Question about Craftsman Garden
Craftsman Model No.917.294250
I have a craftsman rear tine tiller. It is about 4 years old. I was tilling with it when all of a suddent the tires locked up. The tines still rotate and the engine runs good. Does this have something to do with the transmission, and does anyone know why this would occur?
thank you
trippssmengi
  • 76 Answers
SOURCE: Craftsman Front Tine Tiller 6.0HP/26" -- can not start it
First check for spark, if you have spark than you can try spraying a little fuel into the carb and try to start it if it starts then dies its the carb
Posted on Dec 27, 2008
steve_lima
  • 181 Answers
SOURCE: what type of lube is used in 917-294261 tiller gearbox?
80-90 gear lube
Posted on Jan 09, 2009
  • 10865 Answers
SOURCE: Help, new craftsman rear tine tiller stopped tilling.
It sounds like the belt just stretched. Now you need to move the belt tensioner over to put more pressure on it.
Posted on Apr 25, 2009
SOURCE: craftsman front tine tiller 917.299011 parts
If you are looking for repair parts diagrams and part numbers they are located pages 38 through 45 of the Owner's Manual.
Hope this helps.
Posted on May 26, 2009
  • 48 Answers
SOURCE: Tiller tines will not turn. Engine runs fine...
Well hopefully it's not the transmission, as sometimes these tend to go. Another common but cheaper repair are the two bearings where the tines connect to the unit.
MORE THAN LIKELY.. The bearing is located above the worm gear housing, the part connected to the tines beneath the guard. This removal can be somewhat frustrating but if you remove it and remove the engine flange you'll be able to manually spin the drive shaft and see if it's the worm gear housing/lower bearings or if it's the more likely bearing on the clutch drum or the clutch itself.
Posted on Apr 16, 2010
Tines on tiller
-Check the locking bolt that hold the tine shaft to the main shaft. Possibly it's broken. If so replace new bolt. you should be good to go again.
Good Luck
mai
May 24, 2014 | Craftsman 17 In. Dual Rear Tine Tiller
Craftsman rear tine tiller
If you cant move the tines by hand then I wouldn't think you sheared the pins, more like a gear box problem.
Mar 21, 2014 | Craftsman Garden
Tires and tines will not engage
model number would be VERY helpful here because craftsman made many different styles/models throughout the years
Nov 28, 2013 | Craftsman Garden
I purchased a Craftsman 205cc dual rear tine tiller (17" width) in 2009. I used it very little to break ground for a small garden (32'x12') after purchase then to till it a couple of times a...
It appears that the gear case on your model is not capable of being serviced. The cost is over 300 dollars. There is a shear pin or similar connection in the case where the shaft connects to the pulleys. It has broken off and the shaft has no torque now.
Mar 05, 2017 | Craftsman 205 cc 13" Dual Rotating Rear...
I have a craftsman 17" 5.5 rear tine tiller chain
Go to sears.com. at top of page about center of page find parts. put in model #. It will give you a breakdown of the whole tiller.
R.G.S.
Mar 22, 2011 | Craftsman Garden
I have a craftsman 19 in dual rotating tines, rear tine tiller. # 917-293493. In mid till, the tines quit turning. Won't shift into any gear. Wheels are locked. Any ideas?????
It is going to be a transmission issue. You can try with the engine off, turning the trans pully by hand in the opposite direction that the motor was turning it.
Some gears in the trans got crossed up and locked.
Aug 12, 2009 | Craftsman Rear Mount Tiller
Apr 25, 2009 | Craftsman 8.50 Torque Rating Rear Tine...
Craftsman 6.5 tiller model 486.252444
Not sure about this tiller but some others just need oil in the crankcase - tillers tend to lose oil because of the harsh conditions they work under. If you hear squeaking down their it might be a good idea to check it out.
Apr 19, 2009 | Craftsman Cultivating Shield
Garden Logo
229 people viewed this question
Top Craftsman Garden Experts
Wade Mobley
Wade Mobley
Dean Gruber
Roland W VanLue
Roland W VanLue
Are you a Craftsman Garden Expert? Answer questions, earn points and help others
