Question about Konica Minolta bizhub C250 All-In-One Laser Printer
WARMING UP LIGHT STAYS ON!!COPIER WILL NOT WORK??
WHEN WE POWER IT UP THE WARMING UP MESSAGE STAYS ON. THE COPIER WON'T WORK. ANY IDEAS?? THANKS, RICH
  • Frank
    Frank May 11, 2010
    replace the heater element.
    An expert whose answer gotĀ voted for 100 times.
    Sniper:
  • 62 Answers
Hi, it sounds like your firmware is corrupt. Have you tried rebooting the device by switching it off/on. Use the main switch inside the front door.
Failing that, you'll need to reload the firmware, an engineer will easily be able to do this
Regards
Taminol
Posted on May 11, 2009
I have a 1997 Nissan atlas truck which has the exhaust brake light and glow plug lights flashing on the dash after starting the truck does anyone have an idea what that is caused by. Thanks
The glow plug light will stay on till warmed and the go out. Exhaust brake light should go out at the same time, when engine warmed. The glow plug light action is normal t stay on for a bit longer cause it's still warming and needs the heat from them.
Jan 05, 2018 | Nissan Cars & Trucks
Xerox Fuser will not warm up? Any idea why?
The fuser is nothing more than a heater element. One fuser is broken and the other isn't. You need a new one.
Or did you mean the broken one works in the other machine? In which case the power to it is disconnected somewhere.
Dec 27, 2015 | Xerox WorkCentre 4150 Black and White...
My monitors not working. I think the problem is the camera. The light won't stay on. Any ideas???
If the monitor is not working then it should not be related to the camera. Do you see any error message on the monitor? Try unplugging it from your computer and tell me what you see on the screen.
Jul 26, 2013 | Computers & Internet
The cruise control won't work -air bag light stays on and just put in a new clock spring to fix this but that did not work? Any ideas?
check fuses and relay. if not.....double check that clock spring.
sorry thats not much help.
Jan 27, 2013 | 2002 Lincoln LS
My asb light comes on when starting and stays on. Lights won't come on , power locks won't work, power windows won't work, radio won't work. All fuses are good and car runs fine.
Those are all really common symptoms of the alternator going bad on those cars. I would have it checked to make sure it's charging properly.
Dec 15, 2012 | 1996 Oldsmobile Cutlass Ciera
We can't get our Dometic fridge to light when it's turned to gas. Model number 2453. It works on AC and DC but just won't light at all on gas. The gas will light but won't stay lit in the...
If you are lighting the pilot corectly and waiting for the thermo couple to warm up and then setting it to on, then the thermo couple is probably bad. Good luck!
Jun 27, 2011 | Refrigerators
My printer won't turn on. I have tried turning everything off and back on but it still won't turn on.
There is only one way to find out if it is an issue with the printer or the Power cord or Power Adapter.
Normally every HP printer has 2 parts. One cord connects the Printer to an Adapter. the Adapter cord then connects to the Wall outlet.
Now that you have connected the printer to working outlet, Check after 10-15 mins if the Adapter ( black box ) is warm or cold. If the Adapter is warm and the green LED light on adapter is glowing, then it could an issue with the Cord or the Printer.
Try with another Adapter or power cord to diagnose.
For Other brand printers, there should be a power adapter ( black box ) and it should be warm when connected to wall outlet, if it is not warm then it is defective power adapter that you need to replaced. Else it is a problem with printer mechanism.
Regards,
Shawn
May 07, 2011 | Office Equipment & Supplies
Warming up stays on, does not go out unless I
GO ON LINE A TYPE THE FOLLOWING INFORMATION IN THE ADDRESS BAR:
HP OFFICEJET 6110 INKJET PRINTER WARMING LIGHT STAY ON
ENTER
YOU WILL FIND OUT IF ANY ONE ELSE HAS EVERY HAD THIS PROBLEM BEFORE AND MAYBE HOW TO FIX IT.
RODGANDYSR
Mar 07, 2009 | HP OfficeJet 6110 All-In-One InkJet...
Konica Minolta bizhub C250 All-In-One Laser Printer Logo
210 people viewed this question
Top Konica Minolta Office Equipment & Supplies Experts
Norman  J Weimar Jr
Norman J Weimar Jr
Adorjani Laszlo
Ben
Ben
Are you a Konica Minolta Office Equipment and Supply Expert? Answer questions, earn points and help others
