Question about HP Photosmart C5180 All-In-One InkJet Printer
My HP C6180 All in One printer shows an Ink System Error oxc18a0207. I tried removing the ink cartridges and reinstalling them but the message will not go away. What is solution?
    President:
  • 2,004 Answers
You must have inserted a refill ink cartridges or there is a malfunction in the ink registering led.
Get a new set of inl cartridges from an authorized shop and insert.
This will end all the worries.
But if you have already done this, just ignore the error report it will go off later.
Posted on Apr 22, 2009
I am getting a error message saying the printer does not have enough ink to ensure printer health. The empty ink cartridge must be replaced to resume printing. I replaced the cartridges and it does not...
These printers have been known to have ink system failure errors. This message can also be caused by using compatible or re-manufactured cartridges. We believe the HP Live update software is also responsible for "dobbing" on you if you use any other brand.
A Fix for the ink system failure can be found below Not sure if it will help with your particular error but it wont hurt to try.
http://fix-your-printer.blogspot.com/2009/03/ink-system-failure-on-hp-photosmart.html
Good luck
Apr 14, 2011 | HP Photosmart C6180 All-In-One InkJet...
HP Photosmart C6180 Ink System Failure Message
just follow this steps may help you out otherwise you need to change it.
Check to see if the installed cartridge is the correct one for the printer. . If the cartridge is the proper part number, remove the ink cartridge and make sure all the packaging tape has been removed from the copper circuitry strip on the backside of the cartridge. Reinsert the cartridge and try printing again.
If the error continues, remove the cartridge again and clean the copper circuitry strip on the backside of the cartridge, and the contacts inside the printer, by following the instructions below:
1. Use a clean, dry, soft, lint-free cloth. Locate the copper-colored circuitry strip on the back of the cartridge.
2. Wipe the copper-colored strip with the dry cloth. Use an upward motion, from the nozzle end to the top of the cartridge. Do not wipe the nozzle end of the cartridge or touch the nozzle plate. Wipe the contacts only once.
3. To clean the printer contacts, carefully look for fibers or contamination on the electrical contacts inside the carriage assembly, but do not wipe the printer contacts with any object. The contacts in the printer can be damaged if too much pressure is applied during a wiping process. Try to remove any visible attached debris within the carriage assembly by gently pulling the debris off with your fingers. If the carriage contacts show noticeable damage, contact the HP Customer Care Center listed in the printer's User's Guide.
Reinsert the cartridge and try printing again. If the error continues,then you can go for repair or buy a new one .but i advise you to dont go for repairing bcoz it is 3 year old .
Have a nice day and do not forget to rate please...!
Feb 02, 2010 | HP Photosmart C6180 All-In-One InkJet...
Hp printer will not detect new ink cartridge has been installed. Thought it was the cartridge, bought a new one and it still says it needs replaced.
I have had similar problem with my HP C6180. Over several months I have replaced Lt. Magenta at least 6 times. Finally I got a "Cannot Print" message after the 6th full cartridge. I tried removing/replacing cartridges, doing a hard reset, and clearing the hardware failure status (press # and *, enter code 1,2,3, scroll to 'System Configuration' press OK then scroll to 'Hardware Confifuration) - all to no avail.
I decided to remove the BIOS battery. Only do this if you're ready trash your C6180 and able to buy a new printer immediately! Remove 2 the black screws holding the left side panel in place and remove it to reveal the circuit board. Remove 5 silver screws securing the circuit board, and carefully tilt it up. On the back side, center front, is a silver 3 Volt Lithium battery; remove it. Cover the printer and let stand overnight. I did this, and when I put the battery back in and powered up the printer, error messages were gone, and it printed normally. I was lucky, but if you're prepared to take a total loss on your C6180, this might just work. My theory is that the hardware "forgot" it' error message.
Sep 03, 2009 | HP Photosmart C6180 All-In-One InkJet...
Keep getting replace yellow ink cartridge error message
Where did you get the error message on printer or computer?
If you get the message on printer remove all cartridges and reinsert the cartridges and align the ink cartridges. If the alignment page prints successfully then the problem is resolved.
If you get the message on the computer disconnect the usb from computer. uninstall the software and reinstall the full feature software by selecting connect USB later.
May 23, 2009 | HP Photosmart C6180 All-In-One InkJet...
Ink System Failure HP C5180
IssueAn 0xc18xxxxx or 0xc19xxxxx ink system error code displays on the front panel. The printer cannot copy, receive faxes, or print. Solution
Press the On button to turn the printer off.
Unplug the power cord from the back of the printer.
Remove all the ink cartridges.
Wait two minutes.
Plug the power cord into the back of the printer.
Press the On button to turn the printer on.
Install the ink cartridges when prompted.
If the error code does not display, the issue is resolved.
If the 0xc18xxxxx or 0xc19xxxxx ink system error code displays on the front panel, service the printer.
Jan 23, 2009 | HP Photosmart C6180 All-In-One InkJet...
Oxc18a0101 error message - C6180 All-In-One
Try the following reset:
Hold the OK and the Help button at the same time. While holding them down, plugthe power in. Continue to hold both buttons until the unit shut off.
After shutting down, release both buttons and power on the printer.
Alternatively follow instructions on this document from HP.
Oct 14, 2008 | HP Photosmart C6180 All-In-One InkJet...
Ink System Failure
below is to document that i want you to follow exactly inorder to resolve your issue..
CLICK HERE ==>> DOCUMENT
Please let me know the result after following the document.
thank you so much.
adonscott
Aug 07, 2008 | HP Photosmart C6180 All-In-One InkJet...
Error message #Oxc19a0013----Ink system has failed
Solution
Wait two minutes.
Jul 19, 2008 | HP Photosmart C6180 All-In-One InkJet...
HP Photosmart C5180 All-In-One InkJet Printer Logo
500 people viewed this question
Seeker5211
Seeker5211
