Question about Slider Lutron: Dual Fan Control / Light Dimmer: 300w, Single Pole
Control fan/light separately, with only two wires
I have a combination ceiling fan + light. I would like to have the fan and light controlled separately from the wall, however the house is not wired for it (only one hot and one neutral going from the wall to the fixture).
The fan/light fixture does have two hots and a neutral, but both hots are wired together at the base of the fan. There are two chains to control the light and fan speed. The chains are fine, but what I really want is full-range dimming of the lights, while maintaining fan speed. (And I'd prefer to control it from the wall rather than pulling chains.)
What I am imagining is this: a small device to install above the base of the fan, which would split the single hot wire into two separate hots for the light and fan. A special wall control would communicate with the above-fan device, instructing it to power the light and/or the fan.
This seems to me like a relatively simple application of a proven technology (ethernet and HD can be sent over a powerline, so why not a signal to dim a light or turn on a fan at speed 2?) I just wonder if someone has implemented it and if it's available for a reasonable price.
Thanks!
~David.
  • 3 more comments
  • dle3ab Apr 23, 2009
    Thanks, guys, for the input!
    It sounds like noone's doing a signal-over-power solution as I'd hoped. I'm not fond of these radio gadgets, and the cheapest remote/receiver (in fact the only one I've found) is $75:
    http://www.ylighting.com/mod-mf005.html
    I guess I will have to look more seriously into adding an additional hot wire.
    This is an old house with two add-ons, and 5 fan+light fixtures, so the situations vary. One has a conduit, so that one should be easier, and thus a good place to start. So I guess I'll see if I can do that one and then think about the others.
    Cheers,
    David.
  • dle3ab May 25, 2009
    Thanks for the idea -- Home Depot has three different wireless transmitting devices that will work, and the cheapest is less than $30! I may go for the $50 Lutron, as the dimmer control is functionally superior IMO. This is a great find -- duh, of course I should have gone to Home Depot in the first place -- thanks very much.
  • Brent  Reddick
    Brent Reddick May 11, 2010
    Can you change wire from wall to fan? < would you feel comfortable doing this? if you can then could give you instruction for set up.
  • Frank
    Frank May 11, 2010
    I would just pull the 2 sets of wires and install the switch on the wall. it looks better and clean. besides cheap about $40 should do the job.
  • Frank
    Frank May 11, 2010
    you are talking about wireless device, it is not cheap at this time. cost of the device is going to run you $100-200 per device. for a dual device control it should run you about $300-400.
    here is a thought, check out radio shack or other hobby shop for a set of remote control deices.
  • 323 Answers
They are available at Home Depot and Lowes. Hunter makes a wall mounter dimmer that will control the lights and fan speed separately. There is a receiving unit that mounts above the fan to the house wires on one side and the others connect to the fan.
The two hots you mentioned should be a black one and a blue one. The blue is for the lights; the black the fan. Ground everything you can to boxes, etc, if the house is only a two wire system without a ground.
I believe that remote wall switch and receiver runs close to $40.
Sirwriter
Posted on May 23, 2009
  • Dan Todd May 23, 2009
    Au Contraire. Look at Insteon.com, and you will find that you can find dimmers, either RF or IR controlled, which can be hooked to a Harmony remote or and Insteon remote. Usually, you need two remotes or a remote and a relay installed. The dimmers from Insteon run only on a ground and a white neutral wire. They are easy to wire in (in a 1,2,3, or 4 gang box in place of the traditional switch. Also, check out Homeautomation.com for pricing and ordering. Stay away from anything other than Insteon (speaking from experience.)
    Note: The Insteon signals are dual mesh, that is, running on a combination of the relay signal as well as the house current.
    Sirwriter
Is there a switch between the fan motor and the light motor on an outdoor Horchow ceiling fan? The light is coming on, but not the fan. Thank you!
for these combination fans there is a separate switch for the light
It can be in the wall next to the fan controller, a pull switch from the middle if the fan or a remote control switch operated by the remote control
Talk with a fan supply shop for details of your fan
Jun 17, 2015 | Dryers
I need help hooking up my bathroom fan and light i have three wires going to the bathroom fan and light white black and ground i want a swith to turn off the bathroom light one to run the light to the fan...
Right now a single switch turns on both light and fan.
You want to put in a double switch to control light and fan separately.
But the problem is there is not a separate wire to each the light and fan.
You need a separate wire to each, but the circuit wasn't wired that way.
Usually when the circuit is wired for separate control, there is a red wire that also goes to ceiling box.
Unless you run another wire to the ceiling box, it won't be possible to control light and fan separately.
Electrician can do this pretty easily if there is attic space above bathroom.
Oct 17, 2010 | Broan-NuTone Broan 68W White Decorator...
Trying to install lsdc163pwv for ceiling light operated by 2 different switches. Install box is through switch with black common hot wire, red and black travelers and 2 white neutrals and grounds . New...
Found a .pdf file that shows LSDC163pwv ... it does not show wiring for LSDC. It shows wiring for other 3-way dimmers & separate wiring for 3-way fan control. This is a clue.
The Pass and Seymour download page does not load, so I can't see specific manual.
Let me provide what I know:
-Instructions might be confusing because LSDC works for both single-pole and 3-way circuits ... which probably adds a lot of extra wording in manual
-LSDC Device has single-pole/3-way dimmer (this requires 3 wires)
-Device has single-pole/3-way fan control with 3 speeds (which requires 3 wires)
-That's 6 total wires
-If I understand correctly, you just want to control a ceiling light? -And you do not have a fan? And your ceiling light is set up with 3-way switches.
-IF you are also wanting to control a fan in addition to the light, the box will need separate wires that go specifically to the fan >> your description shows that you do not have separate wires for the fan. Is this correct?
-Without separate wires to the fan, you can still control the light ... but if wires to light also turn the fan on-and-off, then the LSDC is not the right control since a dimmer for lights will not work on both fan and light.
To wire the light:
-You have identified black common wire for light (it is connected to dark-colored screw on 3-way switch)
-You have identified travelers that connect the 3-way switches
-The neutral wires seem to be twisted together at back of box.
-I think the dimmer is located on the top, and fan control is bottom?? Not 100% sure >>>
-Question: are there 3 wires that are associated with dimmer?
-If you can see 3 wires for dimmer, one of those wires should be black ... just hook that to common, and hook other 2 wires to travelers ... and see if it works. If not, keep connecting them until correct combination is found.
Tip- I read a lot of electrical part manuals, and when confused, I write out the instructions so it breaks down the information.
Oct 03, 2010 | Pass & Seymour Pass and Seymour Decorator...
Missing remotes for hampton bay ceiling fans
https://www.google.com/search?q=remotes+for+hampton+bay+ceiling+fans&rlz=1C1PQHB_enUS689US689&espv=2&biw=1536&bih=748&source=univ&tbm=shop&tbo=u&sa=X&ved=0ahUKEwik3qiMx4bTAhXh5oMKHV3vDJ4QsxgIGg
Apr 02, 2017 | Hampton Bay 52 In. White Redington...
Does the red wire coming out of the ceiling go to the blue wire in the fan. i cant get the lite kit to come on
The white wire in your ceiling box is USUALLY the neutral wire. Green or bare wires are ground wires. Any other colored wires are generally hot, switched or unswitched. If changing the position of a wall switch makes a white wire hot, it is NOT a neutral wire. You need a test light, generally an inexpensive neon test light available at any hardware store, and a book on basic wiring would help. To control the fan and light separately, assuming you have not installed a wireless control, you need two switches, one for the fan and one for the light. If you do not have these, you need a wireless control unless you have a spare wire in the wall switch box or you need to be satisfied with controlling the separate functions with the pull chains. Check the ceiling box wires. Put one lead on the ground wire or, if you have steel boxes, on the box. Remove the wire nuts on the other wires, being careful not to touch any wires or touch any of the wires to each other or the side of a metal box. Touch the other lead to the other wires, one by one. If the light comes on, the wire is hot. Try the wall switch(es) on and off and see what changes. To make the fan or light work it has to be hooked up to a neutral wire (white, never hot regardless of any switch positions) and a hot wire. The same is true for the light kit. If you do not have or want two wall switches, one for the light and one for the fan, you need to identify the wire that is hot when you turn on the wall switch and hook it up to the black (fan) wire AND the blue (light)wire. You then control both with the single wall switch in conjunction with the pull chains. If you have two switches in the same wall box, and they make two different wires hot in the ceiling box, hook one to the black fan wire and one to the blue light wire. If you're set up with only one switch, and you're lucky, you may have an extra wire in the same cable from the ceiling box to the wall box, with a wire nut on each end. In that case, install a second switch for the light (or a combination switch designed to control both a fan and light). Hook the hot wire from the wall box to both switches (or the hot terminal on the combination switch) and the other two wires to the other two terminals that go to the ceiling box to feed the light and fan. Never use a light dimmer switch to control a fan or a fan speed switch to control a light. If two or more switches in different areas controlled the original fixture in the ceiling box, things can be complicated. If the same wall switch makes two different wires hot depending on it's position, for example, it's a three or four way switch. The above description also assumes the wall box is fed from the ceiling box, but the opposite may be true. There may also be wires in either box that are feeding other circuits in the house. Electricity can kill or burn down your house. If unsure of what you are doing, hire a licensed electrician. Also be aware that if you touch the leads of the test light to two wires that are both hot, the light may not come on. Always test with one lead on a ground or a wire that you are sure is a neutral wire. I recommend tuning off the power to all the circuits in the boxes that you are working on, after you have determined what the wires are, by shutting off the circuit breaker(s) or removing the fuse(s). There may be more than one circuit in a box.
Feb 12, 2010 | Hampton Bay 24002 Ceiling Fan
Need a basic diagram to wire a ceiling fan.
Depending on how your place is wired will dictate the solution here.
The light box in your ceiling should have two or three wires. Black and White, or Red, Black and White.
If you have two wires (one switch to control everything):
Black is power - hook this to the fan's power wire (and the fan's light wire if applicable)
White is neutral - hook this to the fan's neutral wire.
If you have three wires (two separate switches):
Red is power for the light - hook this to the fan's light wire if applicable
Black is for the fan - hook this to the fan's motor
Sep 18, 2009 | Hunter 52" Ceiling Fan With Light And...
I have a ceiling fan with a light that is controlled by the same switch. I want to put a combination switch to control them seperately. There two sets of 3 wire (black, white, red, ground) and another set...
First, turn off the circuit breaker. The three wire bundle should be the incoming power, the four wire bundle should be going to the fixture. Using a duplex switch (one with two toggles), the incoming black wire goes to one side of the switch, the outgoing black and red wires go to separate terminals on the other side of the switch. The whites are connected together. The Grounds (or bare copper) are connected together and to the switch ground screw. Hopefully both the outgoing read and black were connected to the old switch or you may have to rewire the fan to wire up the fan and light separately.
Jul 06, 2009 | Cooper Wiring Devices ACE AC-DC...
Ceiling Fan Electric
hi,
you may have two dedicated ceiling fan circuits coming out of that box, check to make sure theres not a black wire bunched up in the ceiling or cut off, or try this
1.white to white wires, and black wire and black with a white stripe to red wire out of ceiling for fan and light together operation
2. If you can find the black and the red and the white coming out of the ceiling then you may have two switches on the wall for that fan, red for black fan wire, black with white stripe for the to black out of the ceiling , white all together. try that combination
for separate light and fan control from the wall
good luck, and be careful
J
Aug 06, 2008 | Hunter 22451 The Brookline Brushed Nickel...
Slider Lutron: Dual  Fan Control / Light Dimmer: 300w, Single Pole Logo
2,149 people viewed this question
Top Slider Electrical Supplies Experts
Steve
Gene Haynes
Are you a Slider Electrical Supply Expert? Answer questions, earn points and help others
