Question about Samsung HLN5065W 50" Rear Projection HDTV-Ready Television
Anyone have a sevice manual? I need a part number for cable.
I recently replaced color wheel on my HLN5065w and dispite knowing how fragile cable connectors can be, I broke one. I was able to fix but would like to replace next time I have cabinet opened. It is the three conductor white/white/blue(top to bottom) which connects just below copper ribbon cable for color wheel onto the vertical board towards the rear of tv from color wheel. It had to be removed to get color wheel assembly out(crosses over it). Any help finding this part would be greatly appreciated. I dont want to buy a manual and find its no help.
  • 4,234 Answers
Send an email to the address below with as much descriptive info as you can and ask for the part number, availability and cost. They will research it for you.
CETechSupport@encompass.com
Encompass is a parts distributer in the US that supplies parts for Samsung.
Dan
Posted on Apr 25, 2009
Service manual to install a color wheel,for a samsung hln5065w also if you have direction
you can get the service manual which shows color wheel replacement from the following link delivered by download link within minutes of ordering http://servicemanuals.vstore.ca/product_info.php/pName/hln5065w/cName/samsung-manuals
Oct 29, 2011 | Samsung HLN5065W 50" Rear Projection...
My hln5065w started making a loud noise like a fan noise upon startup recently. The color is fine (I've read the color wheel w/loud noise problems). It has been doing this for the past week, previously...
The loud noises came from the tv with a colors wheel design in it have to be replaced every few years,because the spinning of the colors wheel disc are spinning in very high speed in RPM to have it colors for the tv to operate correctly,the humming,loud motors noises and eventually the effect of the tv colors.The colors wheel disc are worn out and spinning hitting it axes motor,the colors wheel must be replaced to solved this problems.
Jul 21, 2011 | Samsung HLN5065W 50" Rear Projection...
I just replaced the color wheel on my samsung hln5065w. Picture is great but there is a shadow on the right side of screen from top to bottom. The shadow on the top of the screen is wider across the screen...
Its a Good Possibilty that its the New Color Wheel causing this,if the colors are not complete on the color wheel then that will be why you are seeing shadow on right hand side of screen.
I know I ordered color wheel for mine and had to send it back,it did the same thing.
I compared it to the old color wheel and the new one did not have Solid colors on it.
Can you see picture behind the shadow? or is it shadow and no picture?
Mar 06, 2011 | Samsung HLN5065W 50" Rear Projection...
I just replaced the color wheel HLN5065W and now it wont turn on. I get 2 blinking lights lamp/temp. Do i need to reset? Could it be the fan plugs are out of order?
There is a common mistake people make when they replace the color wheel.
There are two cables from the color wheel that plug into the DM unit, a silver box. One is a normal plug with wires and the other a flat usually orange ribbon cable.
Note the ribbon cable where it plugs in only has contacts on one edge! It is quite common to put it in backwards and the set will not turn on nor will the lamp come on, contacts on it usually face the rear of the set, This is simple to check and happens often.
Let me know what happens and or if you have more questions.
SD TECH
Jan 10, 2011 | Samsung HLN5065W 50" Rear Projection...
I replaced the color wheel in my HLN5065W DLP tv now I dont even get a picture. After 3 times of it restarting itself I get 3 flashing lights on the front of the TV.
THIS IS JUST A SUGGESTION, IF I am right give me a very helpful vote here and a note, check the ribbon cable----color wheel has two cables--one regular and one orange--look at contacts on orange one--they should face the back of the light engine--it is very possible to put the cable in backwards--common issue.
SD TECH
Sep 01, 2010 | Samsung HLN5065W 50" Rear Projection...
There is no color and a very loud noise comes from
Sounds like your color wheel has failed. Its right about time, they don't always go bad but do fail regularly. This one uses a bp96-00250a and it costs about $95 plus shipping. You can get one straight from samsung it will come to about $105 after shipping.
http://www.samsungparts.com
Its a little tricky to get it in, and its glass so its fragile, but a mechanical person with a few screwdrivers can get it done in an hour or two. Let me know if I can be of further assistance.
Jun 11, 2010 | Samsung HLN5065W 50" Rear Projection...
Where can I find these two parts, and how do I attached them?
www.tvrepairworld.com should have the items you need. Just leave them a email with your model number and what youre needing
Aug 08, 2009 | Televison & Video
No color perfect picture hln5065w
Either your Color Wheel is bad or the DMD bd is bad. You will need a trained Samsung tech to look at it to determine which it is. The Color Wheel replacement is relatively inexpensive Color Wheel part# is BP96-00250A. The DMD bd is a little more but are hard to find besides you must have a trained Samsung tech to properly align a new DMD bd. Engines cost hundreds moreand are available.
Jul 13, 2009 | Samsung HLN5065W 50" Rear Projection...
Samsung HLN5065W color wheel installation
Check the wire connections one may be loose or not properly seated
May 11, 2009 | Samsung HLN5065W 50" Rear Projection...
HOW TO REPLACE MY COLOR WHEEL
there is no color wheel. please explin your problemin detail. thanx Joe.
Dec 18, 2008 | Samsung HLN5065W 50" Rear Projection...
Samsung HLN5065W 50" Rear Projection HDTV-Ready Television Logo
106 people viewed this question
Jerry Greenberg
Jerry Greenberg
