Question about Epson Stylus CX9400 Photo Printer
I cannot find a waste ink reset program for Mac. How do I reset?
  • 1 more comment
  •  Robert Allocca
    Robert Allocca Apr 23, 2009
    Thanks for the reply. I discovered there isn't any reset program for Mac. I purchased a Ink waste container, disconnected the tube going to the waste ink pad and connected the IWC. It automatically feeds the waste ink. I'm saving a ton of money with my CISS and Waste Container systems.
  •  Robert Allocca
    I bypassed the internal container/pads and now use an external waste container that I just empty when it's full. Best $10 investment I've made in a long time.
  •  Robert Allocca
    Robert Allocca Jun 23, 2009
    The original question was referring to a Mac program relating to the Mac. Waste Ink Container does not get replaced, it gets emptied, rinsed and reconnected. Do not use the ink from the WIC.
3 Suggested Answers
  • 2678 Answers
SOURCE: epson 1280 on mac: I need to replace the ink waste
Still locked out until the counters are reset.
Posted on Dec 02, 2010
SOURCE: epson stylus color 3000 Waste Ink Reset program
For primary solution you can see http://www.wasteinkpads.com/?gclid=CNSizPWb_bICFVEX6wodkScAcw. If your problem don't get resolved you can visit us for epson printer support at http://www.pcasta.com/support-for-epson-printer/
Posted on Oct 13, 2012
My epson WF 840 has had counter reset, and waste ink pds changedbut, message reads, printers ink pads at end of life, switch off printer
Google epson waste ink pad resetter.this is a small program from china.you may be in luck and be able to reset the counter.download program run it, select printer from drop down menu.right click icon, reset waste ink pad.switch off printer restart.you may need to do this again.this program also resets cartridges before they become empty so you can get more out of them.
Nov 27, 2014 | Epson Workforce 840 Wireless Inkjet...
Waste ink goes to external tank but I need to set the counter. On a CIS system which has been reset
The free SSC utility which will reset the waste ink pad protection counter in most Epson inkjet printers can be downloaded from
http://www.ssclg.com/epsone.shtml. Remember though, if you don't change the ink pads, there will be an increasing danger of ink leakage from your printer, particularly if you tip it up for any reason - VERY messy, and it can clog up your printer mechanisms.
Jan 01, 2011 | Epson Stylus Photo 1400 Printer
Canon 130 printer ink absorber is full. need advice to fix.
Hi, is it canon 130 or canon 1300, if it is canon 1300 you can try to fix it using a manual reset and software reset. You can visit my blog here for free reseter and tutorial:
http://feedproxy.google.com/~r/Inkq-mac/~3/eJkvGfLlL1U/how-to-reset-canon-pixma-ip-series.html
To know why "waste ink absorber is full" message appear, you can visit it here:
http://feedproxy.google.com/~r/Inkq-mac/~3/0DgDreiMUw8/waste-ink-absorber-is-full.html
If the reseter won't help you please let me know. Hope this help.
Dec 22, 2009 | Canon Office Equipment & Supplies
Where is the waste ink
You're probably referring to the Waste Ink Tank in a Canon printer. If you've received the Waste Ink Tank nearly full message, there's a workaround.
The waste ink absorber is actually a pad/sponge that absorbs left over ink spray. There's really no precise way to measure the amount of ink these pads hold so when the message first appears, "waste ink absorber is almost full" it's just an estimate.
The workaround for the message is as follows:
Reset ip2000 / 3000
1. Turn off printer
2. Hold down Resume button and press Power button.
3. Keep holding down Power button and let Resume button go.
4. Press Resume button 2 times then let BOTH buttons go.
5. Green lights will flash and then stop blinking.
6. When green lights are solid, press the Resume button 4 times.
7. Press the Power button and the printer should turn off, if not,
press the Power button once more.
8. Your printer should respond as normal.
Using the above procedure should clear the message and your printer should function normally afterward. Best of luck and thanks for using Fixya!
Greg
Nov 26, 2009 | Office Equipment & Supplies
Epson R320 Service required message
Reset waste ink counter using SSC ver. 4.30. You can find at indoreset.blogspot.com. Don't forget to replace waste ink pad, washing or extend outlet pipe from head cleaning mechanic to outside of printer.
Jul 23, 2009 | Epson Stylus Photo R320 InkJet Printer
I have a problem with my printer epson stylus C90. may i know what todo when parts of my printer are near the end of their life service.?how can i fix it?
It means waste ink pad full or nearly full. Reset waste ink counter using SSC ver 4.30. Find at indoreset.blogspot.com. Don' forget to replace pad, washing or extend outlite pipe to outside of printer.
Jul 23, 2009 | Epson Office Equipment & Supplies
MY PRINTER IS TELLING THAT PARTS IN MY EPSON R220 NEEDS SERVICE
download .epson reset for printer,google will reset counters
Jul 05, 2009 | Epson Stylus Photo R220 InkJet Printer
Printer won't printer as message says parts are
Part are end life cycle : waste ink pad full. Need to reset waste ink counter. SSc ver 4.3 support RX 620 and 640. U can try using printer model RX 640. Menu Protection Counter, Show current value for checking. Reset protection counter. Or Try to find RX630 adjusment at indoreset,blogspot.com. Don't forget to replace or wash the pad. Or extend outlet waste ink pipe to outside.
Jun 28, 2009 | Epson RX620 All-In-One InkJet Photo...
Ny epsom r360 reads ink pads saturated
don't replace the ink pads install a external waste ink tank instead, then reset the printer using reset program . . search on eBay for epson waste ink tank it incudes the reset program.
Jun 07, 2009 | Epson Stylus Photo R320 InkJet Printer
Epson Stylus CX9400 Photo Printer Logo
110 people viewed this question
Top Epson Office Equipment & Supplies Experts
Alun Cox
Are you an Epson Office Equipment and Supply Expert? Answer questions, earn points and help others
