Question about Whirlpool Dryers
Inside of dryer has turned blue from what i am thinking is my jeans. when i wasd whites they turn blue
    Genius:
  • 1,198 Answers
Wow, where were the jeans made? I'd definately take them back. If any of your other clothes were ruined, I'd take them along. To avoid bad publicity, the store just might replace all for your silence.
Posted on Apr 22, 2009
What is the best settings to wash jeans on.
While hand washing and line drying is safest, it's also costly in terms of time and effort. Unless your jeans are particularly dirty, it's best to wash them in cold water, select one of the gentler cycles, and dry them at a low temperature. Special detergents formulated to preserve dark colors really do work.
What temperature do you wash jeans? When to Use Warm Water - For man-made fibers, knits and jeans, use warm water (90°F). Most of your clothes can be washed in warm water. It offers good cleaning without significant fading or shrinking. When to Use Cold Water - For dark, bright colors that bleed or delicate fabrics, use cold water (80°F).
Wash your jeans in the sink or a tub.
  1. Fill a tub with a few inches of cold or lukewarm water. Mix in a gentle, color preserving detergent.
  2. Turn the jeans inside out, then lay flat in the tub. Don't bunch them or wrinkle them. Let them soak for about 45 minutes.
  3. Run them under the water to rinse. Hang up to dry.
  4. Can you put jeans in a tumble dryer?
    According to Good Housekeeping "All fabrics and especially jeans benefit when youtake them out of the dryer slightly damp. ... If, even after tumbling on low heat and a delicate cycle, you see lots of lint on the dryer's filter, you may want to switch to linedrying your jeans to help preserve the fabric.
    hope this helps you out.
Oct 28, 2017 | Washing Machines
Do u have anything that i can put in a dryer to clean the tub with its i put jeans in there to dry and now the inside of the dryer is blue and it causes the other things i put in there po dry it turns them...
Probably the only way to clean it that I know of is by hand and I would suggest using rubbing alcohol since it dries quickly. It will take time to do it but I have cleaned out parts of dryers that had similar problems and had no problems with the dryer after cleaning that way.
Dec 04, 2013 | Dryers
I have a front loader dryer and the inside is turning blue, causing my clothes to be tinted blue.
If you have washed some NEW blue denims, some of the dye will get on everything. Blue denims are often a pain, and if you wear them before washing them they will get that same blue dye all over you.
It didn't hurt your washer, just run a couple loads through and add a little bleach to the whites. Note that if you put bleach in with OTHER colors, they will fade.
The trick is, never wash ANYTHING with blue denims, especially when they're new.
Mar 05, 2011 | Whirlpool Duet 7.0 Cu. Ft. 7-Cycle Super...
PLEASE HELP! I HAVE A BRAND NEW WHIRLPOOL WASHER AND DRYER AND I LEFT A INK PEN IN MY SCRUB POCKET. I NOW HAVE INK ALL INSIDE MY DRYER. WHAT CAN I DO?
BUY SOME "GOOF OFF" FROM LOWES OR ANY HARDWARE STORE THE RUB AS MUCH OFF AS YOU CAN, THEN DRY 3 LOADS OF BLUE JEANS TO GET OFF ANY RESIDUE, THEN YOU SHOULD BE OK, YOU WILL STILL BLUE IN YOUR TUB BUT IT WONT COME OFF ON YOUR CLOTHES
Oct 26, 2009 | Whirlpool GEW9250P Electric Dryer
How do I remove ink stains from the inside of my dryer?
You can try to use nail polish remover or wd 40 .Then clean after done.Make sure it is cleaned really good after your done.If still on there it may be die from blue jeans or bounce then it will not come off
hope i helped:)
May 17, 2009 | Dryers
Inside of dryer is turning blue. How do I clean it? My clothes do not seem to be affected by this...my whites are staying white...but I can't figure out what to do about this.
My best guess, is it is your blue jeans. fingernail polish remover..non acetone usually does the job. Stay in a well ventillated area when doing this. Good luck.
Apr 20, 2009 | Maytag Atlantis MDG7400AW Gas Dryer
Inside of the dryer is turning blue - could it be the detergent?
its dye from blue jeans, all you can do is replace the drum or ignore it. real common for whirlpool products.
Nov 18, 2008 | Dryers
Dryers Logo
97 people viewed this question
Top Whirlpool Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Sal DeAngelo
Are you a Whirlpool Dryer Expert? Answer questions, earn points and help others
