Question about Sony KV-27S22 27" TV
Tv repairing when i plugged it, it blew. i replaced the 102, 1kv ceramic capacitor and the 2.7 ohm fusable resistor ans also the str. but it still doesn't start to turn on. the power led doesn't light. what do i need to do?
    Genius:
  • 1,153 Answers
You still have something open in power supply. Look for a fuse resistor or bad relay.
Posted on Sep 23, 2007
SOURCE:
Sony TV has a power supply problem both ics irf1b7n50a in the power supply section are all shorting which number could I use as an equivalent. is there a way I could use a power modular with two power id's
Hi Saidi
Have you checked all the other components used in the main power supply regulator section circuit, before replacing a new STR? You should do it. There should be a reason for the failure to STR. You should find it, and rectify it, before replacing an other STR. Check all the small components, resistors, zener diodes, small value ceramic capacitors etc: Make sure all of it are OK. Especially give a keen attention to zener diodes used; if any. It will be best to replace these diodes, even if you do not find any fault with it with multimeter test.For more information go to http://electronicshelponline.blogspot.com/
Power supply schematics to some popular brand TVs are given. Pull up older posts. Good Luck.
Nov 26, 2013 | Televison & Video
Is there a specific solid state part known to make the fuse blow in model number sb350
It sounds that there is some short circuit with its main power supply regulator circuit. A detailed check is necessary to locate the exact faulty component/s. If you are sound in electronics, you can do it by yourself. If not, contact any service technician. If you wish to get more details, check this site. Pull up older posts there. Check the site with patience, as it has over 2350 posts now. All are related to electronic equipment repair help. If you check the site in Timeslide option, which can be selected from the drop down list at the top left side of the display window, it will make search easy.
Apr 21, 2013 | Emerson SB350 13 in. TV/DVD Combo
Getting no power I,ts not the power cord herd a popping sound and the sub lost power
The popping sound might have been caused by an electronic component (capacitor) inside which blew. If it's still under warranty I would bring it back to the shop.
Mar 06, 2011 | Creative Labs MegaWorks THX 550 Computer...
Enter main220v str6707 shart
hi,
when u replace the str 6107 along Whit it ,replaced the opto-coupler, the polistor , ceramic capacitors in the str side. mainly that one connected to is pin 3.
on the out put side replace the SE1XX voltage controller also.
ok
Dec 22, 2010 | Sony FD Trinitron WEGA KV-36FS120 36" TV
Won't Power up fuse is not blown
hello,
Since the fuse doesn't blow now (you did replace it with one of the same ratings, right?), you need to check for:
Other blown fuses - occasionally there are more than one in a DVD.
Replace with one of exactly the same ratings.
Open fusable resistors. These sometimes blow at the same time or in place of the fuses. They are usually low values like 2 ohms and are in big rectangular ceramic power resistor cases or smaller blue or gray colored cylindrical power resistors. They are supposed to protect expensive parts like the HOT but often blow at the same time.
If any of these are bad, they will need to be replaced with flameproof resistors of the same ratings (though you can substitute an ordinary resistor for testing purposes). Before applying power, check: Rectifier diodes, horizontal output transistor, regulator pass or chopper transistor (if present), and main filter capacitor for shorts.
An initial test with an ohmmeter can be done while in-circuit. The resistance across each diode and the collector to emitter of the transistors should be relatively high - a few hundred ohms at lest - in at least one direction (in-circuit). If there is a question, unsolder one side of each diode and check - should be in the Megaohms or higher in one direction. Removed from the circuit, the collector-emitter resistance should be very high in one direction at least. Depending on the type, the base-emitter resistance may be high in one direction or around 50 ohms. If any reading on a semiconductor device is under 10 ohms - then the device most likely bad. The filter capacitor should eventually measure high in one direction (it will take a while to charge from your ohmmeter). It could still be failing at full voltage, however.
If you find one bad part, still check everything else as more than one part may fail and just replacing one may cause it to fail again.
May 21, 2010 | RCA DRC8320 DVD Recorder/VCR
Tv will not turn on
This could probably means that the power relay is working, though there could be bad contacts.
Since the fuse doesn't blow, now you need to check for:
Other blown fuses - occasionally there are more than one in a TV.
An initial test with an ohmmeter can be done while in-circuit. The resistance across each diode and the collector to emitter of the transistors should be relatively high - a few hundred ohms at lest - in at least one direction (in-circuit). If there is a question, unsolder one side of each diode and check - should be in the Megaohms or higher in one direction. Removed from the circuit, the collector-emitter resistance should be very high in one direction at least. Depending on the type, the base-emitter resistance may be high in one direction or around 50 ohms. If any reading on a semiconductor device is under 10 ohms - then the device most likely bad. Assuming that you do not have a schematic, you should be able to locate the rectifiers near where the line cord is connected and trace the circuit. The transistors will be either in a TO3 large metal can or a TOP3 plastic package - on heat sinks. The filter capacitor should eventually measure high in one direction (it will take a while to charge from your ohmmeter). It could still be failing at full voltage, however.
Assuming everything here checks out, clip a voltmeter set on its 500 V scale or higher across the horizontal output transistor and turn the power on. Warning - never measure this point if the horizontal deflection is operating. it is ok now since the set is dead. If the voltage here is 100-150, then there is a problem in the drive to the horizontal output circuit. If it is low or 0, then there are still problems in the power supply or with the winding on the flyback transformer.
Other possible problems: bad hybrid voltage regulator, bad startup circuit, bad standby power supply (dried up filter capacitor, etc.) bad relay contacts as mentioned above. However, these probably would not have blown the fuse in the first place so are less likely.
Good luck...
May 21, 2010 | Proscan 26LB30H 26 in. LCD TV
Toshiba Plasma TV 42" 42HPX95
Components on the printed circuit board are still faulty, you need to carefully check the components on the board with the use of an ohmmeter.
Do follow the below procedures to enable you repair your television.
The click probably means that the power relay is working, though there could be bad contacts.
Since the fuse doesn't blow, you need to check for:
May 21, 2010 | Toshiba 42HPX95 42 in. Plasma Television
Loud crack when turning unit on, blows main fuse no lights come on.. bottom of power supply black and signs of burn...
DO NOT REPLACE THE FUSE !!! You will do more damage.
I just repaired one of these. A small ceramic surface mounted cap very near where the +/- 85 volt connectors plug onto the board blew up.
This left a sputtered mess on the insulating material at the right rear corner of the power supply.
The net parts list of parts I had to replace:
1. Main IGBT transistors on heat sinks. You have to remove the heat sinks to get at the mounting screws. 1MBK50D or equivalent. I used DigKey part APT28GA60BD15
2. One 1N4148 surface mount diode that is for gate drive speedup. D24 and D25. (don't remember which one was shorted)
3. All four driver transistors for the gate of the IGBT's. @ each 2SA1020 (PNP) and 2SC2655 (NPN). These are tall TO92-like transistors and I believe that at least one of these I had to get from Mouser.
4. Transistor T9, suface mount BC856B (PNP)
5. Replaced all four surface mount caps, one had exploded.
C50, C51,C54,C56. Replace with 0.01mfd/200 Volt 1206 style surface mount caps Digikey 478-1511-6
6.Replaced ceramic wire wound 10 Watt stand up resistors that were blown open. Replaced with 20 ohm design change. These slowly charge the main input filter caps and when supply is stable, a relay shorts them out. If you have replaced the fuse, you LIKELY blew them out. Original value was 10 ohms on some units. This was a Mouser part. 280-PRM10-20-RC
7. The 2153 switching reg chip IC1. This chip shorts. It is made by International Rectifier and I believe the full number is something like IRF2153. I had these in stock and not sure of which source I had procured them from... It was from one or the other.
Lots of destruction and one really needs a desoldering station to work this. Removal of the blown IGBT's is especially tough. All solder must be removed from the transistor leads AND the thermistor on one of the heat sinks. Once you have verified the leads are loose, one has to rock the heat sinks to get the tabs free. The tabs are NOT soldered! Be careful when restoring to get the thermistor leads started in their holes.
Note: ALL these repair parts were procured from DigiKey.com and Mouser.com. Neither of these places had all, I had to order from both. Mouser had the ceramic resistors.
When restarting this, leave outputs disconnected until it is running again. USE a series 75 watt light bulb in the 120 volt input. ONLY work on the unit using an isolation transformer as a large portion of this is connected right to the power line.
There is a small 15 volt switching supply that comes on first that runs the relay to short out the inrush limiting resistors. With the 2153 shorted as usual, this auxilary supply can't reach voltage enough to turn on the relay. The power for this is supplied through the ceramic resistors.
May 08, 2010 | Behringer Pmp3000 16 Channel Audio Mixer
Sony kv xj29m50 no picture.
If I understand you correctly:
The horizontal output transistor in your TV blew.
You replaced it with a BU2520DF.
I'm not sure what you mean by "change to dynamic mode".
Dynamic what?
Usually, horizontal problems in TVs are caused by bad capacitors in either the sync circuit, the driver circuit, the geometry circuit or the output circuit.
When I repsir problems like this I use an oscilliscope to find which stage is not working properly, then start substituting the capacitors in that stage until the problem is solved.
Look for large orange or blue ceramic or polyprop capacitors with bulges or cracks in them.
Look for electrolytic capacitors with bulging tops or shrunk cases.
Check and make sure no resistors are brown, they may be blown.
Use an ohm meter to test low value resistors in circuit.
If you don't have an oscilliscopw, that's about all you can do.
Jan 31, 2008 | Sony KV-XJ29M50 29" TV
Tv trouble shooting
whenever any fusible resistance fails means there is a short ckt in tv. failure is mainly due to main filter cap or rectifire diode os switching ckt failure(here as you cleared str.) remember while servicing power supply isolate hor. section for safety purpose.& connect it only after power supply output is ok &after checking parts in hor. ouyput section. if this seems to be ok then go for hor.output ckt failure like hor output,flyback transformer & cap& diodes connected with it.
Oct 02, 2007 | Televison & Video
Televison & Video Logo
103 people viewed this question
Top Sony Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Steve Allison
Steve Allison
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
