Question about Motorola Mobility SLVR L7 Cellular Phone
FLASH METRO PCS TO CRICKET
I HAVE A METRO PCS AND I WANT TO UNLOCK THE PHONE AND CHANGE IT TO CRICKET.HOW DO I GET THE UNLOCK CODES TO FLASH A METRO PCS TO CRICKET SERVICE?
How do I flash a sprint Samsung galaxy s2 for metro use
I think what you mean is that you want o unlock it. This a CDMA phone, but there is also an S2 Sprint model which have a min-SIM card (the Samsung SPH-D710). But then again I'm not sure that it can be unlock. One way would be to contact Sprint, they will ask you for an ESN (located under the battery). To flash any firmware you need the firmware and Odin, this is a tool to flash firmware to Samsung devices. But that won't unlock your device.
I recommend that if possible, visit a Metro PCS store or Kiosk, maybe they can sell you a mini-SIM card and unlock it for you. Metro PCS use CDMA technology as Sprint and Verizon, but Metro PCS is now accepting GSM phones. Best of luck.
Mar 06, 2014 | Samsung Cell Phones
I want to flash a metropcs phone to cricket
Flash or Flashing--Technically, flashing refers to the overwriting or re-writing of the phone's firmware. There are many phones which can be flashed to cricket with all features working. On most CDMA phones, programming the phone can be done "over the air" by dialing a special code, usually *228 or some variation. Colloquially speaking, flashing can also loosely mean making a phone from one carrier work on another carrier. The easy way to tell the difference is that if your phone does NOT take a SIM card, then it is probably CDMA.
To flash a phone to cricket you will be overwriting th phones firmware. The firmware is software in the phone that doesn't change when you turn it off, and it cannot be deleted unless it is overwritten, hence flashed. It requires specific files called prl files.PRL or PRL File--Short for Preferred Roaming List--A small text file containing instructions for how a phone connects to a specific network's radio towers It is usually loaded by connecting the phone to a computer to overwrite its data. There are a few tools used such as a pst PST--Short for Phone Service Tool or Tools--Special software used by phone manufacturers to program their phones. And also a monster file - -"Monster File"/"Monster Pack", ROM, or "Kitchen"--System software that is needed to flash a phone.
In almost all case you will need to access the phones service programming menu- - -Service Programming Menu--A special menu typically hidden from the primary User Interface that allows for "deep programming" of a phone.You will also need access to msl and spc codes specific to the device you are flashing.MSL/SPC--Special six-digit codes needed to access service programming features on the phone. Access to the service programming menu can be disabled in a phone's firmware.
Depending on your phone, it may require extra steps to unlock or get WAP and MMS working. That is why you need the msl/spc codes to allow deep programming to unlock these features. Not all phones will be capable to access wap or send and receive mms.
Ringtones generally have to be prepaid using a flex bucket. It is best to download ringtones before you flash your phone to cricket since they have a limited selection of ringtones and wallpapers.There are cases were flashed phones will not be able to download ringtones directly from cricket.
The details outlined above will not only work with cricket but you can also flash phones to metro pcs using the information provided above. It is best to do all your research before purchasing your phone to ensure that the cell phone you are interested in can be flashed to cricket or metro PCs
Feb 21, 2012 | Motorola SLVR Cell Phones
I want to unlock a cricket samsung sch-r560c so i can be able to use it wit metropcs?how can i do that
yes but your cricket samsung sch-r560c is not supposed to have a sim card for it because metro pcs does not have a sim card and if your samsung does not have a sim card yes u can unlock it to metro pcs
Feb 14, 2010 | Cell Phones
HOW TO ACTIVATE INTERNET SETTINGS IN HTC TOUCH PRO
You have to be more specific...HTC Touch Pro is available for sprint and Verizon...and can be flashed for metro pcs and cricket pcs..
for metro pcs, go here:
http://www.howardforums.com/showthread.php?t=1559514
Oct 16, 2009 | HTC Touch Cell Phone (Unlocked) - Soft...
HOW TO UNLOCK A SPRINT SANYO SCP-8400 AND flash TO metro pcs EXISTING ACCOUNT WITH METRO PCS PHONE #
it can be unlocked by calling your carrier and they will give you the infomation unlock code as long as the account is current and not delienquent if canceled it will cause some of the features not to work on the device
Jun 14, 2009 | Sanyo SCP-8400 Cellular Phone
Unlock pantech ocean for use with metro pcs
POWER CYCLE BY REMOVING THE BATTERY
Jan 07, 2009 | Computers & Internet
How to unlock helio ocean?
no..you cant unlock it at all..your just going to have to get a cricket or boost..OC phone have a locking on the web and pic java program to were fly genie is unaccessable..
Oct 14, 2008 | Helio Ocean Cellular Phone
Need an unlock code!
For $35 Metro PCS will now flash it to work with their service. They did my Sprint Razr phone.
Sep 08, 2008 | Kyocera Switchback KX21 Cellular Phone
Motorola Mobility SLVR L7 Cellular Phone Logo
166 people viewed this question
Top Motorola Mobility Cell Phones Experts
Rami Obeid
Level 1 Expert
D. E. Hev
Lawrence Oravetz
Are you a Motorola Mobility Cell Phone Expert? Answer questions, earn points and help others
