Apple iPhone4 4G iPhone 4 Logo
trevor dien orton Posted on Oct 08, 2013
How do i factory resest my iphone 4 its completely disabled
ElgoBay
Level 1:
New Friend:
Problem Solver:
  • Contributor 17 Answers
  • Posted on Oct 08, 2013
ElgoBay
Contributor
Level 1:
New Friend:
Problem Solver:
Answers
17
Questions
Helped
3379
Points
33
Hold down both the power button and the home button for 10 seconds, release the power button, keep holding the home button for 10 more seconds, iphone should be in DFU mode. Restore with iTunes.
4answers
My iPhone 6 is dsabled. How do I get my phone back
You will experience your iPhone is disabled if you have entered the Face ID or Touch ID incorrectly multiple times. If you want to know how to deal with this issue and recover your iPhone, continue with this; To Fix A Disabled iPhone With iTunes or iCloud
How do i unlock my iphone
You can put your iPhone into Recovery Mode to unlock it. This will allow you to restore it without needing the passcode.
Step 1. Disconnect all cables from your iPhone and turn it off.
Step 2. Press and hold the Home button and connect your iPhone to iTunes. If your iPhone does not turn on, please turn it on manually.
Step 3. Continue holding the Home button until you see the Connect to iTunes screen. iTunes will remind you that it has detected your iPhone in recovery mode.
Step 4. Click OK. The Summary tab in iTunes appears. Click "Restore iPhone" and restore your iPhone.
Step 5. Once the restore process is complete, you'll be prompted to setup your iPhone as if it were new. If you have an existing backup, you'll be able to load it.
Recovery Mode will erase all your data and passcode from your iPhone, resetting it to factory defaults. Thus, you'll have brand new iPhone without any personal data after you unlock a disabled iPhone with Recovery Mode. Therefore, please consider carefully whether you need to use this method to fix the issue.
http://www.leawo.org/tutorial/how-to-unlock-a-disabled-iphone-with-without-itunes.html
3answers
How to unlock iPhone without password
Hello Allen. If your iPhone is disabled, the only way to unlock it is to completely erase and reset it. If you have a backup, you'll be able to restore it, otherwise you'll lose all of your data. There is no way to unlock a disabled iPhone unless you use the correct passcode or you erase it.
Step 1. Connect your iPhone to the computer with via a USB cable that your iPhone has trusted.
Step 2. Launch iTunes. If you've synced your iPhone with iTunes, then no "enter password" is required.
Step 3. iTunes will automatically sync your iPhone and create a backup file. If it doesn't, you should sync your iTunes and create a backup file manually by clicking "Back up Now" in the Summary window.
Step 4. In the Summary window, you can see the option "Restore iPhone". Click it to reset your iPhone. Once the reset process is complete, you'll be taken through the iPod's initial setup process.
Step 5. Select "Restore from iTunes backup" during the setup process. This will load the backup that you created so that all of your data is restored.
How to Unlock Disabled iPhone with without iTunes
Nov 21, 2016 • Cell Phones
2answers
My Iphone4 is disabled, windows and iTunes does not recognize it, I want to factory rest it.
How to Unlock/Fix a Disabled iPhone - "I forgot my iPhone ...
? 7:34
https://www.youtube.com/watch?v=DjEw6DPGYiY
Jan 7, 2015 - Uploaded by Full Screen Ahead
4.) While holding the circle button at the bottom of your iPhonedisplay, ... Your PC or Mac will say "iTunes has detected aniPhone in recovery mode. ... says "Are you sure you want torestore the iPhone to its factory settings?
How to remove/reset any disabled or Password ... - YouTube
? 5:31
https://www.youtube.com/watch?v=csLUmaDTHl4
Oct 30, 2014 - Uploaded by Karlos Corner
How to remove/reset any disabled or Password locked iPhones6S ... Thank you for watching, please feel free to comment, likethe video or subscribe to my ..... Iphone Disabled / Forgot Passcode iPhone Fix - Hard Reset for ...
Hard Reset for iPhone 6/5s/5c/5/4s - YouTube
? 3:21
https://www.youtube.com/watch?v=C8OCbVO8r6g
2answers
How to unlock my Iphone 4 when its disabled
If your iPhone has been disabled, it is completely locked down. The only way you'll be able to use it again is by restoring it using iTunes or iCloud. If you have a backup, you'll be able to recover your data, but this process will delete everything that is stored on the iPhone. Except for the following four ways, there is no other way to unlock a disabled iPhone. Step 1. Connect your iPhone to the computer with via a USB cable that your iPhone has trusted.
For more detail, check: How to Unlock A Disabled iPhone with/without iTunes
How do you disable a i phone 4
You can disable a iPhone by entering a passcode wrong too many times.
1helpful
My iphone is disabled and says connect to itunes it will only allow me to make emergency calls
When the Iphone is restored to factory settings you will receive the prompt to connect to itunes and only make emergency calls, you will need to connect the Iphone to itunes to allow the Iphone to complete the setup process, similar to when you first buy an Iphone.
7helpful
5answers
IPHONE DISABLED
restore your iphone to factory settings this will solve your problem go and get this click here it will jailbreak your iphone and unlock it to any sim this gu will help you just tell him your problem and he will solve it he's a god with all things iphone.
Top Apple Cell Phones Experts
Grand Canyon Tech
Grand Canyon Tech
ADMIN Andrew
ADMIN Andrew
Paul Bade
Are you an Apple Cell Phone Expert? Answer questions, earn points and help others
