Kenmore Model 44052
Washer quit in middle of cycle. Followed steps to unclog water pump. There was a quarter in the drain hose. Washer still will not run. The start light on the panel flashes. What do I do now?
  • DebH Sep 27, 2007
    The problem was actually a faulty door latch sensor. It was not reading that it was closed and therefore would not advance to the next stage of the cycle.
  • Yoop Jun 07, 2008
    Machine had a clogged pump strainer which I cleaned. The machine then worked fine for a few weeks. Now washer will not complete wash cycle. Strainer basket is clean. Pump is working fine. The machine will complete a rinse and spin cycle, but will not complete a normal wash cycle.
    Thanks
Also remove the hose at the back of the washer. There is a restriction about 4 inches inside the hose that traps hairs and everything bigger than a toothpick.
Posted on May 12, 2008
  • 209 Answers
You are on the right line, check for blockages again, if all well then check the pump for open circuit electrically, if faulty replace and you should be alright, ensure the impeller (blade) in the pump is clear and will rotate hope this helps
Posted on Sep 27, 2007
Model 11026955690. Why does screen indicate LP?
I am not familiar with any error code referencing "LP". Could you be seeing "LF"?
Below are the error codes listed for your washer:
  • "LF" (Long Fill) Inlet hoses are kinked or clogged or water valve screens are not clear. (Solution: Straighten inlet hoses or clear screens of any foreign material.)
  • "LD" (Long Drain) Drain hose is kinked or clogged. (Solution: Straighten or unclog hose.)
  • "FF" (Fill Failure) Problem with water level sensing system. (Solution: Call for service.)
  • "OL" (Open Lid) Lid Is open during drain or spin. (Solution: Close lid.)
  • "PF" (Power Failure) Power to washer went off during cycle. (Solution: Press any pad to clear the display. Restart the washer from the beginning of the cycle.)
Source: Kenmore 11026955690 Manual
Aug 25, 2015 | Kenmore Washing Machines
My Kenmore Washer Dryer Combo stacked unit Model # 417.92702200 will not drain it has noise and runs thropugh the cycle then spins like it should just will not drain out water after its done wash cycle....
looks to me that you have eather coins, yes,coins traped in the electric water pump mostly a quarter blocking the inlet of pump or a piece or clothing from the hose that comes from the bottom of the OUTER TUB to the PUMP. if not you may have a faulty pump.
good luck to you.
Feb 07, 2011 | Kenmore 22422 Top Load Washer
My Kenmore Calypso Elite HD Top Loading washer quit cycling through a complete wash today. I've drained all the water from the interior hoses and found them clean and uncloged. The washer belt looks good...
skipneal,
The code on your machine stands for 'Long Drain'. Ld flashes if it takes longer than 5 minutes to pump out water to a point where the operating pressure switch resets. Check the intake and exit hoses of the recirc pump for debris. It's easiest to get to the pump through the front panel of the machine(click here). Looks like this: click here. the hoses to the pump have spring clips holding them on. Be careful taking the hoses off, have something to catch the water from the hoses.
Hope this helps.
-samson39
Jul 20, 2009 | Whirlpool Calypso GVW9959K Top Load Washer
Kenmore elite washer problem
you can use a shop wet vac on the drain hose to **** the rest of the water out then you can remove the hoses to check to see if anything is suct in hoses or pump-,mike
Apr 24, 2009 | Kenmore Elite Oasis 27052 Top Load Washer
Flashing code
The following link explains the "FH" error code:
http://www.fixya.com/support/r615354-fh_error_code_whirlpool_duet_kenmore
This is one of the more involved error codes to try to resolve because there are so many causes. I suggest you start with the simple things first. Make sure the water inlet hoses are unclogged and water flows freely through them. You can determine this by turning off the water and removing each hose from the back of the washer. Place them in a bucket or position the washer where you can place them inside the wash tub and turn the water back on. Both hoses should have free unobstructed water flow. It is common for the sediment screens at the end of the hoses to become clogged if you live in an area the uses well water, or if you have hard water.
Next, Make sure you don't have a siphoning problem. This is causes by placing the drain hose too far down in the standpipe. This creates a vacuum and the washer constantly drains as it tries to fill. If you pull up on the drain hose and hear a sucking noise, you have the drain line positioned too far in the standpipe. You need to keep an air gap in order to allow proper drainage.
Then, check the drain pump for obstructions. There is a clean out reservoir that you can remove the access the pump interior. Use the instructions I provide to perform these steps.
These are the simple items that you can easily rule out, first. Follow the remaining tips I provided you and if you still have questions, let me know before rating the solution. I hope this helps you.
Feb 24, 2009 | Kenmore Elite 45986 Front Load Washer
Kenmore Calypso washer Ld code?
I just had the same problem. I borrowed my neighbors wet vac. The hose of the wet vac fit right over the end of the drain hose and I sucked out all the remaining water. My hope was that if the hose was clogged that it would clear it out. It seems that it worked. I put the drain hose back in the drain and turned on the extended spin cycle. It was working, so I put the water logged clothes back in the washer on the extended spin cycle and it took the water out. I am now in the process of washing another load to see if it really fixed the problem. I hope this helps.
Jan 18, 2009 | Whirlpool Calypso GVW9959K Top Load Washer
Kenmore m#44052 front load washer
If you have no known issues with your plumbing, it sounds like you either have a failed drain pump, or something obstructing the pump, preventing it from draining. As long as the wash tub is still full of water, the unit will not proceed to a spin cycle. I would recommend you check the drain pump first. The following link explains how:
http://www.fixya.com/support/r385844-checking_drain_pump_kenmore_elite_front
Make sure you also check all the drain hoses for clogs as well. In particular, the hose that runs from the bottom of the wash tub to the inlet side of the drain pump. Small articles of clothing have been known to find their way into this area. NOTE: Using a wet/dry shop vac will go along way towards assisting you with emptying the washer of all water and minimizing the mess associated with cleaning out the drain pump.
If you clean out the pump and the unit still does not drain properly, the manufacturer recommends replacing the drain pump. The next link explains how:
http://www.fixya.com/support/r401841-replacing_kenmore_elite_water_pump
Normally, a drainage issue is also associated with an error code of either "F02" or "F21, depending on model. Does your washer also show any error codes on the front panel? Now...with that said, the absence of an error code does not necessarily mean you do not have a failed component. For some reason, sometimes an error does not always get generated.
I hope this helps you. Let me know if you have further questions, or still need assistance.
Jan 16, 2009 | Kenmore Elite 45986 Front Load Washer
HOW DO I GET TO THE PUMP TO UNCLOG IT
take cabinet off and the pump is right there in the front of the motor.remove the top hose and the water will finish draining on the floor.reach in and you should be able to take out the obstruction.
Dec 01, 2008 | Whirlpool Ultimate Care II LSQ9549L Top...
Kenmore Elite Front Load Washer...F02 and SUD not draining!!!!
Probably something caught in pump. Remove lower panel if this one has it and you will see the pump. Loosen the round cover in middle to access clean-out.
Nov 08, 2007 | Kenmore 46462 Front Load Washer
Washing Machines Logo
655 people viewed this question
Top Washing Machines Experts
