Question about GE GSH25JFR Side by Side Refrigerator
Food is unthawing
Ice built up in the back of the freezer, sounds like something inside is constantly running, food is slowly unthawing. What could be the cause of this?
    President:
  • 331 Answers
Cmax,
The cause of this is the evaporator thermister. Sounds daunting, doesn't it? It's not. See? This is an electronic component that connects to the main computer and is used to monitor the temperature of the evaporator during the defrost cycle. When it fails, the main computer simply doesn't go into its' defrost cycle. Then you'll see frost build up on the rear panel inside the freezer, your beer compartment will get warm and the fan inside the freezer will run constantly (ahhh!).
The repair is cheap. Seriously cheap (and easy, too!) It'll take me longer to type out the repair thn it would if I'd actually DONE the repair (I type slow). Take a gander at the full size diagram of your fridge's evaporator (freezer) section here. You'll be replacing # 243... it's located at the top of the coils on the left.
You'll need;
Phillips screwdriver
A towel (maybe)
Hair dryer
Wire cutters
Wire strippers
2 Wire nuts (small blue ones) <--- all of this is found at a local hardware store (except for the towel. Unless it's a "shop" towel)
Pull all the frozen stuff outta the freezer and remove the shelves and the basket at the bottom. Now remove the back panel. You'll probably see a huge block of ice now. Your jaw will most likely drop and you'll feel like freaking out..... don't. Grab the hair dryer and melt all of that outta there. (NOTE---> WHEN DOING THIS, KEEP THE DRYER IN MOTION. IF YOU DON'T, YOU RISK WARPING THE PLASTIC INNER LINER)
Now that all the frost is gone, look at the top left of the aluminum coils. You'll see the thermister clipped to one of the tubes (it's the only thing there that has 2 white wires going to it). Remember where it's clipped, then unclip it. Cut the wires close to the base of the thermister, keep the clip. Now seperate the 2 white wires and strip them back about 3/8". Now take your new thermister and install it.
Take one of your newly stripped wires and twist it together to one of the new thermister wires and cap it off with one of the blue wire nuts. Do the same with the next wire. Now take the clip that you saved from the old thermister and place it on the new one and clip it back onto the same tube the old thermister came from.
All you gotta do now is rebuild it all.
Please don't forget to rate this solution as "FixYa". OK?
SG
Posted on Apr 22, 2009
  • 532 Answers
Did you figure it out?i just saw this question,before you go into alot of work like others suggested,completely defrost the freezer,open the doors and shut it off overnight,put towels on the floor to catch the water as there will be lots,the freezer HAS to be completely thawed in order to start the process of fixing it,i dont believe its a computer problem just yet,have you filled the freezer too full for a long period of time?The back vents have to be clear for the cold air to blow around and if it cant then the thermostat says its not cold enough and makes the compressor run continuously.ive seen this multiple times with any refridgerator at the apt building we own and the tenants always packs them too full not knowing the correct way to use them.yes the newer ones have computers,its possible it could be bad,but there is more to it than that,there also is a defrost tube for frost free refridgerators in the back wall that automaticaly warms up the freezer at cycles to keep them from frosting up,that part is about $30.00..the sound you hear is probably the fan constantly running trying to cool the refridgerator,its actually in the freezer behind the back wall
Posted on Apr 26, 2009
    President:
  • 1,489 Answers
Sounds like ice is blocking air flow -- totally defrost freezer.
Freezer is not defrosting
1. Remove all of the food from inside the freezer and place it into the ice chest. Use more than one ice chest, if necessary. Cover the food with ice from a 10 lb. bag of ice. Alternatively, place all of the food from your freezer into the refrigerator compartment, packed tightly together.
2. Place one or two 10 lb. bags of ice into one or two large bowls inside the refrigerator compartment to keep the food chilled. Keep the door to the refrigerator tightly closed and avoid opening it during the freezer defrosting process.
3. Unplug the unit and leave the freezer door open.
4. Let the freezer defrost overnight or for at least eight hours.
5. Use the towels to wipe up the melted ice.
6. Plug in a hair dryer and direct it to the interior of the freezer to melt any remaining ice from the walls and door. Be sure to direct it into the vents of the freezer, too.
7. Wipe up any water from ice melted with the hair dryer from inside and around the freezer.
8. Plug the freezer back into the outlet, and return food still solidly frozen to the freezer compartment from the ice chest or refrigerator. Use any thawed foods within a day or two or discard.
May 25, 2010 | Maytag 21.0 Cu. Ft. Top-Mount Refrigerator...
Frosting up in the freezer and not cooling in the food compartment kenmore 363.9557852
It sounds like you have a defrost problem.
All the cooling for both sections takes place in the freezer behind the back wall. A fan back there distributes the cold air throughout the freezer and fresh food section. Every 8 - 10 hours a heater comes on for about 20 minutes to eliminate the frost from the evaporator coils back there. If this defrost cycle fails the frost will build up to a point of no air flow so the fresh food side and most of the freezer start to warm up.
The best way to take care of this is to turn it off and unload the freezer, take the shelves out and the screws holding the back panel inside the freezer out. Remove the back panel from the freezer. Use hot water and a hair dryer to unthaw the ice and frost, you will need lots of towels as the melting will bring lots of water on to the floor. Once the frost is gone you will need to install this part WR51X443. The picture below shows it. The kit contains new heaters and thermostat.
Apr 26, 2010 | Kenmore 12.8 cu. ft. / 362 liter Chest...
Ice on back wall of freezer, food not staying completely frozen
Do you have the complete model number from the tag on the freezer, it should be either on the bottom rail visible with the door open or on the side wall near the front. I am trying to look this up to see if it is an automatic defrost model, if so you may need to do more than just unthaw and adjust
Thanks
Apr 25, 2010 | Kenmore 16.7 cu. ft. / 473 liter Upright...
A week ago the stuff in the bottom 'veg keeper' was getting too cold so I cut back both the fridge/freezer problem to 'orig settings.) I did put a ton of food in the refrig for Easter (maybe it held the...
it is not defrosting . coil is icing over it will slowly get warmer in fridge then freezer. will be defrost timer needs replacing or defrost element. also listen if fan motor is running when door closed.
Apr 05, 2010 | GE GSS20IEP Side by Side Refrigerator
Kenmore 253.56953601 freezer isnt working properly. food is slowly thawing and ice maker stopped working
I think you have a defrost problem. Look at the inside lower back panel of your freezer. If I'm correct, you will see ice built up. You can take the panel out, defrost with a blow dryer. (After defrosting you can check your heaters. I'm sure you have a bad heater) You can put panel back in and turn the unit back on. It will run ok for around 3 days, This will give you time to repair or get repaired without loosing you food.
Please rate solution
Oct 01, 2009 | Kenmore 55612 / 55614 / 5561 / 655619 Side...
I have a Kenmore fridge model 106.72852100 the fridge part does not work but the freezer works what should I do?
Check to see if your inside fan is blowing air. Your fresh food section is cooled by the freezer. If the fan is running, I think you will find that you have a defrost problem. You can tell by looking at the inside back panel of your freezer. If it has frost or ice built up, you have a defrost problem. Your freezer should be between -10 and 0 degrees and if you have the ice on the inside back panel of the freezer. you will find the your freezer is really running warm and not ok like was thought. If so, remove the back panel and defrost with blow dryer. you can check your heaters once defrosted. they will be behind that panel. You can put the panel back on and the fridge will work ok for 3 or 4 days. This will give you time to get the part or time for someone to come out and fix without loosing any food.
Sep 14, 2009 | Kenmore Refrigerators
Kenmore Side by Side not getting cold enough to freeze food.
Evap fan...cond..fan ...do they turn.....seems like a comp...problem...does the evap ice up...?
Aug 18, 2009 | Kenmore 57029 Side by Side Refrigerator
Ice on back wall but not freezing food and rattle noise. Moved all food to other freezer
This is a fairly common problem with these types of refrigerators. The design is set to defrost every 12 hours and be down for 1 hour to allow ice to melt on coils. More often than not the ice never fully melts and creates a blockage in the coils and in turn slows air flow. You can remove the screws in the back wall of freezer unit and unsnap the ice maker plug to allow access to the coil. Gently tilt the back plate forward. You can then unplug the ref. and help it thaw with a blow drier. If you are not comfortable removing the back plate then you can just unplug the ref. and let it thaw on its own. this may take a while. try to remove as much ice as you can from the back of the freezer wall by hand and prop the door open for a couple of hours to ensure that all the ice melts. The rattling sound you are hearing is the fan blades hitting the ice that is built up around it. As a precaution I recommend that these type of refrigerators get manual defrost simply by unplugging about once a month for about two (2) hours. I hope that this will help you out with the melted ice cream. Good luck.
May 30, 2009 | Kenmore Refrigerators
Freezer runs constantly
not necessarily, is it maintaining temp? all food staying frozen? especially ice creams if stored in there. most newer freezers displace the heat generated while cooling the food through copper lines running through sides of unit, helps to cut down on air temp differences between the inside (0 degrees) and outside temp to prevent moisture and possible condensation causing premature rusting of unit
Mar 02, 2008 | Kenmore 14.1 cu. ft. / 399 liter Upright...
GE TPX24BPBGBB fresh food section won't cool
Have you noticed any ice built up on the rear freezer wall? it is very likely that you have a defrost problem situation,IE: Heater,Defrost Thermostat,Defrost Timer any failure in these components will cause an icing problem and therefore you will not get sufficient air flow to the Food Compartment
Sep 20, 2007 | Refrigerators
GE GSH25JFR Side by Side Refrigerator Logo
261 people viewed this question
Top Refrigerators Experts
Sal De
Charles T Nevin
Charles T Nevin
Gene Tuck
