Question about Onkyo TX-SR604 Receiver
My Onkyo 7.1-Channel Receiver
For some reason my receiver is on stand by and it turns off all the time... i think it stands for about 15 mins and then off and the stand by light starts blinking
Take out all the cables unplug from mains for an hour ,plug it back in with no cables connected ,turn volume to full if it turns off its faulty ,if it stays on turn volume to minimum,unplug from mains,connect all cables,turn back on.
Posted on Nov 10, 2007
My stand by light flashes on my onkyo tx-sr501
Check output transistors for short, change emitter resistors
Mar 30, 2014 | Onkyo TX-SR501 Receiver
Receiver goes to stand by when turned on. All components and speakers disconnected and still goes to stand by. Any suggestions?
This is most likely a "protect" mode. A problem has been detected and the unit shuts down to prevent further damage. The most common cause of this are defective output transistors. Plan on a parts cost of $25-$40 for this repair.
Dan
Jun 15, 2010 | Onkyo TX-SR500 Receiver
My onkyo tx8211 stay on a stand by mode. I can
If it's anything like my Onkyo surround receiver, pressing any input selection will turn on unit.
May 16, 2010 | Onkyo TX-8511 Receiver
Is it odd that my TX-SR606 Onkyo Receiver wont go into stand-by? It turns off but the standby light never lights.
try reset. push and hold vcr1 and then press power button while unit is on this will reset back to factory default
Apr 24, 2010 | Onkyo TX-SR606 Receiver
Onkyo TX-DS 595 receiver surround channel unrealiable
How you power off the amp won't hurt it generally. I used to fix ONKYO amps under warranty, and I can tell you now, it will be full of dry solder joints. Take you unit to your local repairer, and they will resolder all the offending PCB's inside. This type of repair will fix 99% of strange audio noises and cutting in and out etc. for ONKYO recievers. Otherwise this is quite a good product.
Oct 27, 2009 | Onkyo TX-DS595 Receiver
When I push the stand-by/on button - stand-by blinking
WHEN I PUSH THE STAND BY BUTTON THE UNIT GETS ON AND IMMEDEYETLY GETS OFF(YAMAHA RXV-995 IF IUSE 500VA STABULISER THAT PROBLEM NOT COMING PLEASE SOLVE IT
Sep 10, 2009 | Onkyo TX-SV373 Receiver
Yamaha RX-V660 right channel gone
Try checking the connections.
If your really value your receiver it would worth it.
Jun 22, 2008 | Onkyo TX-DS575 Receiver
Onkyo TX-SR500 loosing settings
Turning any receiver off will erase the settings - there is no backup battery (Onkyo uses Battery Free Memory Backup) and the length of time depends on the capacitor charge. Why not just leave the receiver plugged in? Stand-by mode uses a negligible amount of power - enough to keep the capacitors charged and the LED on the front panel on.
Jan 27, 2008 | Onkyo TX-SR500 Receiver
Brand new Onkyo Tx-sr605 won't leave stand by
If the unit will not leave standby I would remove all power, disconnect *all* connections at the back, reconnect to a power source and try powering on. This will eliminate any connection causing the Onkyo to stay in standby due to a short. If it still will not enter power-on mode, you may want to look at the power source (is it properly grounded?), but beyond that the unit probably needs to go back.
Nov 03, 2007 | Onkyo TX-SR605 Receiver
Onkyo TX-SR604 Receiver Logo
278 people viewed this question
Top Onkyo Audio Players & Recorders Experts
Ted28
Level 1 Expert
 Grubhead
Grubhead
Are you an Onkyo Audio Player and Recorder Expert? Answer questions, earn points and help others
