Question about Epson Stylus NX400 InkJet Printer
Epson Stylus NX400 While printing envelopes, I keep getting a black ink blot on the bottom right hand corner of the envelopes. It happens to about every 1 out of 4 envelopes. I printed the return addr
Epson Stylus NX400 While printing envelopes, I keep getting a black ink blot on the bottom right hand corner of the envelopes. It happens to about every 1 out of 4 envelopes. I printed the return addresses on these first and had NO problems whatsoever, once I turned the envelopes over to do the addresses, this issue has occurred. This is a new printer and ANY help would be appreciated! Thanks!
    Champion:
  • 214 Answers
Envelopes can give all sorts of problems Back corner is flicking up. Try rolling the envelopes in the opposite direction to the "bowing" as they have been through machine once.
Posted on Apr 25, 2009
Will the Epson stylus office bx635fwd print if only the black has ink in it ?
Since 2005 Epson and all other inkjet manufacturers use a little of the colors to print black. so ,no,you will not be able to print just clack.
Even color laser printers use the colors to print black.The exceptions since 2009 have been the Canon color lasers and the HP color lasers units they provide print engine for.
Mar 29, 2014 | Epson Stylus NX400 InkJet Printer
I have an epson NX400 inkjet printer, all ink cartridges are full and are installed correctly. When trying to print, the black ink is not being printed. I have tried doing several head cleanings,...
hey friend,
This should be the problem of print head ink nozzle block.The nozzle for the black ink cartridge got dry.So the ink getsdried state.It won't allow any inks passing through the micro nozzles.Head cleaning won't help with the heavy nozzle block.So try replacing a new black cartridge or else bring the printer to the nearest service center.It'll help so.
Mar 06, 2011 | Epson Stylus NX400 InkJet Printer
My epson stylus color 400 will not print in black...I have replaced the two ink cartridges...if I type in color it prints in color...if I type with black ink...it does not print...please help
I had the same problem.
Solution: The black don't print in standard resolution (regular paper)
Set your printer in higher quality paper and your black will print.
This is another problem with Epson nx 415..................
Good luck !!
Mar 03, 2011 | Epson Stylus NX400 InkJet Printer
I want to change black ink cartridge in Epson Printer TX110
If ink level reach ink out level, follow How to.. on Epson status monitor. But, if it's not, turn off printer. Unlock carriage lock, then move carriage by hand. Or you can turn on printer and unplug power while carriage moving. Then move by hand freely.
You should be able to follow the bottom link and find it or you can check this answer .
tech.epson.com.au/downloads/message.asp
Hope that helped..
Nov 05, 2010 | Epson Stylus NX400 InkJet Printer
Need to override color ink and print drafts in just black
Here is a link for your printer. pg21 refers to you. It shows how to print. You would need to go the the advance tab to print just in black. If you find this helpful pls rate me.
http://files.support.epson.com/pdf/nx400_/nx400_qr.pdf
Thankd and good luck
Jan 21, 2010 | Epson Stylus NX400 InkJet Printer
How do you print envelopes on an Epson Stylus NX400?
To print an envelope in Vista, just open any document in Word, select envelope, (located under Home to the left). It will put you in the envelope program. You can type in any address and return address here. Also under options you can change the size of envelope. Hope this helps.
Aug 05, 2009 | Epson Stylus NX400 InkJet Printer
Error message after replacing black ink cartridge
This happened to me twice, You can possibly have no ink in your cyan,magenta and yellow , you would then have to replace them to work the set. I had to do that and it worked =]
Jul 18, 2009 | Epson Stylus NX400 InkJet Printer
How do I print envelopes
You will get an option to print envelopes either from the microsoft word or you can use the software provided by your printer vendor.If you want any further support, an online technician from techbuddies can help you for free.For this log on to http://tinyurl.com/m7ghqz
Jun 18, 2009 | Epson Stylus NX400 InkJet Printer
Epson NX400 works but will not print any ink on the paper
did you remember to pull the tape off the print head before you installed the new cartridge?
May 28, 2009 | Epson Stylus NX400 InkJet Printer
White lines on printed photos Epson Stylus NX400
You need to clean the print head on the cartridges , please follow these steps\
# Hold the cartridge upside down, with the bar-code label facing you and take a damp paper towel.
# Use the towel to wipe the printhead of the cartridge on the bottom (where the ink comes out). Wipe the printhead horizontally in one direction only (left to right).
# Continue doing this until it looks clean.
# Then dab the cartridge on the towel to make sure the ink is flowing.
# Next, look inside the printer and locate the carrier that holds ink cartridges. Caution: Make sure the cartridges are not installed at this point.
1. Look for a shiny piece of metal underneath the contacts at the back of the carrier.
2. Take a damp cotton swab (use water only!) and wipe along the bottom of the shiny metal piece. Note: You may need more than one swab.
# Reinstall the cartridges, making sure you snap them correctly into the printer.
Mar 15, 2009 | Epson Stylus NX400 InkJet Printer
Epson Stylus NX400 InkJet Printer Logo
582 people viewed this question
Top Epson Office Equipment & Supplies Experts
Are you an Epson Office Equipment and Supply Expert? Answer questions, earn points and help others
