Question about Casio FX-9750GPlus Calculator
5 number summaries and casio 9750 plus
I just got this calculater for a statistics class. We are calculating sets of numbers to obtain 5 number summaries that show Q1, Q3 mode etc. My problem is that I was able to get my first set of numbers to calculate but after that I do everything the book says and get nothing. I tried erasing the memory thinking that might have something to do with this but that did not help. Any suggestions
SOURCE: Changing the % tax setting on my Casio calculator
step 1 pess the AC button step 2 press and hold for two seconds the % button step 3 press the tax+ button step 4 input 17­.5 step 5 press the % button that should be the tax set you can check it is set correctly by pressing the AC button and then the tax+ and 17.5 should be displayed
Posted on Apr 12, 2007
  • 374 Answers
SOURCE: Standard Deviations
This calc will do standard deviations. In the manual it is on page 2 and also on page 40.
Posted on Jul 17, 2007
Chintu-KPV
  • 202 Answers
SOURCE: casio fx-82ES scientific calculator
change the mode to stat and then start operating it in statistical mode
Posted on Feb 26, 2008
SOURCE: Mean and standard deviation
Mode - 2 - STAT - 1(VAR) Then put your data: 25,34,13
Then press AC which is the clear button and then SHIFT - 1(STAT) - 5(VAR) 2 (X) =
Voila!
Posted on Sep 04, 2008
SOURCE: I need to find the antilog to -6.80 on a casioi fx-300ms calculat
Alot of people have this doubt, so I might as well make it clear.
Press the 10^x button (while pressing SHIFT, of course; it's exactly above the LOG button) followed by the number whose antilog you desire.
Example :
Let's say we need antilog(-6.8),
1. Press SHIFT, followed by LOG (i.e 10^x); this'll display a 10 on the screen;
2. Type in -6.8;
3. Press "=";
4. This'll display 1.584893192x10^-7 as the solution, which is correct!
5. Bye, lol :P
Posted on Apr 09, 2009
Hi,how can I calculate median using fx-570es plus?
The median is the number is the middle.
Using the calculator, you can follow the Statistical Calculations (Stat) on pages 22 and 23 of the attached manual. http://support.casio.com/pdf/004/fx-570_991ES_PLUS_E.pdf
However, it might be quicker to just put the numbers is order from lowest to highest and pick out the number in the middle.
For example, take the numbers 3, 5, 4, 7, 6, 4, 9.
Putting them in order, we get 3, 4, 4, 5, 6, 7, 9
There are 7 numbers so we want the 4th number (3 numbers to the right and 3 numbers to the left). In this case, the 4th number is 5 and that is our median, as half the numbers are lower than it and half the numbers are higher than it. It the number of numbers is even, you take the average of the two middle numbers.
Good luck,
Paul
May 16, 2016 | Casio Fx-570es Scientific Calculator
How can I reset my Casio FX-115 ES calculator to its default settings
There must be an error in what you report. You pressed MODE then 4: Base-N and now your calculator is in base-N calculation mode (the DEC, Hex, BIN, OCT) numeration keys are active.
To do statistics you must put the calculator in STATS mode.
Press MODE: You have 6 computational modes to choose from
1: COMP, the general computational mode
2:CMPLX, for calculation s with complex numbers,
3: STAT for statistics,
4: Base-N, binary, octal, decimal, and hexadecimal numeration
5: Equation, solving mode, etc..
For statistics, choose 3:STAT
Apr 24, 2012 | Casio FX-115ES Scientific Calculator
Can you please help me on how to calculate mean, median, mode, standard deviation calculation on casio fx-991ms scientific calculator
This will show you how to do statistics (calculate average, standard deviation, regressions etc.) as to the mode and median refer to the definitions.
TO COMPUTE STANDARD DEVIATION AND 2-VAR STATISTICS.
I assume you know the theory. I will show you the key strokes
For 1-Var statistics
Press [MODE][3:STAT] [1:1-VAR]. You are ready to enter values in the X column.
Enter a number and press [=]. Cursor jumps to second number to enter.
Keep entering numbers and pressing [=] till all numbers are in. Press the [=] key after the last one.
Press [AC] key to clear the screen.
Press [SHIFT] [STAT] (above digit 1.) then [5:Var]. Screen displays the statistical variables 1:n ;2: x bar; 3: x sigma n; 4:x sigma n-1.
Press the number corresponding to the statistical value you want, ex 1:n . The variable appears on screen. Press [=] and it will be displayed.
To display another variable press [SHIFT][STAT][5:Var][ 1,2, 3, or 4] .
To access the sum of squares sigma x^2 and the sum of data sigma x press[SHIFT][STAT][4:SUM] then [1: for sigma x^2] or [2: for sigma x]. Press [SHIFT][STAT][6:MinMax] to access minX and maxX.
For 2-var statistics
To perform 2 variable statistics you press [MODE][3:STAT] and any of the other regression options (except 1:1-Var). A two column template opens where you enter the X and Y values. When finished entering data, press [SHIFT][STAT][5:Var]. to access the different statistics. As I assumed above, you should be able to recognize what each variable means.
Apr 19, 2011 | Casio FX-115ES Scientific Calculator
How to find the "!" button on Casio fx-9750 PLUS?
  • In RUN screen enter the number
  • Press OPTN
  • Then press F6> to go to next page pf TABs
  • Press F3:PROB
  • Press F1:x! and EXE
Mar 26, 2011 | Casio FX-9750GPlus Calculator
How to calculate standard deviation in casio fx 115es
Nov 12, 2010 | Casio FX-115ES Scientific Calculator
How to solve for a factorial problem on a casio fx-9750g plus or buttons to press to get the ! how to solve for a combinations problems on a casio fx-9750 plus
There is no button but a menu tab.
In Run screen, enter the number whose factorial you want to calculate ( number can be at most equal to 69), press [OPTN][F6] to get to next page of menus.
For factorials
  • Press then [F3](PROB) then [F1] (x!) followed by [EXE].
For combinations
  • Press then [F3](PROB) then[F3][nCr][EXE]
For permutations
  • Press then [F3](PROB) then[F2][nPr][EXE]
Oct 01, 2010 | Casio FX-9750GPlus Calculator
How to sum series
Click on the Mode button twice until you see “SD”. Select 1. This puts the calculator in Statistics Mode. image001.gif Enter the first number, 1.
image001.gif Hit the M+. (n= 1 will appear in the window)
image001.gif Enter the second number, 1.
image001.gif Hit the M+ key. (n=2 will appear in the window)
image001.gif . . . . .
image001.gif Enter the last number, 7.
image001.gif Hit the M+ key. (n=7 will appear in the window)
image001.gif Hit shift, 2. (This invokes the S-Var option.)
image001.gif Hit 1 for the sample mean. Hit Enter.
image001.gif Hit 3 for the sample standard deviation that we will use in class. Hit Enter. here you can also ffind the sum of all numbers
Jan 21, 2009 | Casio FX-300MS Calculator
Standard deviation
standard deviation
calculate mean of a data set:
1. Turn calc. on or press MODE SeTUP
2.Press 3 for STAT
3. Press 1 for VAR
4.Enter values for X column
5. WHen done entering press SHIFT 1
6.Press 5
7.Press 2 to calculate the mean
8.Press =
Oct 05, 2008 | Casio FX-115ES Scientific Calculator
Casio 9850
Definitely not by asking in a forum. You could get a walkthrough, but that's not solving the problem.
This one is down to reading the calculator manual and your textbook a bit, then satisfying yourself that your answer and the definitions for those types of average are in accord. Mode is clearly an oddball which would make more sense with more context, but for now just pick the most common number, which is a set: (7, 10, 11).
That sounded better than 'toss-up between 7, 10 and 11,' did it not?
Dec 03, 2007 | Casio CFX 9850GA Plus Calculator
Statistics
Random number generators on computers are not really random. They need to be "seeded". If you seed the random number generator with the same seed each time you will generate the same list of numbers. A common technique in computer programming is to seed the random number generator with a value like the number of seconds that has occurred since midnight. This gives you the illusion of real random numbers.
Look up the word "Seed" in your calculator documentation and it will most likely tell you how this is accomplished on the TI calculators.
Nov 20, 2007 | Texas Instruments TI-83 Plus Calculator
Casio FX-9750GPlus Calculator Logo
82 people viewed this question
Top Casio Office Equipment & Supplies Experts
k24674
Colin Stickland
Colin Stickland
Are you a Casio Office Equipment and Supply Expert? Answer questions, earn points and help others
