Question about Liebherr K3660-20 Refrigerator
Fan not working, temperature too cold
Liebherr K3660 fridge next door to a freezer.
Freezing the contents of the fridge
Fan is not working.
Can you offer a simple fix or do I need the Liebherr man?
  • Anonymous Mar 16, 2014
    temperature freezer and alarm sounding on Liebherr freezer
You may need a man. Mine was doing the same, The sensor repair kit costs £35 the labour £60, both plus vat, so that was £109.25 in 2009.
Repair men seem thin on the ground and therefore his traveling time may add up. I believe, repair men pay for a course, and then charge like a wounded bull as they are the only ones that can do anything necessary
Posted on Nov 03, 2010
My Liebherr CNes 3366 fridge freezer has started to build up ice in the bottom of the freezer. How do I check the fan in the fridge is working, (I never see it going)as it may be the cause? thanks r
remove cover and test with a meter or push door switch when door open and should hear fan hum or feel air when door open fan stops unless you push switch
Apr 20, 2017 | Liebherr Refrigerators
I have a Liebherr CUPsl 3221 freestanding fridge/freezer. Does any one know what are the approximate temperatures in the freezer area at different settings? (1-7, manual button in the refrigerator are
Their are no direct connections between the number and the temperatures on refrigerators and freezers. Is is based on surrounding temperature, in the room. That is the reason they used numbers and do not mark teperatures.
May 23, 2014 | Liebherr Refrigerators
My liebherr 7082 218-03 fridge is freezing food and drinks - can anyone suggest why please?
Yes it could be the fan, it could also be that the freezer auto defroster isnt working.
Apr 11, 2013 | Refrigerators
Fridge acting like a freezer - with no difference made with temperature dial on front - I assume the problem will be the thermostat located with the light?
There can be many reasons why your refrigerator is freezing your food. To see what could be happening and to figure out how to possibly fix your problem. Take a look at this tip which contains many of the causes and solutions to fix the problems.
Refrigerator is Too Cold and Freezing Food
heatman101
Mar 06, 2011 | Liebherr K3660-20 Refrigerator
The fridge does not seem to be cold enough and the fan inside does not seem to be working - could this be the problem
On most refrigerators you get your cold air from the "freezer" compartment. If the freezer fan motor is inoperable, this will prevent the proper amount of cold air to flow into the "fresh food" compartment. Make certain that the fan motor does not work with the freezer button within the door frame activated. On some models, with the door open, the fan motor will not operate. Open the freezer door and activate the freezer button for several seconds to determine whether the fan is properly working or not. If not, contact an appliance service company.
Feb 16, 2010 | Liebherr Refrigerators
Refrigerator the freezer is cold but other side is not, when I have the freezer door open cold air blows through the vent to the other side through the vent
First thing to try is Powering off the FF at the mains supply and leaving it standing for 30 minutes. Make sure that you do not open any of the doors or touch any of the controls during this time. Then reconnect the power and wait for 30 to 60 minutes to see if the fault remains or is cured.
In side by sides if the freezer side is working OK and the fridge side is not working correctly it means that the air vent from the freezing unit to the fridge compartment has stuck in the closed or partially closed position which causes the fridge to not be any where near as cool as it should be. If it is too cold then the vent is stuck in the open position and the fridge temperature will continue to fall and become the same as the freezer, thereby freezing the contents of the fridge compartment. It can also get stuck in another position so that if the temperature is adjusted on the front panel then nothing happens to the temperature in the fridge compartment. The vent, which is usually at the tope of the fridge compartment on the side where it joins the freezer compartment, is controlled by a small sync motor and either the motor has become faulty, the control module is faulty or the vent is iced up. It can be come iced up by putting too many hot items in the fridge so the steam condenses and freezes the vent in position and then the motor cannot open or close it causing it and / or the control module to become faulty. Other times it is just old age that causes the motor and / or the control module to fail. If the sync motor and vent are working Ok then there may be a fault with the fridge temperature sensor or main on board controller that will mean that the sensor or the controller will need replacing.
Also worth checking the return air path from the fridge and making sure it is not blocked or frozen up. Also check the freezer compartment and cooling panel at the rear (behind the cover plates) and the fan for icing / blockage up as it sounds like there is a mini vacuum being created when the freezer door is closed or you have too much in the frezer so it presses on the back plate and stops the mini fan circulating air to the fridge.
Oct 30, 2009 | Kenmore 55612 / 55614 / 5561 / 655619 Side...
My fridge is freezing food
The fridge gets its cold air from the freezer through a vent(damper) between the freezer and fridge.The fan in the freezer blows air through it. Make sure this fan is running. You may have to hold the door switch in for it to run. There is a flap you adjust with the fridge temp. control. Make sure it's opening and closing when you adjust the fridge temp.
The problem could be the electronic control if you have one or the mechanical linkages.
Oct 21, 2009 | Refrigerators
Fridge will not turn down
How to check everything
http://www.acmehowto.com/howto/appliance/refrigerator/refrigerator.php
Sep 21, 2009 | Liebherr KES3660 Stainless Steel...
Freezer cold but not freezing
Check the settings for the freezer control. Refrigerator temperature control normally controls the run time of the compressor. if the freezer control is set to low the refrigerator temperature will be fine and the freezer will be warmer. Setting the freezer control to a colder setting will hold back more cold air in the freezer and reduce the air volume supplied to the refrigerator. Check and make sure the condenser coil is clean.
Jun 08, 2008 | Liebherr Premium CTP 3153 Top Freezer...
Liebherr K3660-20 Refrigerator Logo
650 people viewed this question
Top Liebherr Refrigerators Experts
Dan Webster
Dan Webster
Shehu Pro
Shehu Pro
Are you a Liebherr Refrigerator Expert? Answer questions, earn points and help others
