Question about Dishwashers
Dishwasher starts to fill then stops but timer continues
  • 1,889 Answers
A dishwasher starts by first having the lever close a switch in the door a second switch is closed against a pin as the door closes. then the machine will fill with water untill a float lifts enough to close a switch and, dishwashing will start so; check the float switch when this problem occurrs
Posted on Apr 22, 2009
S5N27B keeps stopping mid cycle
If the cycle doesn't complete, check these:---
Water-heating cycle Many dishwashers heat the wash and/or rinse water to a higher temperature, as the cycle calls for it. In these cycles, the dishwasher pauses after it has filled with water, waiting for the water to reach the pre-set temperature. What happens next, depends, as follows: On some units, the pause is timed and the unit continues after the allotted time. On others, the cycle can't continue until the water reaches the higher temperature. If you have this type of dishwasher and the water isn't being heated (say, because of a problem with the heating element or thermostat), after the unit stops at the heating cycle, it never continues. When you repair the heating-system problem, the "cycle problem" is fixed too. Timer Timers don't often fail. But if every other part of the dishwasher seems to be working properly and the timer knob seems to be stuck in one place--doing one function continuously--the timer may be at fault. Dishwasher timers can't be repaired. If yours is defective, replace it.
This will help. Thanks please keep updated.please do rate the solution positively .thank you for using fixya
Dec 28, 2009 | Bosch Dishwashers
It starts then stops. never completes the cycle. it shuts down. it will drain thats it.
If the cycle didnt complete check the following:
Water-heating cycle
* On some units, the pause is timed and the unit continues after the allotted time.
* On others, the cycle can't continue until the water reaches the higher temperature. If you have this type of dishwasher and the water isn't being heated (say, because of a problem with the heating element or thermostat), after the unit stops at the heating cycle, it never continues. When you repair the heating-system problem, the "cycle problem" is fixed too.
Timer
Timers don't often fail. But if every other part of the dishwasher seems to be working properly and the timer knob seems to be stuck in one place doing one function continuously the timer may be at fault. Dishwasher timers can't be repaired. If yours is defective, replace it.
Sep 03, 2009 | Kenmore 24 in. 17482 / 17484 / 17489...
Our neff dishwasher has suddenly started to go wrong. When you switch it on a push a setting, it fills but does not wash. After about 10 mins it even drops the powder cube but still has not washed, it just...
Water-heating cycle
Timer
  • On some units, the pause is timed and the unit continues after the allotted time.
  • On others, the cycle can't continue until the water reaches the higher temperature. If you have this type of dishwasher and the water isn't being heated (say, because of a problem with the heating element or thermostat), after the unit stops at the heating cycle, it never continues. When you repair the heating-system problem, the "cycle problem" is fixed too.
Aug 02, 2009 | Dishwashers
Dishwasher stalls
Water-heating cycle
Timer
May 31, 2009 | Bosch SHU4006 Dishwasher
Dishwasher keeps tripping electric
Two things to consider....clean water or dirty water?
Clean water usually indicates the fill valve is not shutting off all the way and the fill valve is "weeping" water in all the time = new fill valve time!!
Dirty water usually is not a dishwasher problem but more of a plumbing issue. Often the sink drain that carries the sinks water outside is not fast enough and some of this sink water is backing up into the drain hose and filling up the dishwasher through the drain hose. The drain from the sink to outside needs attention as this type of a problem indicates a slow house drain for that sink.
The dishwasher drain line should be clamped to the top underneath part of the counter before entering the sink drain plumbing, this may help the water from coming back inside the dishwash
Water-heating cycle
Timer
Jan 04, 2009 | Whirlpool GU2400XTP Built-in Dishwasher
Dishwasher pump motor stops
Water-heating cycle
Timer
Water-heating cycle Manydishwashers heat the wash and/or rinse water to a higher temperature,as the cycle calls for it. In these cycles, the dishwasher pauses afterit has filled with water, waiting for the water to reach the pre-settemperature. What happens next, depends, as follows:
  • Onothers, the cycle can't continue until the water reaches the highertemperature. If you have this type of dishwasher and the water isn'tbeing heated (say, because of a problem with the heating element orthermostat), after the unit stops at the heating cycle, it nevercontinues. When you repair the heating-system problem, the "cycleproblem" is fixed too.
Timer Timersdon't often fail. But if every other part of the dishwasher seems to beworking properly and the timer knob seems to be stuck in oneplace--doing one function continuously--the timer may be at fault.Dishwasher timers can't be repaired. If yours is defective, replace it.
Dec 10, 2008 | GE Dishwashers
Dishwasher will not finish cycle
Oct 19, 2008 | Dishwashers
Won't run through cycle
please rate my solution thanks
Jun 30, 2008 | Frigidaire 24 in. FDB1050REC Stainless...
Dishwasher problem
1. Water-heating cycle
2. Timer
Water-heating cycle
Timer
 thanks for using FixYa
Feb 10, 2008 | Kenmore 65924 Electric Dryer
Dishwashers Logo
175 people viewed this question
Top Dishwashers Experts
