Question about Kodak EasyShare C743 Digital Camera
Lens error 111.000 and 221.000
When I switch on the camera it brings up this error and then shuts off. any ideas what I can do? Thank you
  • makennedy Jan 03, 2009
    mine does the same, turns on and the screen has an error code 111,0,0,0 then it changes to 221,0,0,0 and then it shuts off. I do not want to try to open this but is that the only option?
Try opening your camera up and reconnecting the connections that goes from the lens to the main board. There should be two ribbon cables. One of them is kinda tricky to get.
Posted on Apr 17, 2008
    Champion:
  • 217 Answers
Defective mechanism, a stucked mechanism is present. camcorder are smart it can detects error and shuts down itself for safety. earlier models dominoes the defect if the user is not quick enough to react when something goes wrong with the camera. You need professional service to fix it.
Posted on Sep 30, 2007
6ya staff
SOURCE:
Jerking motion
Try switching of the camera. Remove the lens and check if al contacts are in good order (no dents), clean and shiny if they look good to you, replace the lens and switch on the camera. If the error returns, the best thing you can do is is late the error, by placing another lens. If you don't have on. take the camera to a camera store and ask there if you can try another lens.
Then when you are sure where the error is, bring that part to the Nikon service centre, Or when it is the lens, buy a new one. The standard lens (or even the 18 - 105mm) are not that expensive.
Success
Feb 09, 2014 | Nikon D3100 Digital Camera
Showing lens control error fuji finefix HS 30 exr
Does it say Lens control error, or does it say Focus error, turn off the camera and turn it on again?
The last can happen when you touch the lens barrel. When the lens does not retract when you shut down the camera, perhaps the battery is exhausted or the barrel got stuck.
Try to recharge the battery and start all over again. If nothing goes, try carefully to pull out the lens a little Less then one millimetre. or gently press it back a little. Be aware the camera is a very delicate piece of equipment, so don't use force, because that could damage the camera definitive.
In the manual, it says you should contact FujiFilm, when the error comes back after you switched off and on. So if nothing helps, that is the last option. Visit a repair shop from Fuji, or bring a visit to your dealer.
Dec 27, 2013 | FUJIFILM FinePix F300EXR Digital Camera
Water Damage Lens Error
Most cameras with retractable lenses are very sensitive to grit (sand, dirt, salt etc.) in the lens mechanics and will shut themselves off if everything is not perfect. It's possible some salty water remained in the works and left a salty residue when it dried out.
Unfortunately, most repair shops will charge you almost what the camera is worth to properly clean it and it is not a job for the do-it-yourselfer.
Apr 27, 2017 | Canon SD4000 IS IXUS 300 HS Digital Camera
My camera says lens error and the lens is not coming out
While your camera is switched on, remove the battery. Wait for at least 30 seconds and reinstall the battery (make sure it´s charged). Switch on the camera. The lens should open and pop out.
Mar 12, 2011 | Canon G12 Digital Camera
My camera its a A830 / it tells me it has a lens error what should i do thank you :) when i push the power butten it tells me it has a lens error and then shuts off
Usually it's sand or grit interfering with the lens extension mechanism. Or the camera's been dropped with the lens extended. Or the camera has been powered on, but the lens had been blocked preventing its extension. Or the battery ran down with the lens extended. If the camera is still under warranty, before trying any of these, please please first contact your camera's maker to see if they'll cover the repair, or to determine how much they'll charge for the repair. Who knows, you might get lucky. But if they quote you a number that's higher than the value of your camera, you may want to consider the following methods.
Place the camera flat on its back on a table, pointed at the ceiling. Press and hold the shutter button down, and at the same time press the power-on button. The idea is that the camera will try to auto focus while the lens is extending, hopefully seating the lens barrel guide pins in their slots. Blow compressed air in the gaps around the lens barrels with the idea of blowing out any sand or grit that may be in there jamming the lens. Other variations include blowing with a hair dryer in “no heat” setting, or sucking the gaps with a vacuum (careful with this one).
Thank you!
Aug 17, 2010 | GE A830 Digital Camera
I have a problem with my camera c633 . i ant't start it . it' show me this message LENS ERROR 20e,1,0,0 and than it shut dawn .???????
Hi, the problem was inside of the lens unit and maybe the lens gear was damage.this is cause impact or excessive force to the said parts.
Try to open the camera if you can and check the gear inside of the lens if damage or need to be allign only. But if you cant do this you need to do is bring to service center and rquest for the estimate charge before they proceed to repair.
thank you
Jul 17, 2010 | Kodak EasyShare C633 Digital Camera
I have kodak_easyshare_v610_digital_camera an...
hi, error #45 is the same with lens error and one of the lens unit is damage.your camera has two lens assy and the damage one is the lower part that always used. there'e only 2 possible way to work your camera 1.To adjust or clean the lens unit and the 2. To replace the whole assy.bring to service center and request first for estimate charge before you proceed to repair.
thank you
May 19, 2010 | Kodak EasyShare V610 Digital Camera
Lens error
This is probably THE most common failure among digital cameras.
There's a halfway chance of fixing it yourself, described here: http://camerarepair.blogspot.com/2007/12/fixing-lens-error-on-digital-camera.html
Feb 20, 2010 | Pentax Optio 60 Digital Camera
Error 2111 on camera VPC-S750
On my Casio Ddigital Camera the lens comes out when I press the open button but then it shows LENS ERROR and shuts down again.
Please advise what the problem could be.
Thank you.
Apr 03, 2008 | Cameras
Kodak EasyShare C743 Digital Camera Logo
66 people viewed this question
Top Kodak Cameras Experts
Ekse
Vitally Alcher
FIKRET UNALIR
FIKRET UNALIR
Level 1 Expert
Are you a Kodak Camera Expert? Answer questions, earn points and help others
