Question about Sennheiser HMD 280 PRO Headphones
Left-side bass is messed up
On the left side of the headphones, the bass seems to be messed up. how do i fix it?
I just connected two sets of 901'a to Sansui G901 receiver. The sound is TINNY no bass at all. I've tried different connections and nothing seems to work. I've used two different EQ from bosse series
Either there is NO bass on the recordings (if you listen to it with headphones does it have bass?) ...OR...you've wired them out of phase. Connect only one(1) Bose 901's to just one side. Is there bass? Then connect the other side. IS there bass? If not reverse the phase (+ /- connections) and see if the bass comes back. Once that is done and there is BASS, then add the 3rd and then the 4th speaker. .Are you sure your Sansui can handle a lower than 4 ohm load???
Jun 19, 2014 | Audio Players & Recorders
Why are my headphones making a vibrating sound on the left side, when there is a lot of bass.
Each speaker works independently from each other. One speaker may use more low frequency tones than the other one.. Low frequency tones create a lot more noticeable vibration than higher frequency tones. You can reduce it by turning the volume down a little on the left speaker. It is possible that nuts came loose on the speaker.
Jun 01, 2014 | Beyerdynamic DT 770 PRO Professional...
Beats studio no bass working in the left cup.....
There may be a broken wire or defective connection in the left side.
Mar 28, 2017 | Beats By Dr Dre Studio Noise-Canceling...
Dre beats left ear "rattling"
Right now I am having the same problem. When the bass goes high it's an awful noise like rattling and I'm afraid I blew the speakers. But I was only listening to them on a simple iPod 3rd gen. Please helpppp!!!!
May 29, 2012 | Monster Cable Products Monster Beats...
Skullcrusher Bass not working.
You might want to check out my tip on replacing dodgy cable/plugs on headphones.
May 13, 2010 | Skull Candy Skullcrushers Headphones
Sound through headphones only.
Try the speakers on another computer, to see if they work at all. If they do, then the problem is the audio-interface on your computer (or DVD-player, or home-stereo system).
Apr 05, 2010 | M-Audio Studiophile DX4 Computer Speakers
Only the right side of the headphone works and the left turns on and off when the bass amp moves around.
yea i have the exactly same problem exept on my left??? did u find a way to fix them? i open'd them up and all the four wires were welded to the appropriate port. i think its in the wiring.... :( this is just very sad stuff with such beautiful head phones
Jan 27, 2010 | Skull Candy Skullcrushers Headset
STR-DE445 Works, but goes into protect when you turn up/down volume
This is a piece of **** unit. Mine only works on the left side, sometimes. When those times are I have NO idea. It doesn't seem to play 5.1 correctly and it goes into speaker protect mode for NO reason. It is TRUE lemon !!! ..let me know if you have any other problems with this JUNK .....schafe1001@aol.com
Aug 28, 2008 | Sony STR-DE445 Receiver
Sennheiser HMD 280 PRO Headphones Logo
63 people viewed this question
Top Sennheiser Audio Players & Recorders Experts
Vito Vacirca Jr.
Gerhardus Stroebel
Are you a Sennheiser Audio Player and Recorder Expert? Answer questions, earn points and help others
