Question about Mitsubishi VS-50607 50" Rear Projection Television
TURNS OFF BY ITSELF
Hi! I have Mitsubichi projection TV Model VS-50607. The problem is that it turns off by itself, I try to turn it back on and the power light just blink and stays off. I have to let it sit for about 15 minutes and then it works fine for another hour or so. Can you help? or any sugestions? Thank you very much for any help.
  • 129 Answers
SOURCE: Picture comes on than turns off and red light stays on
you can reset the tv to factory default settings , but before that I need more info ab manufacture date and purchase date you can find the first one on the back cover, if the tv has more than 5000 hrs of use problably the lamp, filter or fans can cause this problem, hope it helps you . let me know
Posted on Jun 12, 2007
SOURCE: Power turns off automatically
Same w/ mine.  Repairman said they turn off auto to protect the set no matter what is wrong.  Take it to be fixed.  Mine was right at $100.  Works great again.
Posted on Oct 25, 2007
  • 1694 Answers
SOURCE: Mitsubishi WS 65513 turns itself off
Probable four bad caps in DM module = 1000mf/25v
Common repair for qualified Mits tech...........T.
Posted on Nov 22, 2007
  • 108 Answers
SOURCE: When I turn my TV on, it automatically turns off and stays off.
check the lamp and air filter if there is one
Posted on Jan 11, 2009
  • 64 Answers
SOURCE: Mitsubishi TV #WS 5531 hd 1080 upgradable - Screen
Most likely burned out lamp.
Posted on Aug 11, 2009
What's the matter with my Mitsubishi Big Screen Tv Model VS-5041?
just re-read the trouble-shooting section of your owners manual and check the setup on your remote
May 26, 2013 | Mitsubishi VS-5043 50" Rear Projection...
Mitsubishi projection TV model VS-5047 won't turn on
No. It is shutting itself off after it finds something is not right in circuitry.
Apr 14, 2010 | Televison & Video
Mitsubishi Projection TV Model #VS-50603 will not turn on.
The TV is going into a "protect mode", the micro-processor has sensed a circuitry problem and has shut the set down so that no furhter damage can happen, you will need to have the TV serviced by a Mitsubishi tech. Good luck !
Jan 07, 2010 | Mitsubishi VS-50607 50" Rear Projection...
Vs-50607 turns off by itself it might come on after about 8hrs
if you hold menu and input on the front panel it will blink a code to tell you
where the error likely is. hold the buttons for 5 seconds and you'll get a 2
digit error, like 1 2 = no error..
“12” ... indicates no error has occured.
“21” ... X-Ray Protect circuit.
“22” ... Short Protect circuit.
“23” ... Horizontal Deflection failure.
“24” ... Vertical Deflection failure.
let me know what you find.. it will determine area of failure
Jan 08, 2009 | Mitsubishi VS-50607 50" Rear Projection...
Mitsubishi vs 50607
Good Day, gntjige73 & muse923;
Let make this short and sweet, code 24 means you have a vertical problem. Four common things can cause this:
1. Bad connections on the convergence IC's,
2. Bad cap's in b + to vertical circuit,
3. Bad connections/or failing vertical output IC,
4. Or fluid on the PC board, leaking from the crt's.
The companies you called DO NOT call them back, but call a factory authorized service dealer, they will help you, but always remember to get a written estimate before you proceed with the repair. Good Luck, big IRISH>
Jun 26, 2008 | Mitsubishi VS-50607 50" Rear Projection...
Mitsubishi rear projection tv model ws-65907
Your problem is in the power supply section,,all the solder there holding the parts is crack or loose already need to resolder so performance will back again.
Jun 19, 2008 | Mitsubishi VS-50607 50" Rear Projection...
Wont turn on at all...
read info at ctechnicians.com email for questions
Dec 25, 2007 | Mitsubishi VS-50607 50" Rear Projection...
IS THIS TV PLAYING OUT
Color separation is called convergence mis-alignment......that
problem can be repaired...............Blurry,darker when cold may
be a bit of difficulty..............Have a skilled tech give it a look.....T.
Nov 15, 2007 | Mitsubishi VS-50607 50" Rear Projection...
Vs 50607
might be the convergence ic's
Oct 12, 2007 | Mitsubishi VS-50607 50" Rear Projection...
Mitsubishi VS-50607 50" Rear Projection Television Logo
123 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
