Question about Mitsubishi WD-62725 62" Rear Projection HDTV-Ready Television
Had a solid amber light indicating a new lamp was needed.
Replaced with new lamp and still have solid amber light. I have unplugged the tv and replugged but the light still comes on.
Its working fine, and purchased from a reputable firm. What should I look for?
  • Mitsubishi Master
  • 8,617 Answers
Press the menu amd device/input buttons both in together on the front of the set and hold them both in for 6 seconds to see if the timer light will blink a two digit blink code such as 3 blinks, slight pause then 4 blinks. If it blinks that code you will need the V26 Power pwb repair kit which is available at the following link under repair kits and has step by step instructions.
http://servicemanuals.vstore.ca/product_info.php/pName/mitsubishi-v26-dlp-power-pwb-repair-kit/cName/repair-kits
Posted on Apr 22, 2009
Wd 62628 lamp indicator light is solid yellow / orange what needs to be done
Your lamp cover is not installed. That is what causes the LED to light amber. Remove and re-seat the lamp cover door. There is a switch it hits to tell the TV the door is shut. This is to protect you from electrocution.
Sep 13, 2016 | Mitsubishi 915P026010 LAMP WD-52627,...
WD-57731 Will turn on, I get sound but no picture.
You should be able to see if lamp itself is lit or not, if lamp does come on or has been replaced recently let me know, I have a idea or two but need more information if possible.
Oct 14, 2012 | Mitsubishi WD-57731 57" Projection HDTV
Dell 1209S Projector, tries to turn on, and the fan comes on for 30 seconds and then goes off again. It tries this several times and then the light bulb icon comes off and it doesn't do antything else
Lamp is burned out or makes a popping sound.
When the lamp reaches its end of life, it may burn out and may make a loud popping sound.
If this occurs, the projector does not turn back on. To replace the lamp, see on page 38.
LAMP light is solid amber If the LAMP light is solid amber, replace the lamp.
LAMP light is blinking amber If the LAMP light and the Power light are blinking amber, the lamp driver has failed and the projector will automatically shut down.
If the LAMP light is blinking amber and Power light is solid blue, the color wheel has
Unplug the power cord after 3minutes then turn the display on again. If this problem
persists, contact Dell™.
TEMP light is solid amber The projector has overheated. The display automatically shuts down. Turn the display on again after the projector cools down. If the problem persists, contact Dell™.
TEMP light is blinking amber A projector fan has failed and the projector will automatically shut down. If the problem persists, contact Dell™.
Oct 23, 2011 | Dell 1209S DLP Projector
Tv turned off by itself, red light came on. when i turned it back on if had a flashing green light the turned solid green, there was sound but no picture, it turned off again within 2 minutes of turning it...
Tv probally needed a new tv projection lamp.This tv has not been change it projection lamp like 1 1/2 or 2 years already?Tv been on and used it like 4 or 5 hours everyday?Yes,than the tv flashing or solid on green LED light is on have a word "LAMP" written on it tv bazel frame?Yes,tv 100% require a new tv projection lamp replacement.
Aug 31, 2011 | Mitsubishi WD-73737 73 in. HD-Ready TV
LG RU-60SZ30 when turning the tv on the power lite changes from red to flashing amber, flashes 6 to 7 times then turns back to solid red. The tv never actually starts. Before this the tv would randomly...
I have read another solution which may indicate the light engine has failed and will likely need replacing. The cost is quite expensive. $1500 range and apparently the part is no longer available from LG. Best you might do is get an estimate to repair just to be sure.
Dec 04, 2010 | LG RU-60SZ30 60" Rear Projection...
Mitsubishi 53 projection TV- won't turn on- Red lamp light is on. Tried to turn the tv on and the lamp light turned amber and we heard the sound of the tv and then it shut off and the red light "lamp"...
unplug the set for over an hour, if the same thing happenes you will need service. Look at the power light, it should be blikning. If you count the # of blinks between pauses it will tell you the problem
Jan 10, 2009 | Mitsubishi WS-65513 65" Rear Projection...
Lamp light
If you still need code i have it at shop i am home right If i rember right you must reset lamp Timer to Tell tv that it old lamp has been replaced with new code is 9,8,7,6, ect...........
Jan 17, 2008 | Zenith E44W46LCD 44" Rear Projection...
Resetting the indicator light
Hold down on the Enter or OK on the TV and Mute on the remote control for 5-10 seconds. The TV should then ask what you want to do. Perform this with the TV on.
Jan 31, 2007 | LG RU-52SZ51D 52" Rear Projection...
Mitsubishi WD-62725 62" Rear Projection HDTV-Ready Television Logo
168 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
