Question about Ricoh Office Equipment & Supplies
Ricoh Aficio MP 2000 ADF (auto document feeder) is not working
The ADF on my copier is not working. It is connected to the machine - an error message pops up if I open the paper covers as if to unstick a jam. I can't get the ADF to do anything.
  • fredfroogle Apr 24, 2009
    My appologies, there actually is no error message, rather the screen says that it cannot determine size of paper (due to it not recognizing the ADF) and then it copies a copy of the empty scanner bed. The only time it displays an actual error is when I open a flap or door on the ADF. Then it tells me to close that flap
  • Anonymous May 11, 2010
    what is the error message? what happens if you try to use it? anything, or is that when it shows jam?
    New Friend:
  • 63 Answers
Tape is on the underside of the ADF causing a sensor to not tell the machine that the ADF is in the lowered position. look under where the hinge area goodluck
Posted on May 01, 2009
Ricoh MP201 SC820 CODE 612 Detail 40000000
[06FF]: Detailed error code
The pipeline clock frequency
rate is different from the
prescribed value.
?? Defective CPU devices
?? Mode bit data error, which is used
for initializing CPU.
1. Replace the controller board.
Apr 09, 2017 | Ricoh Aficio MP-201 Copier w/ Duplex...
Service Code SC620-01
Steve Jensen: The Ricoh copier error code 620 / SC620 is a BICU to ADF communication timeout error code.
If you are receiving a document feeder communication error code of SC620 you may want to:
Check the Serial line connection (unstable)
Check the External noise on the line
To reset this error try the code:
"Clear Mode"+107+"Clear/Stop" hold for 5s.
Turn ON and OFF the Main Switch.
If the problem persists you may need to contact a local service technician to take a look at your copier.
this is the first result when you go to www.google.com and type in
scs620-01 seriously...
Sep 14, 2014 | Ricoh Aficio MP-C3300
Hello, Our Ricoh Aficio 2000 is saying to remove paper from the ADF but as far as i can see there is no Paper. Tried switching it on and off again but to no avail. Any suggestions?
Hello!
Swithing off and on do not solve your problem.
Make sure that you do not have any sort of paper in the ADF.
If you are sure that you do not have any paper, you probably have a faulty paper sensor.
Not the best help i know...
Jun 24, 2011 | Ricoh Aficio MP 2000 Black and White...
How can i solve error code sc:302 in ricoh Aficio 2000 copier.
You should have a service technician take a look at your copier. SC302 is a charge roller current error, and it could be caused by a number of things, from a dirty charge roller to a faulty high voltage supply board.
In the meantime, try turning the machine off, unplugging it, and then plugging it back in and turning it on the see if the error message will clear.
Aug 24, 2010 | Ricoh Aficio MP 2000 Black and White...
Copies run through the feeder have black line on them, copies on glass & faxes are okay
Clean the ADF scanner glass. This is the small strip of glass that is just to the left of the large glass. Normally there is a label on the machine right by this glass that instructs you to clean this strip of glass whenever streaks appear when using the ADF or Automatic Document Feeder. Sometimes toner/dirt gets stuck on this strip of glass so clean it well using a soft cloth with some glass cleaner.
Good Luck and Thank You for using Fixya
Apr 29, 2010 | Ricoh Aficio 1035 Copier
I have a ricoh spc232sf multifunction printer which is giving a error message of cannot copy and it says feeder adf what do i do?
the ADF is the upper cover where you put the document to be automatic feed by the machine, that is the part which you pull up when you want to copy on the exposure glass, on the left side of the ADF has a little door which you need to open. It is opened like a car door opener and pull it on the right side. see do have some paper inside if do not have paper close the door and lift the ADF in to up position and than set it back. with this you will rest the message.
Please answer do this is helpful for i to know do i should post some more information.
Regards
Jan 12, 2010 | Ricoh Aficio SPC232SF All-In-One Laser...
Aficio 2015 ADF not working
if you plug the ADF connector while the machine is on the code will appear when you connect the ADF shut down the machine and then connect the ADF plug
Jun 22, 2009 | Ricoh Aficio 2015 Copier
Ricoh C21SF Automatic Document Feeder (ADF)
Take a little soap and a little water and clean the gray feed tire that is located in the document feeder. Check for any paper obstructions. If the machine has had a lot of prints I would replace the feed tire.
http://www.websitetoolbox.com/mb/copierquestions
Sep 25, 2008 | Ricoh Aficio SP-C210SF Printer
Error msg..."close ADF cover". Where is it?
Adf : auto doc feeder
the top that you put the pappers in to copy mare than one sheet.
make sure all doors are closed.
lift doc feederas if making copy on glass look where the hinges are there should be a plunger next to one of them, that is the switch to tell it if it's open or flat. try pressing it down to see if message goes away, it may need adjusting.
Jul 15, 2008 | Ricoh Aficio 1013F Copier
1,092 people viewed this question
Top Ricoh Office Equipment & Supplies Experts
Adorjani Laszlo
OfficeServiceAjnc
OfficeServiceAjnc
fares
Level 1 Expert
Are you a Ricoh Office Equipment and Supply Expert? Answer questions, earn points and help others
