Question about Moen & Posi-Temp Single Handle Shower Or Tub Valve
Water flow stops and starts
Water flow in shower comes almost to a complete stop for few seconds and then comes back full force again. Kitchen sink just did it but happens rarely.
  • 2 more comments
  • lamplighterw Apr 24, 2009
    We have town water.
    water supply adequate - can't check pressure now - have no hose - leaving town for a while (vacation home) - appreciate trying to help - will post again when we return since I can't work on it for a while.
  • heatguy May 11, 2010
    ok now i dont suppose you have a pressure gauge in water line if you do whats the pressure ?if you dont you can take a short hose outside aim it straight up and see how high it goes and i can figure the pressure if you give me the height.my other question would be how do you go from tub spout to shower head do you turn a knob push a button ,what make is the shower
    what is your potable water supply source ?is it a well?
  • 91 Answers
Check PRV...Pressure reducing valve......Plugged ro broken.....
Posted on Aug 18, 2009
When shower is in use pipes vibrate and water starts to pulse,when faucet on sink is turned on it stops .What's up?Shower is an Aquasource brand.
You need to install water hammer arrestors in your basement it prevents this, if you have them already there water logged. All u do is shut off your water to your house and drain it down to the lowest point....when its done draining u fill it back up again slowly. Your water hammer arrestors may have become water logged when the new shower was installed
Nov 14, 2012 | Plumbing
I have to turn the hot water tap on full open to get hot water
Type of water heater is unknown
If you have single-handled faucet the faucet cartridge might be bad.
If you have recirculation system, then check valve might be bad.
Copy following links for troubleshoot.
http://waterheatertimer.org/Crossover.html
http://waterheatertimer.org/How-to-troubleshoot-electric-problems-with-water-heater.html
http://waterheatertimer.org/How-to-troubleshoot-gas-water-heater.html
Jul 16, 2012 | Water Heaters
I have a BOSCH 425N tanlkess hot water heater. In order to get hot water to flow to the sink taps, I need to turn more than one tap on (eg. if I want hot water at kitchen sink I must also turn a bathroom...
You need to have the flow switch looked at. The low flow of the water to the lavs and the kitchen sink, they all have as small demand next to t bath or shower,
Tom
Sep 19, 2011 | Bosch 425HN NG Tankless Water Heater
Hansgrohe Ecostat (with part 94282000 thermostat). Shower runs fine for a few minutes then boiler shuts down and shower runs goes cold. Boiler starts up again after 30 seconds and runs fine for a few...
Check the 94282000 cartridge for debris on the filters. If your boiler requires a certain flow rate to come on, then you must get enough flow through the cartridge to make that happen. Also, if your boiler is producing very hot water, the cartridge will self regulate and reduce the hot flow accordingly. try lowering the output temperature of the boiler to resolve that possibility.
If you need further assistance, you can call us direct at 800-334-0455
Sep 03, 2011 | Home
Sink sprayer hose makes noise
hello, you may have a air pocket in the line try shutting of the water supply and then sqeeze the handle and slowly turn the water supply back on with the hose handle squeezed on till the air is forced out, hope this helps
Jun 07, 2010 | Moen 87530 Touch Control Single Handle...
Why did my moen faucet stop working? I have water flow throughout the house but the flow at the kitchen faucet just suddenly stopped!
Rubber gasket on the water shut off valve under the sink has come off and traveled up into the faucet. It's pretty difficult to get it out. If you have access to an air compressor you may get lucky by taking the faucet completely off the sink and blowing air back from the faucet outlet back into the internal piping to dislodge the rubber piece. If that doesn't work, or you can't use the air compressor method, then it's a trip to the hardware store for a new faucet.
Jan 11, 2010 | Moen 87530 Touch Control Single Handle...
Water flow interruption in shower diverter
The washer on the diverter is loose. needs to be tightened or replaced
Sep 12, 2009 | Home
WATER HEATER ELEMENT IS NOT WORKING NEED TO REPLACE IT.
is there one or two,, turn off power drain it down, use the water heater element wrench remove the wires and the element, install new element snug it tight, start filling the water heater while it is filling reinstall the wires, turn on a hot side faucet only let the air out, wait till you have a full flow of water out of the faucet then turn the power back on to the unit, the thermostat should beat 120 degrees,
Feb 21, 2009 | Select Brands 20012 500°F Heating...
Water is either hot or cold - no in between.
I found a way to get warm water in the shower, but I'm not sure it qualifies as a solution. After trying everything else I thought that maybe when I was feathering the faucet in the shower toward the cold side so I would get warm water that at a certain point it blocked the flow on the hot water side enough so that the sensor in the hot water heater sensed there was no demand in the line and it shut the water heater off. To test this, I went to the kitchen and turned the kitchen sink faucet all the way to the hot side and then turned it on so that I got a small flow of water. I waited for the water to get hot to be sure the hot water heater was working. Once it was hot, I left it running to keep demand in the line and then I went to the shower and turned the faucet on. When the water got hot I started feathering the control towards the cold side and soon I had warm water. So I think I'm right in that the sensor in the hot water heater was shutting the water heater off when the demand in the shower was lowered to a certain point when I was trying to adjust the water temp in the shower.
So now I can get warm water, but it means I have to leave the hot water running at another fixture in the house to create a false demand in the system so the hot water heater doesn't shut down. Is there a way to adjust the senor in the hot water heater so that it will stay on when I'm using the shower only, so I don't have to waste water by running another faucet when I want to take a shower?
Nov 28, 2008 | Water Heaters
Moen & Posi-Temp Single Handle Shower Or Tub Valve  Logo
683 people viewed this question
Top Moen Home Experts
Mike
john h
Andrew Bugbee
Are you a Moen Home Expert? Answer questions, earn points and help others
