Good Morning ehsanulhaq, thank you for your inquiry!
Being that you have a top
mount, the vent in the freezer is what circulates air down to the Fresh Food
section, making it cool. Here are a few simple troubleshooting tips that may
help you resolve this issue:
First
check clearances around your refrigerator. There must be adequate space around
a refrigerator with a static condenser so that air can circulate properly.
Proper clearances include 1" at the back and 3" on top of the refrigerator.
Examine
your doors. If the doors have been opened too often or for too long, this may
have allowed warm air to enter the refrigerator. Make sure to shut the door
completely and be sure not to keep the door open for too long. Even leaving a
door slightly open can allow too much warm air intake. Make sure refrigerator
is level and keep food and containers from blocking the door closing.
Check
the door seal. You do this by placing a dollar bill between the body of the
refrigerator or freezer and close the door. The dollar bill should stay in
place and pull out with a small amount of resistance. If the dollar bill falls
out when placed between the gasket and cabinet, double check to see if the door
is being blocked by anything that may be stopping it from closing. If nothing
is stopping the door from closing then replace the gasket.
Check
to see if the condenser is dirty. A dirty condenser cannot release heat
efficiently into the surrounding air. Cleaning the condenser may be necessary,
more if you have animals in the house. If you have condenser coils, they should
be wiped occasionally with a damp cloth to remove accumulated dust. The
condenser coils should be wiped occasionally with a damp cloth to remove
accumulated dust.
Check
for any obstructions to the vent to ensure proper air flow. If the vent is
blocked, the air in the refrigerator will not get cool.
I recommend to double check the
freezer control. If the freezer control is set too warm, set freezer control to
a colder setting and allow 24 hours for temperature to stabilize.
If these assessment measures prove to be ineffective, I
would strongly suggest contacting an authorized service technician who would be
better able to assist you in the diagnosis and repair of your unit. You can
often locate an experienced technician in your area by going to the
manufacturer website.
Check out these tips...they can help you figure out what is going wrong with your refrigerator and why it is not cooling
Refrigerator not Cooling or Fridge not Cooling
How to Defrost Refrigerator Defrost Timer Problem
Water Running in refrigerator from Freezer
Refrigerator or Freezer not Cooling or Getting Cold
heatman101
heatman101
