HOW DO I SEND A FAX ON THE BROTHER MFC-5440CN? LOST MY MANUAL
  • 184 Answers
To send a fax, you will have to configure the settings. here are the steps you can follow;
Remote Fax Options;
You can only use one remote fax option at a time:
Fax Forwarding—OR—Paging—OR—Fax Storage—OR—PC FAX Receive—OR—Off.
You can change your selection at any time (Menu/Set, 2, 5, 1).
Setting up Fax Forwarding
When you select Fax Forward, your MFC stores the received fax in the memory. The MFC will then dial the fax number you’ve programmed and forwards the fax message.
  1. Press "Menu/Set, 2, 5, 1".
  2. Press ▲ or ▼ to select "Fax Forward". Press "Menu/Set". The LCD will ask you to enter the fax number to which faxes will be forwarded.
  3. Enter the forwarding number (up to 20 digits). Press "Menu/Set".
  4. Press ▲ or ▼ to select "Backup Print:On or Backup Print:Off". Press "Menu/Set".
If you select "Backup Print:On", the MFC will also print the fax at your MFC so you will have a copy if there is a power failure before it is forwarded.
5. Press "Stop/Exit".
Programming your pager number When Paging is selected, your MFC dials the pager number you’ve
programmed, and then dials your Personal Identification Number (PIN). This activates your pager so you will know that you have a fax
message in the memory.
1. Press Menu/Set, 2, 5, 1.
2. Press ▲ or ▼ to select Paging.
3 . Enter your pager phone number
followed by # # (up to 20 digits). Press Menu/Set.
Do not include the area code if it is the same as that of your MFC. For example, press 1 8 0 0 5 5 5 1 2 3 4 # #.
4. If your pager needs a PIN, enter the PIN, press #, press Redial/Pause, enter your fax number followed by # #. Press Menu/Set. (For example, press 1 2 3 4 5 # Redial/Pause 1 8 0 0 5 5 5
1 2 1 2 # #) —OR— If you do not need a PIN, press Redial/Pause, enter your fax number followed by # #. Press Menu/Set. (For example, press Redial/Pause 1 8 0 0 5 5 5 1 2 1 2 # #)
5. Press Stop/Exit.
■ You cannot change a Paging number or PIN remotely.
■ If you have set Paging, a backup copy of the received fax will
automatically be printed at the MFC.
Setting Fax Storage
If you select Fax Storage, your MFC stores the received fax in the
memory. You will be able to retrieve fax messages from another
location using the Remote Retrieval commands.
1 Press Menu/Set, 2, 5, 1.
2 Press ▲ or ▼ to select
Fax Storage.
Press Menu/Set.
3 Press Stop/Exit.
Setting PC Fax Receive
If you select PC Fax Receive, your MFC will temporarily store your
received fax messages in its memory, and then automatically send
the faxes to the PC. You can then use your PC to view and store
these faxes.
PC Fax Receive.
Press Menu/Set.
3 Press ▲ or ▼ to select
Backup Print:On or
Backup Print:Off.
Press Menu/Set.
4 Press Stop/Exit.
If you have turned on Fax Storage, a backup copy will
  • Before you can set up PC Fax Receive you must install the
MFL-Pro Suite software on your PC, make sure your PC is connected and turned on. (For details, see Using Brother PC-FAX software on page 5-1 in Software User’s Guide on
the CD-ROM.)
  • If you select Backup Print:On, the MFC will also print the fax at your MFC so you will have a copy if there is a power failure before it is sent to the PC.
■ If you get an error message and the MFC cannot print the faxes in memory, you can use this setting to transfer your faxes to your PC.
Turning off Remote Fax Options If you set the Remote Fax Options to Off and there are faxes in your MFC’s memory, the LCD will give you two options.
  • If you press 1, all unprinted faxes will be printed and erased
before the setting turns off. If a backup copy has already been
printed it will not be printed again.
  • If you press 2, the memory will not be erased and the setting will be unchanged.
Setting your Remote Access Code
The remote access code lets you access the Remote Retrieval features when you are away from your MFC. Before you use the remote access and retrieval features, you have to set up your own code. The default code is inactive code (--- ).
  1. Press Menu/Set, 2, 5, 2.
  2. Enter a three-digit code using numbers 0-9 or . Press Menu/Set. (The preset ‘ ’ cannot be changed.)
  3. Press Stop/Exit. Do not use the same code which is set in your Fax Receive Code ( 51) or Telephone Answer Code (#51). You can change your code at any time by entering a new one.
  4. If you want to make your code inactive, press Stop/Exit in Step 2 to restore the inactive setting (--- *).
Posted on Apr 22, 2009
    Scholar:
  • 192 Answers
Just go here and download the manual you need. I did for my unit. Its free. DFD
http://www.brother-usa.com/Manuals/
Will not receive faxes or copy Fax line rings but the machine says its receiving but nothing will print out and it won't copy pages either I've tried turning the machine off for up to 5 minutes,...
To begin troubleshoot,you should set the machine to basic Fax/Tel mode only.
1 If it is not illuminated in green, press (Fax). 2 Press Menu/Set, 2, 1, 2. 3 Press ? or ? to select how long the MFC will ring to alert you that you have a voice call (20, 30, 40 or 70 seconds). Press Menu/Set. 4 Press Stop/Exit. Even if the caller hangs up during the pseudo/double-ringing, the MFC will continue to ring for the set time.
After you confirm your Brother MFC-5440CN is able to receive fax then you can pick one of the 4 modes as describe on the owner manual.
You can download it HERE Detail Information is on 3-10
Jul 28, 2011 | Brother MFC-5440CN All-In-One InkJet...
I cannot receive a fax. I've tried all the 'fixes' in the manual without success. I've tried automatic receiving, manual receiving, etc. Need assistance, please.
Some Brother fax machines are only 14000bps models and have trouble receiving faxes from more sofisticated models at G3 speeds.
Call the person trying to send you a fax and have them drop down thier tx speeds to 9600bps orbelow and see if this solves.
I do assume the fax telephone line is plugeed into the reight jack.
Aug 03, 2009 | Brother MFC-5440CN All-In-One InkJet...
How to empty fax memory.
The setting for resolution was too high. Set back to basic and fax went through--no more problems.
Feb 08, 2008 | Brother MFC-5440CN All-In-One InkJet...
Cannot fax w/ phone line
have a look around here:
http://welcome.solutions.brother.com/bsc/public/us/us/en/faq/faq_list.html?reg=us&c=us&lang=en&prod=mfc5440cn_all&Cat=12
Dec 03, 2007 | Brother MFC-5440CN All-In-One InkJet...
648 people viewed this question
k24674
jasbo
jasbo
