Question about HP Pavilion A530n (DW234A#ABA) PC Desktop
Hp pavilion a503n
PC will not turn on no matter what power source is used. When power cord is attached, green light an rear of tower flashes.
  • 1 more comment
  • Cody6846 Jan 19, 2008
    I'm having the same problem right now. I went to bed last night with the PC still running. We lost power for a while in the middle of the night, this morning the PC will not power up, and the green light under the power cable plug-in is flashing. The PC is plugged in to a surge protector, and the surge protector is still reading that it's protected. I've not tried anything yet, but was basically looking to see what the flashing green light meant. I'm hoping (though doubtful) that maybe there's a reset. Should I start with a new power supply?
  • Anonymous Jan 25, 2008
    Same problem. After power down. Never coming back. I checked motherboard and when power is on light on the motherboard is on. Change memory, video card, power supply and nothing. I had same problem like a year ago with AMD 64 - Systemax, but didn't do any fix.
  • Anonymous Dec 15, 2008
    anyone know how to access the motherboard?
    Problem Solver:
  • 14 Answers
Hey, If you have switched out the power supply with known working and it still doesn't power up then it might be your motherboard has gone bad. What happened the last time the PC was on? Did you power it down normally and then it never came back on?
Posted on Sep 23, 2007
Why is my hp pavilion a1220n product number ED904AA-ABA?
Try removing the 512 MB memory to see if it does work with the 1GB stick only.
It's not the power supply that does have a problem. It has something with your memory stick.
Dec 12, 2012 | HP Pavilion a1220n (A1220NED904AA) PC...
Hp pavilion f1340.uk will not turn on at all, just the green light flickers at the rear of the tower?
Could be a number of things wrong with this tower.
-If the computer stays at a black screen with a white cursor, it means it's missing system files and the operating system cannot start up. A reinstall is needed.
-If your computer won't power on, it could be either the power supply or motherboard, or sometimes, both.
-Also, check to see if the RAM is properly inserted into the proper slots.
Hope this was helpful.
Apr 18, 2011 | HP Pavilion Desktop PC
HP PAVILION A 1520N pc DESK TOP does not turn on when power button pressed. has power to end of cord. Power button does not light up. little green light on back by power source blinking green
Bad Power supply. Look on the side of your current power supply and find the wattage rating, and buy one of the same rating or higher. Some place like newegg.
Feb 24, 2011 | HP Pavilion a1520n PC Desktop
Hewlett Packard Pavilion Tower Button Flashes for a second but will not power on the tower. The green light in back is on and power source is fine. How can I fix this?
Sounds like the power supply is bad. That's the one inside the tower.
You could try blowing dust out of it,  reseating the connectors. But I have a feeling it needs replacing.
Go here for detailed instructions from HP..
http://h20000.www2.hp.com/bizsupport/TechSupport/Document.jsp?lang=en&cc=us&taskId=125&prodSeriesId=3376322&prodTypeId=12454&objectID=c01358060
Dec 10, 2010 | Computers & Internet
The light on the power supply (back of tower) and light on the front button that turns on the computer flashes. This is with the power cord plugged in. The computer does not turn on when I press the...
try removing the front panel make sure the button isnt clogged with dust or disconected failing that it may well be your power supply internal fuse which can be repaird but a trick job if youare not very good with a soldering iron you may get a replacement one on ebay.
Oct 06, 2010 | HP Pavilion a622n (PC108A) PC Desktop
Tower won't turn on. There is a green light on the back near the power cord that's flashing green.
Pull the power cord out and allow it to reset. If you still have issues you may need to replace your power supply.
Aug 05, 2010 | HP Compaq Presario Media Center SR1750NX...
HP Pavilion a735w will not power up Green light flashing.
check the light at the rear panel of the tower ... if it is solid green then reseat the cables coming out of the smps and going to the motherboard and other device drives(Hard Drive and CD/DVD drive).... if there is no light smps might have gone bad
Jan 27, 2010 | HP Pavilion a735w (PL308AAR) PC Desktop
HP Pavilion A520N will not power up. Green light
Which light?? the network light?? Do you get anything when you press the power button if not it is most likely the power supply since the motherborad is still showing power also may be cpu!
Nov 17, 2009 | HP Pavilion A520n (DW233A#ABA) PC Desktop
Hp desktop wont turn on worked two days ago? Turned it off and when i tried to turn it back on ---nothing. A green led light in the rear of the tower is flashing ???
check if the monitor is on.check is the fan is making noise.If not then the power supply has problem.what appears on screen?
Jul 10, 2009 | HP Pavilion dv6000z Notebook
Tower problem
the problem is your power button needs to be replaced or you can buy a new pc box on ebay for cheap.
Nov 02, 2008 | HP Pavilion 754n PC Desktop
HP Pavilion A530n (DW234A#ABA) PC Desktop Logo
144 people viewed this question
Top HP Computers & Internet Experts
pontelemon
pontelemon
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
