Question about Whirlpool Washing Machines
Washer won't drain and timer stops in the middle of cycle
Won't drain
  • dmthompson72 Apr 23, 2009
    model number is LT23585R16
  • 5,911 Answers
If this is a top loader, the symptoms you describe are commonly caused by a defective lid switch. Could you please provide a model number, so I can assist you further? I need to confirm your washer configuration to ensure I'm giving you accurate information.
Posted on Apr 22, 2009
  • Jeff Rockwell
    Jeff Rockwell Apr 23, 2009
    Can you please verify your model number again. The number should be printed on a nameplate somewhere under the washer lid. The model number you provided, does not cross to anything I have. Is this a top loader?
For Eurotech EWC177W fornt load washer, the machine stopped working in the middle of a cycle and now the start light does not illuminate. I have determined it's not the outlet power. Does thsi washer...
Hi
If the cycle won't complete then either it's a problem with the timer or a cold-water supply problem:-
If your washing machine fills with water and begins agitating, but the timer never advances--or if the washer is in a spin cycle and the timer won't advance. Then you need to replace the timer.
It may be a cold-water supply problem, if the washing machine fills with water, agitates, drains, and spins, but then doesn't fill with rinse water.
Please check the link to get some more idea:-
http://www.washerhelp.co.uk/diy-repair-help_8.html
Please get back to us if you have further query else please accept the suggestion.
Thank you for contacting fixya.com
Jul 07, 2011 | Washing Machines
Washer won't drain
hi,
The timer went bad. If you move the timer manually to spin will it pump the water out? if it works that way then the timer is bad for sure
Mar 28, 2010 | Frigidaire ATF6000ES Front Load Washer
Washer Stops Mid-cycle
HI. this is a defective timer mechanism. it must be replaced asap, if possible. the timer is the principal initiator of the units cycles. The motor is defective at this point.
Replace this damaged timer control device asap.
Aug 20, 2009 | Kenmore 22422 Top Load Washer
Stops in the middle of wash cycle
Hi!
If the cycle doesn't advance, it's probably the timer or a cold-water supply problem:
It's the timer, if your washing machine fills with water and begins agitating, but the timer never advances--or if the washer is in a spin cycle and the timer won't advance. Then you need to replace the timer.
It may be a cold-water supply problem, if the washing machine fills with water, agitates, drains, and spins, but then doesn't fill with rinse water. See There's no cold water.
Please do rate this solution as FixYa and revert for further assistance.
Thanks
Rylee
May 29, 2009 | Whirlpool Ultimate Care II LSQ9549L Top...
Won,t drain on rinse cycle
Ok mc we need a timer at this point. You see the timer doing several steps different than before.
Nov 01, 2008 | Whirlpool Ultimate Care II LSQ9549L Top...
Kenmore stacked washer / dryer 2002
hi thanks for the question so your saying your tub is full of water ,did it stop in the middle of the wash cycle or at the end of the wash if its at the end of wash and it doesn, drain then you have a lid switch problem . if thats the case reset your timer as if you want to start a new wash load if it starts to wash your timer is ok replace the lid switch
Aug 27, 2008 | Kenmore 98702 Stacked Washer/Dryer
HELP
check the lid switch
Mar 27, 2008 | Washing Machines
There could be several causes for this, but probably a bad timer. One test for this...when it stops...is to turn it off...and turn the timer slightly clockwise...to the middle of the rinse cycle...and turn it back on. Does it run then?? Try advancing it to the spin cycle after the rinse. If it runs okay after you manually advance the knob...the timer is probably defective.
Jan 13, 2008 | GE WNCD2050AWC Top Load Washer
Washer stopped in the middle of a cycle
i wouldn't be so quick to replace the timer as those rarely go bad. Start simple and check the lid switch. On whirlpoos they sometimes shift position and dont always close when the lid is closed
Aug 25, 2007 | Whirlpool LSB6200PQ Top Load Washer
Washing Machines Logo
Sal De
Gerry Harvey
Gerry Harvey
