Question about Kenmore Elite 45986 Front Load Washer
Frontload washer kenmore elit
The belt keeps sliping off and not turning the tub. We replaced the belt and it has only been 3 weeks and it is off again not broken.
    Problem Solver:
  • 12 Answers
How do the pullies look ar ethey worn or miht they be out of alignment or are the mounts broken or lose
Posted on Sep 23, 2007
What does LOC mean on kenmore elite washer ?
Press the Options and Select buttons at the same time and hold for 3 or 4 seconds to unlock the control panel. Best Wishes
Sep 04, 2014 | Kenmore Washing Machines
How remove Kenmore frontload basket from rear shell?
this is a big job and prob spendy if not under a warranty......
the outer tubs are connected by metal fasteners which need to be removed by a flat screwdiver mark the old fron outer basket with a marker so u can replace those clips in the same manner..........to get acess to the tubs turn power off and remove top, remove back panel, remove front as well console bottom panel etc,,, disconnect all componets,bellows gasket ,connection wires, tubes, remove motor, undo bottom pump tube, remove belt and remove back bolt holding on pulley, get two people and remove tub out front when completed disasseblying all necessary pieces.. once tub out then remove those metal fasteners and set aside front tube reinstall onto new rear/inner rear tubs... hope this helps i might have forget some things actually i know i did this is a complicated process hope this helps let me know
Apr 20, 2010 | Kenmore Elite 45986 Front Load Washer
Kenmore Elite Oasis HE 27072. Keep getting UL
Check the Vibration damper rods to be sure that...
1. They are there and mount is solid.
2. If they are broken in 1/2.
3. The plastic knuckle mounts are not missing/broken.
4. There is oil in the shock absorber/spring section of the rods.
Also - there are suspension springs on the bottom of the tub that could be broken and/or missing.
Replace/repair as necessary.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
Oct 20, 2009 | Kenmore Elite Oasis 27052 Top Load Washer
HE3T Kenmore Frontload Washer Random Draining Problems
The water pumped goes right back into the machine. It may be because the washer is siphoning the water from the laundry tub with a slow drain and back. Your solutions are advised but try this also:
  1. Check the pump impeller for obstruction.
  2. Cut the drain hose into the laundry tub in excess of 4 inches.
Aug 21, 2009 | Kenmore Elite 45986 Front Load Washer
Kenmore Front Load Washer Drive Belt Keeps rubbing up against Tub
IF THIS IS A BRAND NEW INSTALLATION - be sure you hav removed the basket shipping pins (4) that secure the tub during shipping.
Apr 05, 2009 | Kenmore Elite 45986 Front Load Washer
Squeaky maytag frontloader washer
it is the tub bearing and it is a very expensive repair takes about 2 - 3 hrs to do it the only time I have changed them is when they were in warranty noone ever wants to put the money into it
Jan 07, 2009 | Kenmore 43142 Front Load Washer
Kenmore frontload washer
commui=nication error between main and motor control board
Jul 06, 2008 | Kenmore Elite 45986 Front Load Washer
Kenmore Elite 45986 Front Load Washer Logo
95 people viewed this question
Sal De
fordexpert
Jim Goldsmith
Jim Goldsmith
