Question about E-Machines M2350 Notebook
Were is the infrared port i have a pockect computr that uses infrered to get cconeted with this one i look and look and can find the infrared eye
  • 167 Answers
Http://downloads.emachines.com/userguides/M2xxx_M6xxx_notebook_UG_Online_030804_en.pdf this the manual, for that model. i searched it and found no results for infrared port. if it does have one, it would look like a dark red plastic cover, like on a remote from a tv. on some i have seen them next to or near keyboard. i hope this helps you. ok... after reading the manual and looking at the specs, it seems it does not have one. there is an answer, i looked for, and found a usb infrared usb dongle. please rate this solution. and if you need further help, reply...look at comment
Posted on Apr 22, 2009
I have a modem arris cm450b, i bought splitter to use 2 cables but the the cable connected to my sons computr isn't working
That is not the right way to do it. Connect one computer to the cable modem using an USB A/B cable from the USB port on the modem to an available USB port on the computer and connect the second computer to the modem Ethernet port-to-Ethernet port using an Ethernet cable (probably the modem came with one Ethernet cable).
Hope this helps.
Oct 14, 2014 | Arris Touchstone 450a (CM450) Modem
I can't get my Infrared port to work. What do I need to do?
infrared option shuold be in control panel you will find infraport sideways of pocket pc first try to connect a infra enable mobile device then check it.
Dec 09, 2007 | Acer n30 Pocket PC
Wii wireless sensor bars not lighting up
They aren't supposed to light up. The sensor bar uses infrared light similar to that of a remote control. Infrared is invisible to the human eye. If you've seen videos of it lit up online, it is because some cameras can detect infrared (so they can use night vision).
Jan 11, 2014 | Nintendo Wii Console
How to use infrared port in sony ericssion k220i . what is main use of infrared port. what can i do using this facility?
The infrared port is by the left side of the phone, it is along the line that splits the front and the back of the phone. It is mostly covered by a thick red glass or plastic.
Infrared is a device on a phone that allows you to send and receive file using the infrared radiation wireless wave. It works like a bluetooth device, just that it must be placed close to the infrared port of the phone that is sending or receiving files from. You cannot send or receive files that does not have infrared using your own infrared.
Infrared can be used to send and receive files (data, song, pictures, videos etc).
To use the infrared of the sony ericsson K220i, you have to go to your phone 'menu', go to the 'settings', select the 'connectivity', then you select the 'infrared', turn it 'on', when you are to receive a file, you place your phone close to the sending devices infrared port. Also when receiving a file, you do the same.
When you want to send a file through infrared, you go to the file you want to send, you select the option, select send from the option, a pop up blog will come up asking you how you want to send the file, you select via infrared and your infrared will come on, the device you are sending it to would have its infrared turned on as well. The infrared ports must be placed close to themselves before the files can be sent.
Take care
Jun 25, 2010 | Sony Ericsson Cell Phones
I don't know how enable infrared port in my pc - ibm thinkpad x 41
By default, currently available ThinkPads come with the external serial port disabled and Infrared enabled on COM1. To use the serial port on COM1 you must either disable infrared or change infrared so that it uses alternate resources. If you are not using infrared for printing or file sharing it is recommended that it be disabled. Here are the steps to follow to enable infrared :
1. Double-click your ThinkPad Features or ThinkPad Configuration icon located in the ThinkPad folder on your desktop.
2. Locate the Infrared button located on the left-hand side of this configuration screen and click it once. (Note: If you hold your mouse pointer over any of the icons in this configuration screen the button will be identified at the bottom in the status window.)
3. Change Infrared from "Disable" to "Enable" and click "OK".
4. Locate the serial port icon and click it once.
5. Select serial port "enable" and insure that the COM PORT setting is "COM 1" and click "OK".
6. Shut down and restart the computer.
Jan 19, 2010 | IBM ThinkPad X41 Notebook
My dell D505 turned itself and will not turn back on power light flashes but thats it power supply is fine
  1. Locate Fast IR under Onboard Devices.
NOTE: Ensure that the COM port that you select is different from the COM port assigned to the serial connector.
  1. Press <Enter>.
  2. Use the arrow keys to select the infrared COM port setting.
  3. Press <Enter>.
  4. Follow the instructions on the screen.
After you enable the infrared sensor, you can use it to establish a link to an infrared device. To set up and use an infrared device, see the infrared device documentation and the Windows XP Help and Support Center
http://support.dell.com/support/edocs/systems/latd620/en/UG/setup.htm#wp1112328
Dec 26, 2009 | Dell Latitude D505 Notebook
CAN A JVC CABLE EYE CONNECT TO COMPUTER
i dont know how to connect my eye toy to coputer
Feb 25, 2008 | Computers & Internet
E-Machines M2350 Notebook Logo
114 people viewed this question
Top E-Machines Computers & Internet Experts
Matthew Spark
Matthew Spark
Are you an E-Machines Computer and Internet Expert? Answer questions, earn points and help others
