Question about Sony Grand WEGA KDF-50WE655 50" Rear Projection HDTV
Green vertical lines in bottom left corner
About 6 months ago I noticed my Sony Wega rear projection TV has green vertical lines in the bottom left corner of the TV. They are not noticable when the TV is off and they blend in with the blues and greens in the TV when it is on. They have not spread at all since i first noticed them. Does anyone know what this is and how to fix it? The model number is KDF-50WE655
    Genius:
  • Sony Master
  • 1,148 Answers
IN THE MENU USE THE CONVERSION OPTION IF IT HAS IT
Posted on May 15, 2009
2006 sony wega vertical lines green lite blinkspower stand by has sound
This is normally caused by the DIC block being defective and will need to be replaced. However the optical block aka light engine has been known to cause this also, But is very rare.
Mar 18, 2013 | Sony Grand WEGA KF50WE610 50" Rear...
Sony wega tv, vertical green lines on right half of tv?
the convergence board probably causing the problem, you need to change the convergence IC's, or the board.
Dec 03, 2010 | Sony Grand WEGA KDF-60WF655 60" Rear...
Problem with sony 60" rear projection TV
I'm afraid, it is problem of optical block unit (light engine) that produce picture by 3 lcds inbuilt, the blue lcd and its related uv filters become defective and causing this kind of blue hue on screen.
Complete optical unit block (light engine) will be replaced by qualified tech to get tv fixed, light engine is costly part so ask an estimate before sending tv in.
Thanks.
May 21, 2010 | Sony Grand WEGA KDF-60XS955 60" Rear...
Green line running vertically along the edge of picture
If its a LCD projection TV (such as Sony Wega, Hitachi, Epson, Philips, and some Panasonic, some Mitsubishi), and the green image is in the whole screen or just one part as a blob or a line. Is most probably that one of your LCD Color Filters is damaged (burned out or starting to get busted), I don’t know if you can just replace the color filter, I believe you need to change the whole light engine system or the optical block. There are some places around, I found some on ebay but you should definitely try on discountdashmerchantdotcom their price range $260.00 - $330.00
Jun 25, 2009 | Sony Grand WEGA KDF-42WE655 42" Rear...
Bluing at bottom of picture.
take away if there was any speaker near the tv Unit. you need to demagnetize the screen using a magnet or demagnetizer.
Jun 13, 2009 | Sony Grand WEGA KDF-42WE655 42" Rear...
GREEN BOWED LINES
You have a convergence problem Call a Sony service center make sure they use original ic's in this model cost is around 350.00 depending on area.
Apr 13, 2009 | Sony Grand WEGA KDP-57WS550 57" Rear...
Red/green drooping L top corner
i have found when samsangs convergence are out of range perfect focus will fail. if the are out of range a technician will try to adjust the set in service mode. store these values and then this will be the base for the perfect focus. If the set has a bad convergence cuircit then they have to be replaced.
Nov 05, 2007 | Samsung HCN653W 65" Rear Projection...
Problems with green arching lines
yes there is a small black box with 6 controls on it, take off the bottom front of the tv, behind that you should find a black piece of plastic you can remove by taking out 2 more screws. the black box should be in the upper rhs.now i don't remember if the top 3 are the screen controls or the focus controls. the rows should be labled, you are looking for the screen control row. the green control is the middle one. you can try turning down the control till you no longer see the green lines. try adjusting in a dark room, it will be easier to see the lines & when they are gone. if you problem is not solved by trying this, then i agree with your tech & the green tube is bad. good luck.
Oct 23, 2006 | Sony KP-65WV700 65" Rear Projection HDTV
Sony Grand WEGA KDF-50WE655 50" Rear Projection HDTV Logo
138 people viewed this question
Top Sony Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
