System error I have a program trying to enable itself when I start my computer. At first it said it wanted to run a Bonjour service and now that I have deleted it it said device monitor system. It wants to run a program to see what I am doing on the internet. It was given to us on a reciept from Safeway grocery store and now I cant seem to figure out how to delete the program so that we dont have it again. When we typed in the info from the reciept it didnt say that it was going to monitor what we did on the internet until it was downloaded and now it wants to run everytime we start our computer. How do I delete this problem.
    Scholar:
  • 132 Answers
That sounds very odd. Have you tried going to add/remove programs to see if its there? If so, uninstall it.
If it isn't listed there then you can remove it from your start up folder. In Windows XP you can right click the Start button, go to explore, left click Programs in the left hand pane, left click Startup in the left hand pane, delete reference to the program in the right hand pane.
If it isn't there then it's in your registry. You can check if there is reference to it under the following key but be very very careful when working in the registry as it can cause issues to delete the wrong thing.
Click Start, in the run area type in regedit.
Go to this key: hkey_local_machine\software\microsoft\windows\currentversion\run
Posted on Apr 22, 2009
Too many programs open at start up
Your best bet is to download CCleaner and use the startup cleanup option. The program is free, and it won't let you prevent any essential system apps from running
Apr 26, 2012 | Microsoft Computers & Internet
Tip
Error: 169.x.x.x IP Address
<p><b>Information:</b><br /> <p><span>This article outlines methods of resolving issues with a 169.x.x.x IP address. <span>This address results from a built in feature of windows called automatic private IP address(APIPA). When your computer is unable to find a DHCP server the APIPA service will assign itself a 169.x.x.x IP address. According to Microsoft, the APIPA service checks for a DHCP server every five minutes. </span></span><br /> <p><span><span><b>Workaround:</b></span></span><br /> <p><span><span><b>Releasing the IP address</b></span></span><br /> <p><span><span>1. Click on Start and click Run.<br />2. Inside Run, type ipconfig /release to release the IP address.<br />3. Then after the IP address is released, type ipconfig /renew</span></span><br /> <p><span><span><b>Disabling the Ethernet Adapter</b></span></span><br /> <p><span><span>1. Click on Start and right click on My Computer. Then click on Manage.<br />2. Click on Device Manager and then Network Adapters<br />3. Under Network Adapters, right click on your Ethernet adapter and select Disable. <br />4. Wait approximately 5 seconds and right click on it and click Re-enable. <br />5. This restarts the DHCP client and tries to obtain an IP address from the Network.</span></span><br /> <p><span><span><b>Check the Ethernet cable</b></span></span><br /> <p><span><span>Sometimes a bad Ethernet cable can cause your system to receive a 169 IP address, try changing out the cable for a new one.</span></span><br /> <p><span><span><b>Disable antivirus and firewall applications</b></span></span><br /> <p><span><span>Disable/uninstall any external firewall, antivirus, or spyware programs (eg. Norton Internet Security, McAfee Security Center, Trend Micro 2007, Webroot).</span></span><br /> <p><span><span><b>Restarting the QoS packet scheduler Protocol</b></span></span><br /> <p><span><span>1. Click on Start and click Control Panel.<br />2. In Control Panel, double click on Network Connections and then Local Area Connection.<br />3. Click on Properties and uncheck QoS Packet Scheduler. <br />4. Click Ok and repeat the process. <br /></span></span><br /> <p><span><span><b>Restarting the DHCP service</b></span></span><br /> <p><span><span>1. Click Start and select Run. <br />2. Type services.msc in Run and click Ok.<br />3. Find DHCP service and right click on it. Click on Stop.<br />4. Reboot the computer.<br />5. When the computer boots up, click Start and select Run<br />6. Inside Run, type the following: netsh int ip reset log.txt<br />7. Click Ok.</span></span><br /> <p><span><span><b>System Restore</b></span></span><br /> <p><span><span>1. Open Start and click on Programs and then Accessories.<br />2. Then click on System Tools.<br />3. Click on System Restore and select a restore point when you were not experiencing this problem.<br />4. Restore your system.</span></span>
on Mar 15, 2011 | Computers & Internet
Tip
IP address 0.0.0.0
First of all, disable and re-enable the connection. When you change the IP address from automatic to a fixed IP address while the adapter is not connected, you always get a 0.0.0.0 address at first when the adapter reconnects. If this doesn't solve the problem, read on.
Symptoms:
  • You cannot obtain an IP address from the DHCP server. The IP address is 0.0.0.0.
  • The DHCP service is not running, although it is set to Start Automatic.
  • When you try to start the DHCP service, you get the error message: Could not start the DHCP Client Service on Local Computer. Error 1075: The dependency service does not exist or has been marked for deletion.
This problem can occur after uninstalling Norton AntiVirus, which sets the DHCP service as depending on itself. It can also occur when the computer name of the client computer is too long. Make sure that all computer names in your network are no longer than 15 characters.
First set a restore point, so you can undo your changes, should anything go wrong (Programs, Accessories, System programs, System restore).
After setting the restore point, to remove this dependency, do this:
  • Click: Start
  • Click: Run...
  • Type: regedit
  • Click: OK
  • Navigate to the following keys in the registry:
    HKEY_LOCAL_MACHINE\System\CurrentControlSet\Services\DHCP
    HKEY_LOCAL_MACHINE\System\CurrentControlSet\Services\NetBT
  • For each of these, on the right side, double-click: DependOnService
  • Delete any lines containing either SYMTDI or NISDRV.
  • Click: OK
  • Close the Registry Editor.
  • Reboot.
on Mar 29, 2010 | Computers & Internet
My pc is running really slow... can u please help me????!!!!?????
There are a number of reasons but mainly 2 kinds causing a PC running slow. Outdated hardware or poor system maintenance. If possible, try upgrade hardware configuration such as add more RAM etc. Otherwise try this program Speed up PC to diagnose & fix the slow pc for issues. Best regards!
Jul 17, 2011 | Computers & Internet
My Dell Inspiron 1525 freezes randomly after starting up. I can't use the mouse or keys to change the screen. The computer freezes around 5 minutes after starting up. I booted up in safe mode and have...
If you had no issue in safe mode the only thing I've seen like that is a virus that cuts of your use of I/O ports. boot into safe mode and try doing a system restore to a time before this problem occurred. IF that doesn't solve the problem try doing a clean install of the OS
Feb 28, 2011 | Dell Inspiron 1525 Notebook
How to enable Bonjour on windows XP
Go to start, run type services.msc
click on Bonjour service and either set to auto or start it depending on what you want.
I hope I have been of help but please do not hesitate to ask if you have any further questions.
I appreciate your vote if you appreciate my reply.
Feb 22, 2011 | Computers & Internet
Cannot use WinXP System File Checker (SFC), RPC Server?
Are you trying this in safe mode?
Sometimes the RPC service will refuse to start. Assuming all other services are reset to their default values:
Start, run, CMD
net start (check the service again to be sure it is stopped)
net start rpcss
net start (check again)
if no joy, you need to use the XP CD to go to the Recovery Console.
From the Recovery Console type:
enable RpcSs SYSTEM_AUTO_START
reboot the machine.
"Could not start the Remote Procedure Call (RPC) Service. Error 1058" error message when you manually start the Remote Procedure Call service
http://support.microsoft.com/?kbid=838428#appliesto
Some general things to try.
See if System Restore will get you back to a restore point before your problem with Explorer.
Try Safe Mode (Do you have this problem in Safe Mode?).
Try running ChkDsk to check your drive for errors. Right-click your Drive icon/ Properties/ Tools/ Error Checking. Select both boxes.
Run the System File Checker program from the Run Box by typing.....Sfc /Scannow in it and have your XP CD handy.
HOW TO: Verify Unsigned Device Drivers in Windows XP
http://support.microsoft.com/support/kb/articles/q308/5/14.asp
If they don't work you could try repairing windows by running it over itself. You will lose all your windows updates but your files will be untouched.
How to Perform an In-Place Upgrade (Reinstallation) of Windows XP (Q315341)
http://support.microsoft.com/support/kb/articles/q315/3/41.asp
Oct 17, 2009 | Microsoft Windows XP Professional for PC
Bonjour problem
Bonjour is not needed:
To remove Bonjour:
  1. Open a Windows command prompt and type the following command:
    "C:Program FilesBonjourmDNSResponder.exe" -remove
  2. Navigate to the following folder in Windows Explorer: C:Program FilesBonjour
  3. Rename the mdnsNSP.dll file in that folder to mdnsNSP.old
  4. Restart your computer
  5. Delete the the Program FilesBonjour folder
Note: Removing Bonjour prevents Version Cue clients (Photoshop, Illustrator, InDesign, Flash, Bridge) from automatically discovering Version Cue Servers and Version Cue projects in your local network. You will need to connect manually using Connect to Server and the URL or IP address of the machine running Version Cue Server instead.
http://kb.adobe.com/selfservice/viewContent.do?externalId=kb400982
Click on this link or copy and paste the complete link into your browser.
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it.
Thanks, Joe
Dec 25, 2008 | Apple iPhone 3G
Toshiba Laptop Malfunction (2)
This sounds like 2 things, it could be a video driver conflict or there's a startup program that might be causing the problem. To check which is which, try restarting the computer > press F8 when you see the toshiba screen until you get the Advanced Boot Options.. then choose Enable VGA Mode (I'm assuming your using WindowsXP). If that works and you get to the desktop screen with no problems, try removing the display driver & replace it with a compatible one (usually on the cd that came with the laptop). If that doesn't work, try choosing Safe Mode and run msconfig (start > run > msconfig) and disable all services & startup programs (don't forget to check "hide all microsoft services"). then restart the computer. If this doesn't work and continually goes to a loop, do you see a bluescreen with error messages on it? Like Error 0x00000003 or 0x0000000E etc.? or a memory dump error? That could be a hardware problem already and it may require service.
Hope this helps.
Oct 03, 2008 | Toshiba Satellite M45-S265 Notebook
Computers & Internet Logo
David Payne
David Payne
