Question about E-Machines eMachines Desktop PC
My computer wont turn on
My computer comes on but only the fans do and they just keep running nothing comes through to the monitor or the keyboard or mouse when i shut it down last night it was fine it went off i went to bed then i woke up and pushed the power on button and it reved then stopped so i pushed it again it reved then the power button blinked as the fans were spinning and it just stays like that please help i love my computer and can't live without it ....i checked the internal fuse and its fine i even hooked up a new power supply and it did nothing
  • kimotaino Apr 25, 2009
    I push the start nothing button light blinks fan comes on then nothing happens
  • 62 Answers
Your RAM should be Loose, Have a check on it. Remove it and fix it again.
Posted on Apr 22, 2009
  • 55 Answers
Remove the power cable and hold down the power button for about 30 to 60 seconds. plug the power back in and see what happens. If fail look at the back of your computer ans make sure that the fan for the power supply is on. Also make sure that the red switch is set to 115V and not 220V. This is also located in the power supply.
If al has failed your power supply is no longer working and will need to be replaced.
I have an hp home computer. I turn it on but mouse,keyboard,and screen wont come on.
Check all the connections from keyboard, mouse and screen to the pc. Also try unplugging any other devices.
Nov 05, 2013 | Computers & Internet
Problem stating up pc
check to see if your vga cable is properly connected at both ends i.e. at the monitors end as well as the computers end. In case it doesn't solve the issue then your vga port is damaged.
Aug 15, 2012 | HP Pavilion a1310n PC Desktop
No monitor or keyboard, fan is loud, Monitor puts up th no input message but wont turn on, keyboard lights are not on either
> fan is loud
When you first turn the computer on, the full runs at 100%, until the motherboard's "POST" (Power On Self Test) procedure has checked all the hardware, and "beeped" the speaker just once.
So, no "beep" (or multiple "beeps") and the 100% speed of the fan suggest a hardware problem with your motherboard.
Take your computer to a qualified technician for professional trouble-shooting.
Jun 26, 2011 | Acer Computers & Internet
When I turn my computer on the monitor does nothing, i also see power to the keyboard, but when i enter a ctrl/alt/del command the dower lights do not change, indicating working in the background.
Can you hear the Power supply fan running in the back of the computer? Usually, these symptoms indicate a faulty power supply to the motherboard. When was the last time the fan was cleaned?
Sep 25, 2010 | Dell E228WFP LCD Monitor
MPC model D945GCZ serial:4237231-0001 INTEL
It should at least beep. Those beeps are diagnostic codes. Listen to the beeps and google 'bios error beep codes'. If it doesn't beep, the motherboard must be replaced.
Apr 20, 2010 | Computers & Internet
Tower turns on fan runs lights on BUT NOTHING >>>>>>>
If the CD drive door won't open, odds are that at least you know the drive is without power. Have you had the case opened up at all? With what you've described here your computer needs the tender, loving care of a technician.
Sep 20, 2009 | 3G Technology GM-171B 17" Flat Panel LCD...
Computer won't start up and has a constant tone.
If the noise is constant then it means the problem is either:
1: a Power supply issue
2: a motherboard issue
3: a keyboard problem
the latter of the three being the easiest to fix, try booting with your keyboard unplugged or even better if you have another keyboard try using it to see if that corrects the problem.
If the above does not work then you have a problem with 1 or 2, and in order to find out for certain you will need to test it, you can goto your local computer diagnostic store to see if they can check which it is.
and hope its not a problem with the motherboard.
Hope this helps, and Good Luck
Apr 13, 2009 | Computers & Internet
Gateway FPD1760TFT LCD monitor
Problem
1. turn on computer
2. monitor receives signal, it looks like its working
3. it goes through some steps and then the monitor says "no signal" and kind of stays in limbo with fans running, etc.
Solution
One possibility is that computer is looking for drivers for you video card. It could be hung up looking in the wrong places. Remove all peripheral hard drives and memory sticks. Try again.
Jan 12, 2009 | Gateway FPD1760 17" LCD Monitor
Pc Seems to be dead wont load bios post moust doesnt work or keyboard or monitor
I have the same problem, the CPU fan spins, keyboard lights blink, no start up screen, or bios.
But, when I push a few times on the pc reset button, then the CPU fan is becoming still, the keyboard light are out and I can start the computer again in a normal way.
Can this one be a temporally solution for you too? Do you have any suggestion about?
I guess it can be an electricity dysfunction of a wrong fixed cable.
Oct 15, 2008 | Biostar P4M80-M4 Motherboard
Loud Fan, Three Beeps, Black Monitor and No Keyboard response
I have the same model after youlet it sit for a long enough period to cool down it will come back on and work normal, it is a cooling problem called gateway and they confirmed this theproblem I ran in to was what fan this computer has 3. temp fix I used was to remove the tower cover to allow better air flow try this till you can figure out what fan is messing up
Jun 02, 2008 | Gateway GT5404 PC Desktop
E-Machines eMachines Desktop PC Logo
189 people viewed this question
Top E-Machines Computers & Internet Experts
Matthew Spark
Matthew Spark
Are you an E-Machines Computer and Internet Expert? Answer questions, earn points and help others
