Question about Hitachi 50V500 50 in. HD-Ready LCD Television
Hundreds of tiny scratches on the INSIDE of the screen
Looks like a shattered windsheild on the inside of the screen set is 4-5 years old.
  • Hitachi Master
  • 3,866 Answers
Replace the screen protector. you can find parts on ebay.com for this solution.
Posted on Apr 22, 2009
After turning water on to 10 year old grohe shower faucet pressure rapidly drops to nearly nothing
If you spin the shower head off there should be a metal screen inside. If it is clear, Soak the shower head in CLR for about 4 hours. After 10 years even the best water supply will leave behind a build up that can plug the tiny holes.
Feb 24, 2011 | Grohe Grohmix Thermostat Valve & Trim -...
My son smacked the Tv with a telephone. It looks like the inside of the screen is shattered. Can I replace it?
If it is an older projection tv style= Yes... If it is the newer flat screen such as an LCD then = NO --It is scrap. The display is as much as a new set.
Nov 27, 2010 | RCA Televison & Video
Our 4 year old hit the front of our LN -T4061F Samsung set with a plastic ball. It now has a shattered imprint that is black with white shatter marks and ranbow stripes...any chance the repair is less...
Sadly, the screen is the most expensive part of the TV. The replacement screen would cost more than the TV is worth. Shopjimmy.com is the only affordable place to buy the replacement screen, But, they are out of stock. Usually, the screen cost around $250 to $350. Any other website will cost an arm and a leg. Buying a new TV would be best at this point.
http://www.shopjimmy.com/catalogsearch/result/?q=LN+-T4061F+screen
Nov 16, 2009 | Samsung LN-T4061F 40 in. LCD HDTV
Sony bravia tv screen broken
you might can find a tv repair person that needs the parts or has one with a good screen but bad electronics....sorry you need a new tv.....
Sep 20, 2009 | Sharp Aquos LC-42D62U 42 in. LCD HDTV
MY 3 YEAR OLD DAUGHTER HAS JUST SCRATCHED MY SONY BRAVIA TV WITH A MAGNA DOODLE PEN. HOW CAN I GET RID OF THE SCRATCHES?
Clean the surface of the LCD screen with a barely damp cloth.
  • Step 2 Dry the screen with a soft, clean cloth.
  • Step 3 Rub a generous amount of petroleum jelly into the scratch using a cotton swab. The petroleum jelly should fill in the scratch and remain there.
  • Step 4 Immediately wipe the excess petroleum jelly off of the screen with a soft cloth being careful to leave some petroleum jelly inside the scratch to act as a patch or filler.
  • This scratch repair method is effective because of optical density. The optical density of petroleum jelly matches the plastic, LCD screen coating more closely than that of air.
  • To avoid future scratches or gouges, you might consider purchasing a LCD screen protector. These screen protectors are generally made of a thin, plastic film and affix to the screen without adhesives. Not only can they protect against scratches, but they also keep the screen free of dirt, oil and dust while simultaneously reducing glare.
  • When wiping the screen as described Step 4, avoid pressing too hard or you will inadvertently remove the petroleum jelly from inside the scratch.
  • Using petroleum jelly to fill a scratch on your LCD screen could void your screen's warranty. If you are concerned about warranty issues, consult your user's manual for more information.
  • Sep 16, 2009 | Sony BRAVIA KDL-32S2000 32 in. LCD HDTV
    I have a 5 year old RCA 61LPW42 HD DLP television. A few months ago a small dark shadow appeared in the upper left corner of the screen. Over time it has creeped down and become larger. Still starting...
    It's the light tunnel. The tunnel is a square tube made up of 4 mirrors glued together.
    It looks like this from the side: |_| (with a piece on top too.)
    When the glue breaks down, it shifts inside the little mirror holder. The shifted mirrors looks like this /_/ what you are seeing is the shadow of the tilted mirror tunnel.
    ON the RCA's there's not a good fix.
    RCA's response:
    "Ok, well sadly they do not offer the light tunnel anymore, which is what you need. Sadly you would be rendered to get a whole new light engine assembly. That would be the D.N.D module, light tunnel,color wheel,optic spanner, and oci. mirror. Your best bet would be to search ebay for a broken engine and replace it that ways."
    That is the ONLY response I got from them.
    I took the set apart and found the 4 tiny mirrors. I will be attempting to epoxy them together. (The set is dead anyway, why not try?)
    Apr 04, 2009 | RCA HD61LPW42 61" Rear Projection HDTV
    T.V Screen
    Check with an auto parts store they sell items to repair cracked windsheilds.
    Jul 01, 2008 | Computers & Internet
    LCD Sanyo screen looks shattered
    The inner glass plate inside the screen is broken. The glass inside of these is very thin. I think it is only a few millimeters thick at the most.
    The complete screen must be replaced to fix the fault. It will probably be cheaper for you to buy a new monitor rather than replace the screen!
    Jerry G.
    Jun 02, 2008 | LG 42LC2D 42 in. LCD HDTV
    Yellow splotches inside screen?
    Hi. I would need more info, it sound like you have damage the screen's, at this point no warranty would cover it, you can try. The problem is the voltages between screen's acking causing the smear on your screen. If it is a rear projector lcd then it is the engine, or obto some call's it.
    I hope this helps
    Jan 10, 2008 | Televison & Video
    Hitachi 50V500 50 in. HD-Ready LCD Television Logo
    55 people viewed this question
    Top Hitachi Televison & Video Experts
    Jaime Hernandez
    matt martin
    matt martin
    Are you a Hitachi Televison and Video Expert? Answer questions, earn points and help others
