Question about HP LaserJet 4 plus Printer
I want to reset my printer defaults and don't remember which buttons to push
My HP Laserjet 4P stopped printing and I want to reset it back to its default settings I remember you hold down two buttons on the front for 30 seconds but which ones Grace from Seattle
  • 393 Answers
Power the printer on, and press and hold the "Online" button to revert back to factory settings
Posted on Apr 23, 2009
How to cold reset in HP LaserJet 1536 dnf mfp
Resetting the HP LaserJet Pro M1536dnf accomplishes the following:
  • Clears all data from the printer's memory (including unprinted data, downloaded fonts, and macros).
  • Stops any printing that is taking place and ejects the page.
  • Removes some error conditions.
  • Resets the printer to its factory default settings.
Reset Procedure:
  • Turn off the printer
  • Press and hold the Left arrow & Cancel while you turn on the printer
  • Once you see Permanent Storage Init you can release the buttons.
  • The printer should now start resetting.
Thanks,
HP Printer Support
Jun 10, 2014 | HP LaserJet M4345 MultiFunction Printer
Reset hp 1515n
? Restore defaults-used to reset all customer-accessible menu settings back to the factory default
settings (except language) via the control panel or software
NOTE: This service menu item does not reset factory-settable settings, including formatter
number, page counts, factory paper settings, language, and so on.
NOTE: Before restoring defaults, print a menu structure report and a configuration page. Use the
information on these pages to reset customer-specific settings.
CAUTION: All HP Jetdirect settings are also reset. Be sure to print a configuration page before
restoring defaults. Make note of the IP address that is listed on the Jetdirect configuration page. You might need to restore the IP address after performing a cold reset.
Restore the factory-set defaults on the (HP Color LaserJet CP1510 Series Printer
1. Press OK to open the menus.
2. Use the Left arrow or the Right arrow button to select Service, and then press OK (Select).
3. Use the Left arrow or the Right arrow button to select Restore defaults, and then press OK.
The product automatically restarts.
Jul 13, 2011 | HP LaserJet CP1515n Printer
Just got a new computer. Have an old HP Laserjet
you have to refer to usb/ parallel converter manual, not printer manual
Apr 07, 2010 | HP LaserJet 4p Printer
Printer will only print one copy when when multiple copy number is entered. HP Laserjet 4200 printer
The best way I have found to remedy this type of issue is to reset the printer to factory settings. Push the check mark button (green) and scroll down to the resets and restore to factory settings. This will reset everything and you can start over. Also on the computer you are printing from there are default settings under the printing preferences that should be set to default printer settings. You can try one or the other but I usually do both because it saves time in the long run.
Mar 10, 2010 | HP LaserJet 4200 Printer
Need help fixing a HP Laserjet 4P printer. Makes
Check this link for printer parts:
http://www.printersupplies.com
Feb 25, 2010 | Office Equipment & Supplies
I have a HP Laserjet 4P that had been used on my company laptop and home computer. When I upgraded top a new Dell Vostro 420 running Windows Vista Business and moved the printers over to this unit the...
You don't write how exactly is your printer connected - if I remember correctly, HP LJ 4P doesn't have a USB connector, and Vostro doesn't have the parallel port available.
So how did you connect it? Is it via some USB to parallel adaptor, or via JetDirect network card in the printer? There are multiple separate issues that may be applicable in either case...
Dec 30, 2009 | Office Equipment & Supplies
I have a HP laserjet 4P. The print was coming out
You need to replace your transfer roller. Might as well do a complete maintenance kit.(Rollers, Fuser and Transfer Roller)
Nov 08, 2009 | HP LaserJet 4p Printer
After turning on printer, prints initial "blank" sheet
You can fix this by turning off bidirectional support:
- Right click your printer, select properties
- go to the ports tab, uncheck Enable bidirectional support.
Your printer has to be turned on before printing.
That fixed the extra page printing S1M problem for me.
Oct 11, 2009 | HP LaserJet 4 plus Printer
HPLaserjet4P - printer service 50 -
A 50 Service error is a fuser error. Turn the printer off for 5 to 10 minutes, then turn it back on. If the error is still there, I think your going to need to make a service call you can try reseating the fuser, but be sure to let the fuser cool completely before touching it.
Good Luck the HP Laserjet 4p is a great printer.
Jan 28, 2009 | HP LaserJet 4 plus Printer
HP Laser Jet 4p printer problem - will not print continuously
Go to the printer setting's and make sure that the printer paper feed are not set into a Manual feed.
Thanks,
Feb 27, 2008 | HP LaserJet 4p Printer
HP LaserJet 4 plus Printer Logo
140 people viewed this question
Seeker5211
Seeker5211
