Question about Refrigerators
Need defrost timer and manual to determine location of part
I need a defrost timer and service manual to determine where this part is located. Refer quits cooling after a week or so. After unplugging the unit for several hours and then plugging back in, unit operates normally.
  • beefs120 Apr 22, 2009
    If you remove the interior cover plate and thaw ice built-up on coils with hair dryer, you can go about 12 days before it ices over again. Be sure to plug drain and use shop vac to remove water. This will buy you some time until you find the manual/parts to fix. Unplugging compressor often can damage the unit (so I'm told).
    Scholar:
  • 192 Answers
I would say you right on on this one. I can not help with manual . I dont no what kind it is.But I may be able to help. Sometimes they will just stick in one place. Some where On the back there is a hole with a slot on the switch. Take a screw driver and turn it clock wise several times , this will often free then up, they will sometimes stick befor they go bad. give this a try. All so a manual wouldent tell you where it is. But sometimes a nice repair man will tell you for free. Try this. Good luck DFD
Posted on Apr 22, 2009
    President:
  • 1,489 Answers
Unload the refrigerator and remove the back inside panel. You'll see the defrost timer. If all connections are good (which sometimes they aren't) the timer motor is probably bad -- it's an easy replacement.
Where is the location of the freezer defrost timer
The defrost timer is usually located in the top of the refrigerator compartment or in some older models its located in the base of the unit. Normally you will see a small 3/8" hole in front of the timer that is used to move the defrost timer manually with a regular (flat type) screwdriver.
Oct 08, 2014 | Refrigerators
How to locate and replace defrost timer on GE GSS23KGSA WW
Yes the GSS23KGSAWW defrost is controlled by the WR55X10942
motherboard. What is happening that you would ask about a defrost timer? Let me know if you have questions, Thanks Sea Breeze
GSS23KGSAWW Service Manual
Nov 19, 2012 | GE GSS23KGS Side by Side Refrigerator
I have a GE profile Fridg PSS26NSTASS where is the defrost timer located
The PSS26NSTASS does not have a defrost timer. The defrost on that model is controlled by the motherboard=> WR55X10942 Board Assembly Main Control On your model if not defrosting it will most likely be caused by the=> WR51X10055 Defrost Heater It also does not hurt to replace the=> WR50X10068 Defrost Thermostat
while inside freezer changing out the defrost heater. Click here=> PSS26NSTASS Freezer Components
In that photo location 230 is your defrost heater and location 240 is your defrost thermostat. Here is a=> PSS26 Service Manual if you don't already have Adobe Acrobat Reader Click HERE I will be here should you have any questions, Thanks Sea Breeze
Feb 16, 2012 | GE Refrigerators
Defrost heater & fan not working. Evapotater is freezing solid. I would like to know location of defrost timer and how to manually activate it. Do you have voltage checks for motherboard ? How do...
The defrost timer is built in to the mother bored, pull the unit out from the wall and you will find the bored behind a metal panel. Please come back to me if you need anymore help.... Richard
Jan 19, 2011 | GE GSS25LGM Side by Side Refrigerator
What initiates the defrost?
Hi and welcome to FixYa I am Kelly.
Your defrost cycle is controlled by a mechanical defrost timer similar to a spa timer
Download this manual then see pages 13 and 14 for locating and setting the defrost timer.
http://www.mbm-service.de/mbmTechTwo/True_/GDM-9+/Service_Manual.pdf
There are 3 different types of GDM units. NOTE the one 2 and 3 door timer locations on page 13. There are all in different locations.
Also see page 109.
If you need service or technical help:
TRUE MANUFACTURING TECHNICAL SERVICE
1-800-325-6152
Thanks for choosing FixYa.
Kelly
Sep 26, 2010 | True GDM-23 Refrigerator
I am trying to respond to the defrost refrigerator problem but can't tell how to do so. The model is 106.70203990 Kenmore Elite Coldspot. I need to know how to troubleshoot the defrost timer and/or...
the defrost timer should be in the center hood, hanging from the refer section,
if you look up you should see the bottom of the timer
http://www.appliancepartspros.com/modelsearch_model.aspx?image=1&part_id=3110896&model_id=410075&pkw_=timer&x=14&y=16
it will look like this
you can turn it with a flat head
turn it till it till it clicks and the machine shuts off
it should turn the machine on in 20 mins or so
if it does its probaly good
the defrost heater is behind the back wall
its looks like a straight element , they best way to test this is to ohm it out,
no continuity, its no good
next while your behind the wall
http://www.appliancepartspros.com/modelsearch_model.aspx?image=1&part_id=3135377&model_id=410075&pkw_=thermostat
look for this part its your defrost tstat
make sure it looks just like the picture and not popped
sometimes this will actually pop open and be obviously bad
Oct 17, 2009 | Refrigerators
Maytag refrigerator, feezer side coil frozen and frigirator not
Defrost circuit failed, needs to be able to defrost the coils so air can pass through them thus cooling evenly. You can check the heaters located on the coils probably near the bottom back wall of the freezer with a ohm meter if you read through, the heaters are good, if you get no reading the heaters are bad. Or could be defrost timer or on newer models the adaptive defrost control which is a circuit board. If its an older model you can manually turn the timer with a screwdriver if you feel resistance, then you should replace the timer. Also in the circuit is the defrost thermostat located on the coils, this is the least expensive of the 3 components to replace. You should have a schematic located under the fridge, use this to determine which type of timer you have and for further trouble-shooting. Please let me know if this helps
Aug 22, 2009 | Maytag MCD2257HE Side by Side Refrigerator
Location of Defrost Control timer on GE Refer
look around where the thermostat is . do you see a 1/2 inch hole where there's a small button where a flat screwdriver can turn it then that's the defrost control. remove the upper panel and you should have access to the control. Good Luck
Jan 30, 2009 | Refrigerators
Defrost timer sticking
Your model doesn't have a defrost timer. Everything is controlled by the main motherboard in the back. The ONLY way to get an acurate diagnosis is to call GE FActory Service at 1-800-432-2737. There is proprietary software and the tech will be able to plug in a laptop to your refer to find out what is going on. No other companies have this or have access to this software. By the way that deforst thermostat you think you found isn't what you think it is. It looks like one but it only a saftey device. Trust me...!
Dec 16, 2008 | GE GSS25LGM Side by Side Refrigerator
Defrost timer location
need to know the make and model...
GE are in the top right back
Frigidaire are under the toe plate left and right also in the back by the compressor. cheaper frigdaire are in the middle center top refer... so you see they hide them in a lot of places..
Aug 25, 2008 | Refrigerators
Refrigerators Logo
177 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
