink cartridge until you hear it click.
  14. Do the same for all inks
  15. Close the tray
  16. Lower the front access door and pull the paper tray all the way out.
  17. Insert a stack of 5-10 sheets of plain paper into the paper tray.
  18. For the Calibration:Press Start. Wait 2 to 3 minutes for the calibration sheet to print.
Jan 15, 2010 | Kodak ESP 5 Printer
Does not print
***hi there,il be willing to help you on that. ****
the nozzles of the printer might be clogged by dried inks thats why when your printing, its feeding the paper, as if its printing but no inks on the paper. print a nozzle check to see which part or color have clogs, if there are gaps or breaks, do head cleaning untill no more gaps then try printing.
Running a Printer Check
1. Load a few sheets of plain paper in the sheet feeder. 2. Turn off the Epson Stylus NX100 Series. 3. Hold down the nx100_tx100_ug.1.96.1.jpg Stop button as you press the nx100_tx100_ug.1.96.2.jpg On button to turn the Epson Stylus NX100 Series back on. Hold down both buttons until the nx100_tx100_ug.1.96.3.jpg On light begins to flash, then release the buttons. 1. Load a few sheets of plain paper in the sheet feeder. 2. Turn off the Epson Stylus NX100 Series. 3. Hold down the nx100_tx100_ug.1.96.1.jpg Stop button as you press the nx100_tx100_ug.1.96.2.jpg On button to turn the Epson Stylus NX100 Series back on. Hold down both buttons until the nx100_tx100_ug.1.96.3.jpg On light begins to flash, then release the buttons. 1. Load a few sheets of plain paper in the sheet feeder. 2. Turn off the Epson Stylus NX100 Series. 3. Hold down the nx100_tx100_ug.1.96.1.jpg Stop button as you press the nx100_tx100_ug.1.96.2.jpg On button to turn the Epson Stylus NX100 Series back on. Hold down both buttons until the nx100_tx100_ug.1.96.3.jpg On light begins to flash, then release the buttons. 4. Check the nozzle check pattern that prints to see if there are gaps in the lines. nx100_tx100_ug.1.96.5.jpg 5. If there are no gaps, the print head is clean and you can continue printing. If there are gaps or the pattern is faint, clean the print head. If your printouts are unexpectedly light, or dots or lines are missing, you may need to clean the print head. This unclogs the nozzles so they can deliver ink properly. Print head cleaning uses ink, so clean it only if quality declines.
You can also clean the print head by holding down the stop button on the printer for three seconds. (This only works when the red ink light is off.) Run a nozzle check to confirm that the print head is clean.
Caution: When you don’t turn on your printer for a long time, print quality can decline, so turn it on and print a few pages at least once a month to maintain good print quality. ***if my troubleshooting steps are helpful, pls vote for me, i will appreciate it, so that I can be a part of fixya, thanks, Godbless****
Jan 10, 2010 | Epson Stylus NX100 InkJet Printer
New ink in printer but will not put ink on paper.
It sounds like blocked nozzles to me, providing you're SURE you have good cartridges, properly installed (you did take the yellow plastic tapes off the vents before you installed the cartridges of course).
You can try soaking the print heads for 24 hours (or more), as follows. Turn the printer on, and as soon as the print head moves out of its parking position, pull the power cord out of the back, or turn the printer off at the mains. You may now carefully move the print head by hand over to the left hand side out of the way. Look inside the print head parking area on the right and you will see a small rubber cup that comes up to cover the print nozzles when the head is parked (to stop it drying out). Use a syringe or dropper to fill this cup with head cleaning fluid or distilled water. DO NOT USE TAP WATER. Carefully push the print head by hand fully into its parking position so that the cup full of fluid comes up over the print head. Do not turn the printer on at any stage in this process. Leave this for at least 24 hours, then turn the printer on and try a head clean/nozzle check again. If nothing, repeat the process once more. If still nothing, post a new comment detailing what you have done and the results
Mar 07, 2009 | Epson Stylus C84 InkJet Printer
Printer won't stop printing alignment sheet, following changing of ink cart.
my printer only printed 1 page out of 3 so now it wont stop. it pulls the paper in and comes out blank. this will keep going unless i turn it off. how do i reset my printer?
Aug 20, 2008 | Office Equipment & Supplies
Canon i9900 InkJet Photo Printer Logo
281 people viewed this question
Clive
Clive
old marine
old marine
Ekse
