Question about Boss RIP210DVC Car Subwoofer
How big/small can the Enclosure be on RIP210DVC Car Subwoofer
Specifications Key Features Type: Component Elements: 1-Way Function Subwoofer Size: 10" Powered: Non-Powered Nominal Power Handling: 500 Watt Technical Features Peak Power Handling: 1000 Watt Frequency Respond: 35 Hz - 2,200 Hz Sensitivity: 94 dB Impedance: 4 ohm Components Woofer Material: Paper Mounting: Enclosure: Non-Enclosed Top Mounting Depth: 5.5 in.
Posted on Apr 25, 2009
What size should i make the enlcloser
If looking for LOUD, ported enclosure is the way to go.
If looking for accuracy, build sealed. You will need approx 2 cu ft
To tune this 2 cuft box around 50Hz, you need (1) 4" round port 5" long.
MTX recommends an enclosure of 2cuFt ea. You will only be able to use 1 subwoofer in this application.
Even a sealed enclosure is recommended 1.25cuFt.
You can shove 2 in the vented enclosure, but you may not be happy with the outcome
Dec 02, 2010 | Jensen XS-1010 Car Subwoofer
Speaker removal
Good day,
In your trunk there are 2 small amps. The first amp is connected to your car speakers. The second amp is connected to your subwoofer. Once you locate the subwoofer amp. Your subwoofer amp will be the amp close to the sub enclosure. Unplug the subwoofer from the amp. Your next step is to unscrew the 4 10mm bolts so that you can remove the sub enclosure. At this point you can now remove the enclosure. It will take a some time as it always seems to be up there pretty good. But once it starts to move it should come out with little work. I hope this helps with your removal of the subwoofer.
Mar 08, 2010 | 1995 Lincoln Town Car
What size enclosure should I put these 10" woofers in
According to the specs for the 4710 subwoofer, I would recommend going with a 1.25 - 1.75 cubic foot sealed enclosure, or a 1.5-2.0 cubic foot ported enclosure (the port should be 3" or less in diameter and at least 10 inches long.
Mar 07, 2010 | Volfenhag ZX-4710 Car Subwoofer
MTX 12'' sub noise
Sounds like your sub is overextending itself, and possibly losing contact at the voice coil. Overextending will make a weird rattling sound, losing contact at the voice coil will make a popping sound.
I’m happy to help further over the phone at https://www.6ya.com/expert/jeremy_69f3cc28d95bf514
Jan 12, 2010 | Car Audio & Video
What are specs for a ported subwoofer enclosure for a 12" pioneer champ series
TS-W307D2
Design and Specifications
12” Dual Voice Coil (DVC) Subwoofer for Enclosure applications 1,200 Watts Max. Power Handling 400 Watts Nominal Rating Qts = 0.44 Xmax = 8.7mm Fs = 33.9 Hz Vas = 42.2 litres Frequency Response : 18 ~ 500 Hz. Efficiency : 89 dB Impedance : 2 x 2 Ohm (Total 1 or 4 Ohms) Delivered with “jumper link”: ready for 4 Ohm use f0 (Lowest Resonant Frequency) : 33.9 Hz. Recommended Sealed Enclosure : 24 ~ 49.6 Litres RECOMMENDED sealed enclosure, not Ported. 24 Litres = 1464.569 cu. inches 49.6 Litres = 3026.777 cu. inches
Nov 23, 2009 | Pioneer TS-W307D2 12" 1200 Watt Champion...
How much resin and hardener should i mix up, i'm building a fairly big subwoofer enclosure and i'm not sure how big of a batch to make....... this is my first fiber glass enclosure, but i want to get it...
fist you need to find out how much air space you need for each speaker thats going in the box then you will need a frame something light but durable you can get sound board from lowes thats wat you need to start with and when your mixing your hardener and fiber glass mix only a small amount at a time just a little hardener add to much and it will dry immediatly if you mix a lot of it at once you will waste most of it do it during the day it needs to be around 60 degrees to get it right
Nov 19, 2009 | Kicker CVR12 Car Subwoofer
What enclosure do i need for cerwin vega v-max 124 12" sub
Just get a 12" sub box enclosure for an audio store near you or make a custom box, a larger box supposedly gives you more bass yet at the cost of boot space. I have a type R sub and the box is only as big as it needs to be for the sub to fit and it gives amazing bass.
Aug 04, 2009 | Cerwin Vega V-Max 12 Car Subwoofer
Need help im planning to build a enclosure for my s3.10.0 subwoofer, can someone advice what type of enclosure and what size it will be. Tnk u very much! hoping for good advice.
Hello marne_glenn,
Here's a link to Lightning Audio's manual for the S3.10.4.
The minimum recommended size for a sealed enclosure is .5 CuFt. There is no recommendation for ported.
Hope this helps.
Jul 29, 2009 | Lightning Audio S3.10.4 Car Subwoofer
Subwoofer Box for four lanzar 15"
what r u trying to do ?shake the car apart?Only kidding that a good questin 4 15: woofers in 1 enclosure>?what kind of enclosure ?how much space r we working with ? i use to be a installer , i also built costume boxes.I need to knoew how much space u have is it a car van,pick-up?I think an iso baric enclosure woukld be your best bet, it would take up the laest space. What frequency are you going to be runnig to your subs? what do you want? punchy bass,over the big tom drops?
what amp r you running or should i say amps?
you'll get the highest spl in a sealed enclosure,but i dont think thats what your looking for.you want heavy vibrating soud,am i correct? a band pass box will give that to you in a close space.bass sounds better and louder the further away you get../.give me more info then ill give you a layout.but 4 now this might help or solve your problem
http://www.rockfordfosgate.com/rftech/woofer_wizard.asp
they have all the wiring and p[hyschics and designs of boxes. rating please.
Jan 25, 2008 | Lanzar OPTI1222D Car Subwoofer
Boss RIP210DVC Car Subwoofer Logo
85 people viewed this question
Top Boss Car Audio & Video Experts
xxxxxx xxx
hoyzee1
Are you a Boss Car Audio and Video Expert? Answer questions, earn points and help others
