Question about Saeco 762111651808 Espresso Machine
Problems with Saeco 762111651808 Espresso Machine
I have followed the descaling instructions as described in the CD Rom that came with this product from Starbucks. However, even after going through the process twice (with descaler purchased from Starbucks) the read-out on the machine still says "Decalify". How do I make sure the machine is properly descaled and/or how do I get rid of the "decalcify" message?
    Sergeant:
  • Saeco Expert
  • 223 Answers
If the machine is digital you will go into the menu and reset the option that says signal descale. The machine does not know if you descaled it or not, you will have to tell it.
If it is not digital, hold the steam or descaler button(depends on model) down until the light goes off.
Hope this helps!
Posted on Oct 12, 2007
How do I decalicy the Starbucks Italia Digitial?
Use a coffee machine descaling liquid or powder. Follow directions on product. Add it to water container on machine and push the descaler button "bottom right" on machine. Follow directions on screen.
Jul 17, 2011 | Starbucks Saeco Italia Digital Barista...
Our saeco talea giro descaling light is on and after a full descaling cycle it remains in the descaling mode. any ideas? thanks
To remove a descaling light you need to hold down the steam/water button for 6 seconds and the light should go off. The button is located on the right side of the coffee button.
If you are in need of the manual you can download it here
May 10, 2011 | Saeco Talea Giro Espresso Machine
My Saeco Talea Giro plus is not even one month old and the descaling light was on. We have descaled twice thinking we did something wrong and the descaling light will not go off. During descaling the...
Did you often use the espresso machine for family or for business, when you often use the machine and you used water that is not filtered, you can assure it need to descale often.
Read carefully the manual and follow instruction. Did you descale it in the right amount of solution, how long and its duration?
If still persist ( the descaling light continue flashing ) then it has a defect in sensor. Since your machine is new, its under warranty. Call the dealer where you brought that and a service technician will send.
I hope I give you answer and solution idea for your unit problem.
Mar 29, 2011 | Saeco Talea Giro Espresso Machine
We've descaled and the light still appears on the saeco odeo giro
Have you done as described in the manual:
Press the hot water button for
6 seconds to deactivate the
descaling light.
Jul 18, 2009 | Saeco Odea-Giro Espresso Machine
How to clean the saeco aroma ??
Buy an espresso machine descaling agent (they come in packets, and you can get them all over the internet), and follow the instructions that come with it. Do NOT use vinegar like you might use on a drip machine.
Feb 09, 2009 | Saeco Aroma Espresso Machine
What Descale sign means
Start the descaling and follow the instruction the machine give you.
Best regards
/Mirran
Sep 06, 2008 | Saeco Talea Ring Plus Espresso Maker with...
Instructions for descaling Saeco Royal Digital
I used to run vinigar and water thru my coffee maker to remove the **** vinigar is slightly acidic. make sure run just straight water thru it afterward to get rid of the taste.
Robert
Sep 05, 2008 | Saeco Royal Digital Plus Coffee...
I want descalcificacian saeco easy sup 021ye what butons y press?
Warning! Never use vinegar as a descaling agent. You can use any commercially available non-toxic, non-harmful descaling product for coffee machines.
Descaling is necessary every 2 months; should water be very hard, descale the machine more frequently. The machine must be on; it automatically controls the distribution of the descaling solution.
  1. Switch off the machine.
  2. Fill the water tank with the descaling solution.
  3. Place a large receptacle beneath the steam tube.
  4. Switch on the machine.
  5. Open the knob.
    The descaling process starts.
  6. Dispense the descaling solution into the receptacle.
  7. After about 30 seconds close the knob.
  8. Switch off the machine and remove the receptacle.
  9. After 10 minutes, follow instructions 1 to 8 to the water tank is empty.
  10. Rinse out the tank and fill it with fresh drinking water.
  11. Place a large receptacle beneath the steam tube.
  12. Switch on the machine.
  13. Open the knob to rinse.
  14. If the receptacle fi lls, empty it.
  15. When no water is left, turn the knob to close the valve.
    Remove the container.
After descaling the machine, reload the machine circuit. Install the cartridge filter again in the water tank.
Jul 23, 2008 | Saeco Easy Espresso Machine
Saeco Magic 2nd light to the left (ON RED LIT)
Sound like descaling warning light, need to run descaling solution through the machine (follow instructions, you can download a manual on saeco's website) this light can be turned off by pressing and holding the steam button for 5 seconds.
Jan 21, 2008 | Saeco Magic De Luxe Espresso Machine
Saeco 762111651808 Espresso Machine Logo
115 people viewed this question
Top Saeco Coffee Makers & Espresso Machines Experts
just-ice
eyecam
Are you a Saeco Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
