Every time I press the record button I get a "remove the casette" message and it will not record. I then take the casette out and put in another and get the same message. When I switch it to recording on the SD chip, it stil shows the message "remove the casette". Please help. Thank you.
-   I have exactly the same problem, after recording 18 tapes (different brands) and my son dropping the camera on the floor, but if I want to use it I just pull the battery out for about ten seconds, do not switch from "play mode" to "camera mode" and you will be o.k. If u have to switch mode, just pull the battery out again. I will not buy canon again.
-   I have the same problem and the repair folks say it will be at least $200...help!-   seattleb
Dec 11, 2007
-   Hi. I have the same problem. The tape will run for a while then I get a beeping sound and the message to remove the tape. I have tried changing the tape and turning the camera off for a while but the problem persists. Is this something a local camera repair person could fix?-   kmacive
I was having the same problem with my canon elura 70. I called Canon tech support and they told me that there are three possibilities. 1) The camera is made to not accept tapes when the tape heads and path are dirty. 2) There is condensation in the camera. 3) There is an internal problem that would require you to send it in for service.
The first is a $15-$20 fix. Go out and buy a cleaner that will clean, not just the tape heads, but the entire path. In other words one that is not just a brush that moves back and forth, but one that winds on to both spools and gets pulled over the entire path. Unplug your camera, take the battery off, take out the watch battery and the SD card and let the camera sit for about 20 minutes before cleaning. Put all that stuff back in--PLUG IN the camera to the wall charger, then clean the tape path.8 out of 10 times this will solve the problem.
2) If there is a moisture droplet on the screen, this indicates condensation. Unplug your camera and let it sit in a controlled temperature room for about 2 hours. Do NOT use a hair dryer unless it has a no heat setting. The heat can fry other components.
3) If it isn't one of the other two...it will most likely need service.
Hope that helps.
Don
I just received the following information from Canon. Similar to Donjr's.
"The Remove Cassette issue is currently a big issue with Canon camcorders, however, it is not due to the camcorder. Canon USA has found that the cause is when customers use multiple brands of DV cassettes. Each different brand uses a different lubricant and when these lubricants are mixed they congeal and hinder the camcorder heads from moving. This can cause the Remove Cassette error. When this message is received Canon recommends using a dry cleaning cassette to clean the lubricant off of the camcorder heads. You can obtain a dry head cleaner at any local store that carries electronics equipment. If this does not resolve the issue, then the camcorder may need a Tape Path Alignment, or the posts may be loose. This would require servicing to resolve the issue."
I have purchased a cleaning tape and will be trying this solution as soon as it arrives in the mail.
Comments:
Jan 07, 2008
- I have now tried using the cleaning cassette. It did not solve the problem. Did it work for anyone else?
THESE CAMERAS ARE PEICES OF ****!!!!!!!!!!!!!!!!!!
I suggest that no body buys from cannon again!!
I am suppose to record my sister-in laws wedding and BOTH of my ELURA 100's are displaying the EJACT TAPE message!
"TEMP. FIX"
This takes pateince however for me it works....When you get the EJECT TAPE mesage....eject the battery with the power on (thus the power will go off by means of the battery not being in camera) then slap the battery back in....and KEEP doing this untill eventually the camera will NOT DISPLAY the message and actual work.
It may take up to 20 trys ....slap it in..slap it out...slap it in slap it out...BUt for me it works.
If it appears to work but as you hit the RECORD button it beeps and displays the EJECT tape message again...Go back and eject the battery again and repeat the STEPS...but dont worry , that means your getting closer to it working.. LOL
Seconding Charpy Man's hack. Mine is an older Elura. It struck me as risky, but in fact worked like a charm after only two attempts at yanking the battery. In my case, I was yanking the power supply when plugged in, but the result was the same: when presented with the "eject" notice, I ejected the tape, I pulled the power, shutting the camera off immediately and unceremoniously. I then popped the power supply back on, inserted the tape, and got the eject message again. But when I repeated, suddenly, all was well.
Thanks, Charpy Man.
I had the same problem with my Elura 100. The problem started happening a few months after the warranty expired. I tried connecting to AC power only; this worked only once. I've only ever used TDK tapes (10 tapes recorded). The problem I was having was the tape never ejected. I've never dropped it or exposed it to water. The only solution that worked (which is similar to #2 above) was to open the cassette bay and leave the unit next to my laptop fan/exhaust for ~2-3 hrs. So far, so good. Thanks Donjr!
By the way, my local Canon repair shop was going to charge me $160+tax (CDN) to fix it.
I am trying to connect Canon Elura 100 to my laptop to transfer video recorded of my kids. I...
(More)
I am trying to connect Canon Elura 100 to my laptop to transfer video recorded of my kids. I connect the IEEE cable (4 pin to 4 pin) to the camera and the computer and turn the camera to "play". The camera is not recognized by the computer. My other computer doesn't have a port for the IEEE cable, and I don't have any other devices to test on my laptop. So I'm really not sure where the problem is. Can you help?
When I turned on my Canon Elura 100, the motor whirred free, like the partially used cassette tape...
(More)
When I turned on my Canon Elura 100, the motor whirred free, like the partially used cassette tape was spinning away. When it stopped, the camera wouldn't play or record, and display said "check tape." I opened the cover to eject the tape, and the motors spun again, but the tape won't eject. I tried recharging, even ejecting with the power cord plugged in. Nothing works. Any suggestions?
I get the 'remove the cassette' message, but when I open the camera the tape starts to eject, then...
(More)
I get the 'remove the cassette' message, but when I open the camera the tape starts to eject, then stops and goes back in.
I accidentally dropped this camera and now it plays all tapes with several thick gray bars on the...
(More)
I accidentally dropped this camera and now it plays all tapes with several thick gray bars on the viewfinder. It also plays them when I hook it up to the VCR. Any suggestions as to how this problem can be fixed? Thanks so much!
