Question about Braun 4501 Electric Shaver
How do I open the case to change the battery?
How do I open the case of my Braun 5510 electric razor to change the rechargable battery?
There are 2 removable plastic plates on either side of the power entry connector> Pry these off with a knife and remove the 2 screws. Next slide the razor out of it's case. The batteries are soldered in.
Gary
Posted on May 25, 2009
Braun series 3 no longer holds a charge. what can I do?
It is not that young anymore. The rechargeable battery is (almost?) dead. It is almost impossible to replace it. I once tried it, took me more than a day yo put everything together and still it never was as before.
I have bought a new Braun (799) and I'm convinced this one will live longer. The rechargeable battery in this one, you can shave one hour before you need to recharge it. It lasts a week with me, or sometimes even longer, before I have to charge it again.
Perhaps you just use the shaver with the power cord, like we used to do for 20 years, and start saving for a new one?
Oct 14, 2014 | Braun Series 3 Electric Razor Shaver 370cc...
How do I open my Braun 9585 Pulsesonic shaver to replace the battery??
Hello
Remove the electrical cord from the base of the shaver.
Press down and slide off the panel on the front of the shaver.
Remove the two nickel-plated batteries. Use these batteries as a guide to purchase new batteries at a hardware store or home repair store. Recycle the old batteries when finished. (Many hardware and home repair stores have battery-recycling stations.)
Put the new batteries inside the shaver and press gently to pop into place.
Place the front panel back on the shaver and plug the electrical cord into the bottom of the shaver. Connect to an electrical outlet to charge.
THANK YOU FOR VISITING FIXYA
Feb 03, 2011 | Braun Pulsonic Rechargeable Cordless Men's...
Where are the rechargeable batteries located and can any rechargeable battery work as a replacement?
The battery is inside the shaver body. You must remove the rubberized grip to access the screws to disassemble it. You can not use any rechargeable battery. The battery is lithiun ion. The correct battery is available at shaveroutlet.com. See link below
http://shaveroutlet.com/shaver-replacement-parts/braun-liion-barrery-for-pulsonic-model-shavers-p-836.html
Jan 13, 2011 | Braun Pulsonic Rechargeable Cordless Men's...
I have a braun 5614 razor bought in usa many years ago and now needs new batteries.No one in zimbabwe can help, please tell me how to open razor and change batteries.
There are two round screw covers on the bottom. Pry these out to reveal two screws. Remove screws and then the out case can be slid downward and off. You can then access the batteries
Replacement batteries for model 5614 can be found at shaveroutlet.com. See link below
http://shaveroutlet.com/braun-battery-nimh-2-batteries-p-105.html
Sep 12, 2010 | Braun Health & Beauty
I have a Braun 5525 rechargeable razor purchased in 1996. It no longer recharges, and in the charge window displays a jagged line rather than a battery image. Is this a problem with the internal cell, and...
In that case, the circuit board in also bad. This happens when the batteries aren't changed in a timely manner. You can buy a circuit board with batteries at shaveroutlet.com. See link below.
http://shaveroutlet.com/braun-printed-circuit-board-with-batteries-p-107.html
To open the shaver you will need to remove the two plastic screw covers on the bottom on either side of the port where the plug fits in. Then remove the screws underneath. The outer case will then slide off the bottom. You may need to reposition the travel lock to get it all the way of. Then unsnap the black plastic back of the inner case and remove it. You can then lift out the old circuit board. Reassemble in reverse order.
Feb 20, 2010 | Braun Health & Beauty
My Braun 5564 electric/rechargeable razor will no longer hold charge. Suggestions please on repair or battery replacement?
You will need to replace the battery pack. Depending on when your shaver was made, it may have one of two different battery types. You will ned to look inside to see which you need before ordering.
To open, remove the two round screw covers on the bottom of the shaver. Remove screws to remove bottom of shaver. The outer case will then slide off the bottom. Push the trimmer up to be abl to take the circuit board out. BE CAREFUL not to detach trimmer oryou will not likely get it back on yourself.
Your battery(s) will be one of the two types below found at shaveroutlet.com
http://shaveroutlet.com/replacement-battery-for-remington-df-ms2-some-braun-p-213.html
http://shaveroutlet.com/shaver-replacement-battery-aa-nimh-p-108.html
Be sure to read the Note on the second link concerning instalation
If you are unable to do this yourself, shaveroutlet.com can do the repair for you. See link below
http://shaveroutlet.com/professional-battery-replacement-for-most-models-p-374.html
Feb 05, 2010 | Braun Health & Beauty
The braun 5510 shaver.. rechargeable or not
If working properly, model 5510 will work either from the internal rechargeable batteries or directly from the cord. If your shaver no longer recharges, it needs to have the rechargeable batteries replaced.
Feb 03, 2010 | Braun Health & Beauty
I own a Braun Electric Shaver Model 6525 Flex Ultra Speed. I plug it in and nothing! I am pretty sure the rechargeable battery needs replacing and I don't know how to open the razor to replace it. Also the...
if the shaver is DEAD and the green light no longer illuminates when you plug it in, the circuit board is almost certainly bad. The circuit board will burn out if you run the shaver from the batteries for a long time after the batteries have stopped charing properly.
you can purchase a new circuit board which has the batteries alrady on it. it just needs to be dropped in place inside the shaver.
you will find this part at shaveroutlet.com. see link below
Jan 15, 2010 | Braun Flex Integral 6525 Electric Shaver
Need to replace 5569 rechargeable batteries
If you are handy and know how to solder (and have the tools required), you can probably do the replacement yourself.
At the bottom of the razor are two plastic caps on either side of the charging port, you'll need to pry them out with a sharp pick or thin knive tip. Once removed, you can get to the screws that hold the front and rear case halfs onto the main shaver chassis where the PCB with the rechargeable battery is soldered onto the board.
Unsolder the battery and solder in the new replacement battery and put the case back together, making sure all the parts are in the correct posistion, and you're ready to recharge the shaver and start shaving again.
To find your replacement battery, try Electric Shaver Service. They also do repairs, so you might want to get an estimate if you don't want to do the repair yourself, etc. They're reliable and fast in getting shavers repaired and back to you quickly. 1-888-476-1785
Here's a link to the page with your battery on it and the toll free number to call for estimates too.
http://www.electricshaverstore.com/search.asp?p=2&w=%5F&c=battery&t=s&m=0
Hope you find this Very Helpful and best regards!
Jul 29, 2009 | Braun 4501 Electric Shaver
Braun 4501 Electric Shaver Logo
782 people viewed this question
Top Braun Health & Beauty Experts
shaveroutlet.com
shaveroutlet.com
Kazim ERGUNEY
Kazim ERGUNEY
Are you a Braun Health and Beauty Expert? Answer questions, earn points and help others
