Question about Dishwashers
Dishwasher dripping from uderneath - cannot see where from...
  • 1,869 Answers
Dishwashers leak from two places: the front lower door gasket or. the hose on the fill valve under the water float. before you check turn off the dishwasher circuit breaker and, make sure the machine is dead
Posted on Apr 22, 2009
The leak is coming from the loose gasket in the fan assembly (blower) connected to the vent cover. What I did to fix my leak was a simple step of adding petroleum jelly (e.g., Vaseline) around the gasket holder and reuse the same gasket (clean all parts first, including the gunk inside the fan blower assembly) and the leak stopped!! My wife was so proud of me!
Posted on Oct 23, 2011
Water is dripping from the door
try liffting the front legs of your dishwasher a bit so it angles more to the back and check your spray arms make sure they haven't cracked on the seem
Mar 29, 2010 | Kenmore 24 in. 16032 Built-in Dishwasher
EWDW6505GS0 Model Electrolux dishwasher 10 months in service has Error Code 01. Leak. What to do?
Dishwasher likely has leaked into drip pan underneath. Unfortunately, you need to remove dishwasher and flip onto back and remove 3 phillips screws that hold drip pan in place. Install "leak kit" to correct leak problem with this model of dishwasher. Part number is 154769101
Feb 14, 2010 | Electrolux 24 in. EDW5500DSS Stainless...
New whirlpool dishwasher when in use drips from right side.
Check if the dishwasher is level side to side and front to back. (you can generally tell if the edge of the tub has an even space between it and the cabinet at top and bottom, and the tub is not further in or out on top or bottom in relation to the edge of the cabinet. Also, make sure the door is not hitting the cabinet edge when you close the dishwasher door.
Feb 05, 2010 | Dishwashers
All the light on my new, Electrolux dishwasher are
Remove the kickplate at the bottom of your dishwasher and see what error you are getting. Likely a leak error.Dishwasher likely has leaked into drip pan underneath. Unfortunately, you need to remove dishwasher and flip onto back and remove 3 phillips screws that hold drip pan in place. Install "leak kit" to correct leak problem with this model of dishwasher. Part number is 154769101
Jan 25, 2010 | Electrolux 24 in. EDW5500DSS Stainless...
Electroluxe dishwasher starts and once water runs it quits working and all the lights on the display start blinking and it won't work. Any ideas?
Drips come from the bottom of the dishwasher
We had the same problem. It appears the door gets "tweaked" when you have a heavy load in the bottom rack or if someone mistakenly places pressure on it. Figure out which side is leaking then bend the door a little in the opposite direction. Worked for us.
Jan 17, 2010 | Maytag MDB7100AWB Dishwasher
Diplomat dishwasher bleeping showing FA
We have just experienced an FA audible error on our Diplomat ADP 8332 dishwasher...after pulling the dishwasher out and removing the low front panel we found the drip tray full of water. We tipped the dishwasher onto it's front and removed the drip tray and found a float pressure switch...it appears that once the drip tray is full the float switch activates and causes the FA fault (prevents the dishwasher from continuing) drain off your drip tray replace all covers and you should be good to go!!
Sep 16, 2009 | Dishwashers
Bosch 6802UC dishwasher is leaking water from bottom of door
Here is a tip that I wrote about dishwashers and them leaking.
Leaking Dishwasher
heatman101
Jan 22, 2009 | Bosch 24 in. SHU6802UC / SHU6806UC...
Electrolux 6505GSO dishwasher. Says ERROR 01 onled panel and will not function. What is this code and how can I make the the thing work?
Dec 31, 2008 | Electrolux 24 in. EDW5505EPS Stainless...
Whirlpool Gold Dishwasher leaking from behind door
could be water getting behind the lug that holds the dishwasher in place , I used some silicon sealant over the top and the dripping stopped
Oct 18, 2008 | Whirlpool Gold 24 in. Built-In Dishwasher...
Dishwashers Logo
153 people viewed this question
Top Dishwashers Experts
Owen Barnes
