Question about Cycling
I cant findt enough info on the KHE K-Pro BMX pedals.
I am looking at buying the KHE K-Pro BMX pedals. I think it is in alloy, but I can not fint the weight of them any where. Can you help me to a recource? Thanks a lot. Lars
  • unicyclist Apr 22, 2009
    Sorry about the Jag category. I was searching for some bike help, and this site did sound promissing, but when I entered I could only choose either a car problem or a watch problem. A Jag is closer to my unicycle than a watch.
    President:
  • 1,138 Answers
They come in aluminum(cheaper) and Magnesium which is lighter. I don't have the weights yet but will try to find out. They both have 9/16" axles. The graphite Stimulatorz might be a better choice at $16.99.
Posted on Apr 25, 2009
I have 6 Dyno's...I have no idea what year they are...Can you help me?
Just Google "dyno bmx serial number" or "dyno bmx info". Nobody can give you the info you want without doing exactly the same thing. If you post pics on a BMX forum someone may be able to help.
I’m happy to help further over the phone at https://www.6ya.com/expert/donald_f2ed37026a3ac881
Apr 09, 2018 | Dyno Old School Gt Number Plate Old...
Purchased bike. stickersays bmx pro 1974 trying to use serial # to see if this is really a bmx pro 1974
As far as I know "BMX Pro" is not a brand/model. Whatever the brand is, the serial number is often not useful. Contact the manufacturer (name on the head tube where the fork goes through the frame.
Mar 18, 2017 | USE Cycling
I need to replace the right pedal on a Mongoose GMX ladies bicycle which has been chewed off by a dog. I need to buy the pedal and also would like to get an owners/instruction manual as the used bike was...
I tried to find the user manual online but I can get one, I would suggest to visit your manufacturer's website for you to get one.
For replacing a pedal, you just need some tools like open grinch depending on the size of your pedal.
Thanks.
Sep 23, 2011 | Cycling
My new moongoose mischief keeps getting loose chain and pedals, ive tightend it up sevral times but keeps doing it, and the pedals keep loosening from the body??? anyone know how to solve this/
My first thought about the chain continuuin to become loose, is that you need to loosen the nuts on the back wheel, and pull the wheel (while the chain is still attached to bot hsprockets) in order to remove any slack. If it's a continuous issue, chances are that back tire keeps migrating forward because those nuts aren't tight enough.
To the pedal issue-If the pedals are wobbling or vibrating because the aren't snug while on the pedal bar (the bar that the pedals revolve around) it is probably because the peddals are too large. Try buying a new set of pedals. If they are loose and trying to slip off of the pedal bar and if you have tightened the nuts that keep the pedal on the pedal bar and they are continuing to become loose, it could be that you need to use locking nuts.
A quick fix to solving loose pedals is to add washers to the end of the bar until the washers are flush up against the pedal and the nut.
Happy pedaling!
Mar 23, 2011 | Mongoose Mischief Mag BMX Bike
What is the size of the thread of a standard bike pedal?
There are 2 standard sizes:
Standard one-piece cranks 1/2" x 20 tpi
Standard 3-piece cranks 9/16" x 20 tpi.
The Right Pedal (gear side) has a normal thread, the Left has a reverse thread.
Dec 21, 2010 | Huffy Pro Thunder Boys 16-Inch BMX Bike
Pedals move freely
If the pedal is moving too free,but the bike are still moiving forward, it simply mean you are using to low a gear .
Try changing to a high enough gear to satisfy your required tension. Be advised that,
You will also increase your speed,and decrease your hill climbing in the process though.
Jan 30, 2010 | Mountain Pedal Alloy Universal, ...
Well when i try ride my bike the pedals go round but i dont move
You will have to have the rear gear replaced. What has happened is the inside of the gear has broken and it now freewheels when you pedalling. It should only freewheel when you are backpedalling. Have a look in this website:http://www.parktool.com/repair/readhowto.asp?id=48
Oct 20, 2009 | GT Bicycles GT Pro 20" Freestyle BMX Bike
I have a kitchen pro breadmaker #k6725 and cant fint the manual/instruction booklet
You can access a PDF copy of the breadmaker booklet for the Regal Ware model K6725 by following this link:
http://www.regalware.com/documents/Breadmaker_Books/K6725_3rd_setting_sweet_Breadmaker_Guide_Cookbook.PDF
Pat Seitz
Director, Communications
Regal Ware, Inc.
Sep 14, 2009 | Regal Ware K6725 Kitchen Pro Bread Maker
Weird noise on my bmx bike
It sounds like you have cracked or broken one or both sealed cartridge bearings if thats what your bike has. If it has ball bearings in races they might be broken. Try loosening your rear wheel enough to take the chain off and then turn your crank. See if theres a funny noise or if it feels a little weird when its turning. If you broke a pedal bearing you should be able to tell just by carefully turning each pedal with your fingers and seeing what it feels like. In any case unless you have the tools to repair it you will have to take it in and get it repaired.
Mar 26, 2009 | Mongoose 20-Inch Gravity Games BMX...
Cycling Logo
79 people viewed this question
Top Cycling Experts
Michial Gueffroy
Andrew Taylor
Andrew Taylor
Are you a Cycling Expert? Answer questions, earn points and help others
