After pressing f2, the screen displays words that are mis-spelled. every other character is 1 letter behind what it should be.
SOURCE: Blank Screen
contact toshiba, sounds to me like the BIOS was erased. they can send you a CD that can fix that problem. it will cost you like $10 for it
SOURCE: Toshiba Laptop unable to start but only displays post screen
ur OS has corrupted two reasons for that
1. due to virus, malware spyware, etc
2. Hard Disk is getting weak wants replacement
solution first try to re install the OS if u find it difficult to do so then my friend ur hard disk needs replacement
factory reset procedure
Toshiba: BEFORE TURNING ON THE LAPTOP, press and hold the 0 (zero) button on the keyboard, then turn on the computer while holding the 0 (zero) button down. When the Toshiba logo screen appears, you can release the 0 key.
pls rate me FIXYA if i fixed ur problem
SOURCE: Laptop won't boot up.
http://www.cgsecurity.org/wiki/CmosPwd
I have used this program at school to bypass bios passwords and i find it to work well.
You may also try to type Toshiba where it asks for the password.
SOURCE: toshiba satellite a60 wont start.
replace your cmos battery inside... look for a technician for assistance to remove the cmos battery and change a new one... your battery is weak already
SOURCE: toshiba l505d reset bios i
It's very Easy.. remove ram cover near the ram u can see small jumper short the jumper for 15 second with flat screw driver.. if same ..do again but keep short jumper and turn on laptop for 15 second .... Thanks if okie give me vote
Testimonial: "now it asking for a HDD #1/ssd password i don't know what that is do SIM"
F1
F2
F3
F4
F5
F1
Almost always used as the help key,
almost every program will open the help screen when this key is pressed.
Windows Key + F1 would open the Microsoft
Windows help and support center.
Open the Task Pane.
F2
In Windows commonly used to rename a
highlighted icon or file.
Alt + Ctrl + F2 opens a new document
in Microsoft Word.
Ctrl + F2 displays the print preview
window in Microsoft Word.
F3
Often opens a search feature for many
programs including Microsoft Windows.
Shift + F3 will change the text in
Microsoft Word from upper to lower case or a capital letter at the beginning of
every word.
F4
Open find window.
Repeat the last action performed (Word
2000+)
Alt + F4 will close the program
currently active in Microsoft Windows.
Ctrl + F4 will close the open window
within the current active window in Microsoft Windows.
F5
In all modern Internet browsers
pressing F5 will refresh or reload the page or document window.
Open the find, replace, and go to
Starts a slideshow in PowerPoint.
