Question about Mitsubishi Diamond WD-65831 65" Projection HDTV
Intermitent Shot Off
My rear end projection Mitsubishi Diamond Series TV shots itself off while program is on and during commercials. We had a couple of TV repair technicians work on it but it still shots off by itself. What is going on please?
    Master:
    Sergeant:
  • 461 Answers
Please check the sleep timer is off..
Posted on Sep 24, 2007
SOURCE:
I currently am experiencing my 2002 Mitsubishi diamond series tv shuttin g of after being on for 3-5 minutes
Sounds like you have a cooling issue. Do you notice if the fans inside the back of the tv are running? If not then it's overheating and turning itself off to prevent further damage.
Also The next time it happens, before you just turn it back on, press the INPUT and MENU buttons on the front panel together and hold them down for at least 6 seconds. This should cause the front LED to flash a 2 digit code. If it flashes once, then twice, then pauses and repeats, it means that the TV's computer didn't detect a problem.
Feb 28, 2011 | Mitsubishi WS-65809 65" Rear Projection...
THE GREEN LIGHT IS BLINKING ALL THE TIME
You have the one that the capacitors go bad on, this set is the most complicated set to work on call the pro's but expect as heafty bill, the chassis has to be pulled out and sent into Mitsubishi for a rebuild.
Sep 11, 2009 | Mitsubishi WD-62525 62" Rear Projection...
Power Loss
You will find 4 swollen capacitors in the DM module of value 1000uF 16volt. Replace them.
Aug 31, 2009 | Mitsubishi WS-55711 55" Rear Projection...
I get a pop up sign on my set that states..."The system is experiencing above normal temperatures. Unless corrected it will shot itself off..." The TV is next to an A/C vent. I have it off for 8-12 hours...
This seems it could be a temperature issue either the temperature sensor is malfunctioning or the cooling fans aren't spinning at the right speed or not spinning at all. It would be best if you check the owners manual and look for the system reset feature, this may work, or the other option would be to hit the reset button.
Jul 29, 2009 | Mitsubishi WD-52525 52" Rear Projection...
Turns itself off immediatley after turned on
mitsubishi projection TV turns off by itself after a couple minuts of viewing TV?
WD-62527
Apr 28, 2009 | Mitsubishi TS-5545 55" Rear Projection...
No picture
Could be a couple things:
The lamp is blown out,
capacitors on ballast or hyperboard, may be shot
or the door to the light bulb isn't close all the way.
do you get any flashing lights?
Feb 01, 2009 | Mitsubishi WD-52525 52" Rear Projection...
Mitsubishi HD Diamond series WS-55907
Good day k g;
I think the code is oooo.
If not let me know and I will double check.
Good Luck, Big Irish.
Jun 15, 2008 | Mitsubishi WD-52525 52" Rear Projection...
Mitsubishi 65 inch Diamond rear projection
Sounds like your control unit has going down. its the big silver box in the rear to the left of the set.
Oct 28, 2007 | Mitsubishi WS-65869 65" Rear Projection...
RE: Frequent Shut off
Sounds like you fans on the board have dust on them or are faulty.
Sep 23, 2007 | Mitsubishi Diamond WD-65831 65" Projection...
Please help
If its a rear projection TV. It sounds like the Lamp is shot on the projector, or is going. Look in the back and see if it is lit if it is flickering I would definitely suggest replacing it. If that doesnt repair it then I would ultimately suggest the optical engine which is the projector of the TV
Jan 30, 2007 | Mitsubishi VS-5075 50" Rear Projection...
Mitsubishi Diamond WD-65831 65" Projection HDTV Logo
144 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
