SOURCE: hp deskjet 6980 blinking lights
ok so for this situation you have to do a cold reset, and by this you have to go ahead while the printer is still power on, disconnect the power cord in back of the printer, and wait for about two minutes. power on the printer if printer still has the blinking lights then go to step 2.
step 2-after this check the printer if light are still blinking, then your going to remove all printheads, remove paper, and then unplug printer power cord from printer and also from the wall outlet, wait for 20 seconds, then power on the printer, wait for light to flash then install the printheads, put paper, and press the resume button.
*** always connect your printer to a wall outlet never to a power strip, the power strip robs some of the power from the printer***
and this should fix the problem if it doesnt then the carriage might me malfunctioning . hp recently did a recall on some printer with the 6940 and some of the 6980, that the carriage broken.
Hope this help!
SOURCE: HP Deskjet 1280 : The resume light keeps on blinking.
Can I get the reply now? I have a whole lot of documents waiting to be printed.
SOURCE: HP Deskjet 5550 cartridge carriage stuck SPAM SPAM SPAM 1-800-532-4187
I have had this same problem a few times, not due to changing the cartiges, but following one of my kids yanking on a peice of paper as it was printing. After I tried all the unplugging and clearing and re-starting, the arm was still stuck on the left. I read on some forum (can't remember where) while the printer is off, to gently push/pull on the cartiges until they un-jam or start to move. I flet like I was going to break it, but it has worked every time.
Hope this helps osmeone else!
SOURCE: The carriage is stalled message on my hp officejet H470 printer
Check the printer again to see if a very small jam is present. If totally clear, press the Resume button. If same result, power the printer Off / On.
SOURCE: Replacement instructions for ink cartridge carriage assembly
Please follow the link below to HP Web site. This will take you to the HP 7410 Setup Chart. The cartridge instructions you need begin in frame 10.
http://h10032.www1.hp.com/ctg/Manual/c00236206.pdf
Don
