Question about Ricoh FT3713 Copier
ERROR MESSAGE ON RICOH BLACK AND WHITE FT3713 ERROR E70
  • linda_newbol Apr 22, 2009
    Is this something I can do my self if so how do I find the cleaning station and what is the waste hopper AND RUN sp83 code how? thanks
  • linda_newbol Apr 23, 2009
    well this didn't work couldn't get the 5 and so on to show.
Waste toner is full. Remove cleaning station, empty waste hopper, and run "SP83" to clear code.
Posted on Apr 22, 2009
  • Anonymous Apr 23, 2009
    The removal process is too complicated to put into writing here; however the code is resettable and the machine should continue to operate (possibly for a long time) without any difficulty. What may happen after a time is the waste begins to back up and overflow onto copies...so when you see "splotches" of toner, or possibly a sort of "grinding" noise due to the back up of waste -call for service.
    reset like this (I think)...it's been a long time:
    press "7" then "1"
    Hold "clear/stop" until a "." appears in the display, then release it and press it (don't hold) again.
    Now the display should flash "5" I believe.
    press "8" then "3", then "auto density"
    The magnification indicator should be flashing "0" press "1" and then "auto density" .
    I believe the exposure lights will now all flash a few times to acknowledge the setting
    Turn power off/on
    If this works, please give me a favorable rating...too often assistance goes unrecognized here. If you still have trouble...drop another line.
    good luck!
    Well, my memory is still working satisfactorily (about 95%), but you're right, I left out 1 key step......after holding the "clear stop", press it again (like I said), but then press the "lighter" exposure key ( looks like a backwards "D")....now you should see the "5" and proceed as above.
    please let me know, and good luck again!
NO IMAGE
Posted on Aug 08, 2009
Ricoh ft3513 E-7 error code
The E tells you, it's an error. The 7 tells you what area to look in. My first guess is around the fuser and/or output assembly.
Aug 22, 2013 | Ricoh FT3713 Copier
How to hook up a ricoh ft3713 to a computer?
Sorry to tell but this we cannot hook up this unit FT3713 to a computer.this unit is an analog type. if you need you must purchase a digital one and with a specification on what you want to do.
example. 1 printer
2 fax
3 scanner
Aug 20, 2011 | Ricoh FT3713 Copier
Have a PE error code, can't find anything in the service manual. I am a Ricoh Technician.
That is a Paper Empty message.
Check the paper cassett home switch and sensors for the tray stack.etc. Then clean or replace the rollers.
Apr 26, 2011 | Ricoh FT3713 Copier
How to reset e 70 error message?
The used toner tank is full. Empty it and reset the code by using SP Mode SP83.
Mar 07, 2011 | Ricoh FT3713 Copier
Error code E-22 in RICOH FT3713
· Scanner home position sensor failure
· Defective scanner motor
· Defective main motor
· Defective dc power supply board
· Incorrect scanner drive wire position
· Defective dc harness
· CN103 or CN105 on the main board is not correctly connected.
· FU202 on the dc power supply board open (blown fuse).
Jan 08, 2010 | Ricoh FT3713 Copier
Ricoh ft 3713 error 54
Clean the thermistor and clear the code by turning on both dip switches on the main board, turn off the main switch, turn off the dip switches, turn on the main switch.
Mar 26, 2009 | Ricoh FT3713 Copier
Ricoh ft3713 error code e54, where is the fuser and thermistor
You need a tech, or a new machine. The fuser is the heater section nearest the exit of machine - where they are always located. Your error message indicates a blown fuse, or lamp, or thermistor. The code can only be reset in service mode after the problem is fixed.
Mar 08, 2009 | Ricoh FT3713 Copier
Hello mine is really an FT3713
This sounds very scary...
Your Machine is very old..
What did you do last to the Copier to get it in this condition?
All you should have done is empty the Waste Toner bottle, and do SP83.
Oct 26, 2008 | Ricoh FT3713 Copier
Ricoh ft3713
Please properly installed the Drum Unit
Sep 22, 2008 | Ricoh FT3713 Copier
Ricoh FT3713
Try to properly close the cover and also the Drum Section
Sep 22, 2008 | Ricoh FT5832 Copier
396 people viewed this question
Top Ricoh Office Equipment & Supplies Experts
OfficeServiceAjnc
OfficeServiceAjnc
fares
Level 1 Expert
CheckitRight
CheckitRight
Are you a Ricoh Office Equipment and Supply Expert? Answer questions, earn points and help others
