Question about MSI 661FM3-V Motherboard
Hard drive not detected
Hard drive not seen in bios
  • 1 more comment
  • Jerry May 11, 2010
    What type of hard drive (brand/model) are you using? How many Gigs? 500GB? 1Terabyte? Is this a brand new hard drive?
  • Dave Bopit May 11, 2010
    What is the make and model of your motherboard and harddrive? Also what version is your bios?
  • mrninja
    mrninja May 11, 2010
    check ribbon cable is not upside down or backwards...check jumper settings on unit (cs is cable select) check power cable to unit
  • 84 Answers
First check the cable connected to motherboard and hard disk....if its ok then ur cable might have some problem...replace it...
Posted on Apr 24, 2009
Why does my laptop say system operator missing
System operating missing means that your laptop cannot find a operating system to start. This could be that your hard drive have crashed or overheated or the laptop is not detecting your harddrive. You might want to go into your bios menu and see if the bios is detecting your harddrive, and if it is not, it could be that your hard drive is bad. The only way to test this out is to take your harddrive and connect it to another computer to see if it is working. If it is working then there could be a loose connection between the hard drive and the laptop. If the bios detect your harddrive, then that means your operating system is currupted and needs to be fix or reinstall.
Jan 13, 2011 | Computers & Internet
I have a k8u-x motherboard.. my problem is i cant install winxp in it because it doesnt detect any hardisk during the setup. All my floppy drives are damage as well as my floppies. Is there any way to...
Your trying to install windows 3.1 or 98 ? I have never seen Windows XP or newer on floppy disk is why I ask. That will not resolve your problem though. If you are sure you have the hard drive installed and connected with at least one of them set to Master, if you are installing 2, You may need to enter Bios and have it auto detect the Hard Drives in the Bios. If the Bios doesn't recognize the Hard drive or you have 2 hard drives and one isn't set to Master it won't matter what media you use you won't be able to install anything on the hard drive.
Sep 08, 2010 | ASUS K8U-X Motherboard
Laptop wont turn on
It means that the Hard Disk Drive that holds all your data and the WIndows Operating system is not being seen by the system BIOS. Remove and reseat the hard drive, see if it detects. If it doesn't then you'll be replacing the hard drive.
Nov 14, 2009 | Dell Latitude C640 Notebook
Toshiba qosmio g15 hard drive #2 not showing up on explore
First ensure the drive is seen in the BIOS, if not seen there, it will not be seen in Windows.
If detected and Identified in BIOS, then see if the drive is seen as Drive 1 in Disk Management. CONTROL PANEL, ADMIN TOOLS, COMPUTER MANAGEMENT, DISK MANAGEMENT. If it is listed in Disk Management but not assigned a drive letter, then right click the Disk 1 and INITIALIZE the Drive, then format it (Note: any data on the drive will be lost when initializing a drive)
Jun 25, 2009 | Computers & Internet
My bios doesn't recognize my hard drive
Do the neccesary jumper cable settings. then manually detect it through your bios. If not detected, try to replace the ide cable. if still not detected, try to feel the hard drive if it spins, if not, the had drive is damage.
Mar 03, 2009 | Seagate Barracuda 7200.7 200 GB Hard Drive
Hard drive
Make sure your jumpers on your hard drive are properly set. Also, test another cable to rule out that your IDE cable hasn't faulted. You can also go into your bios settings on startup and check to make your hard drive is detected, if not run the auto detection and see if it is seen then.
Nov 18, 2008 | Dell Dimension 8400 power supply ** FREE...
My sata hard hard drive is not detected in linux
Check in your BIOS settings that SATA drives can be seen as "ATA"
Install Linux, and then , after everithing went OK, change BIOS to SATA again.
Aug 04, 2008 | Computers & Internet
Clicking sound & not seen
Does BIOS detect the hard drive? if not then it has conked off. Buy a new one.
Dec 20, 2007 | Maxtor Personal Storage 3200 (U01E200) 200...
Cant detect hard disk
hi all,i just had the same problem, heres how i fixed it.
in bios, check you settings
if using ide and sata, enable combo cable select
check motherboard compatability 1.5gps or 3.0 gbs
if 1.5 insert jumper on back of HDD
check now in BIOS to see if HDD seen.
now boot windows, open control panel, administrative tools, computer managemant, disc management and select drive, it may need to be formatted.
Dec 19, 2007 | Samsung 1TB SATA2 7200RPM 32MB HD103UJ 334...
Harddisk
Check the jumper settings on the back of the drive, if this is the primary HD, set it to master, if secondary, set it to slave, if secondary still does not recognize, switch the ide cable so that the two drives are not on the same one.
Nov 19, 2007 | Computers & Internet
MSI 661FM3-V Motherboard Logo
Top MSI Computers & Internet Experts
vsri9
Alun Cox
David
David
Are you a MSI Computer and Internet Expert? Answer questions, earn points and help others
