Question about Dryers
I have a Speed Queen gas dryer AGM499W. It won't dry. The gas ignighter comes on but gas does not light.
  • sbenn37044 Apr 22, 2009
    I thank you for your advice but could you be more specific? Where exactly is this sensor located?
  • sbenn37044 Apr 23, 2009
    There are two small holes in the side of the combustion area opposite the igniter is that the sensor? If so I cleaned it off and even used the vacuum cleaner and still no flame. Any other suggestions?
    Genius:
  • Dryers Master
  • 1,198 Answers
There is a light sensor near the igniter. Clean off the dust on it's glass face. Don't bump the igniter, it's delicate.
Posted on Apr 22, 2009
  • mike kirschbaum
    mike kirschbaum Apr 23, 2009
    The sensor is mounted in the combustion area. It has a glass area aimed to where the fire happens. It will have a couple of wires leading to it. If it gets sooted or dusty, it can't see the igniter get red and won't turn on the gas. If the flame goes out, it will turn off the gas. Make sure the wires haven't come off at either end.
  • mike kirschbaum
    mike kirschbaum Apr 24, 2009
    I looked your model up at RepairClinic.com, my favorite site. They show your sensor as a rectangular device mounted to aluminum. This thing is not small. It will have wires going to it. There's not much else in that area besides the igniter and the flame device. Even after you find the sensor and clean it the dryer still may not work. That could be a gas valve problem. They are expensive, and I would have a technician do that part. He may get lucky and find another problem not so expensive. Some time you just gotta call in a pro.
Speed queen gas dryer, at least 20 yrs old: the igniter begins to glow, then fades out, there doesn't seem to be gas ignition as the chlothes are not drying...so?
Sounds like you may need some coils. Mine would heat up for a minute then go out. The coils were my problem. They are located close to the igniter. They come 2 in a pack and you have to replace both. Probably $20
Oct 07, 2017 | Speed Queen Dryers
My speed queen model AGM499W does not dry clothes cycles off and on after 10mins
Here is what I did. I went to the breaker box and reset the breaker for the dryer. Sometimes it will only pop 1/2 of the breaker, due to being too hot.
Hope this works
Nov 09, 2012 | Dryers
Ignighter workis and burner has flame but will not keep burnner lit. speed queen dryer. made by RAYTHEON
Hi, If you are having problems with your gas dryer not heatingthe most common problem is that the ignitor goes bad. Even though it glowssometimes it is still not working properly. if you dryer is gas check out this gas no heat tip.... If you have an electric dryer, you can have many differentthings that can go wrong causing the dryer not to heat. check outthis electric no heat tip...
heatman101;
Aug 06, 2011 | Dryers
I have a speedqueen gas dryer model AGM499w iGNITER LIGHTS BUT NO FLAME
heatman101';
May 24, 2011 | Speed Queen AGS28AWF Gas Dryer
Speed Queen gas dryer model #AGM499W. Replaced the igniter but did not fix the problem. Dryer will not heat.
burner may need to be vacuum out or blown out, also could be the thermo coupler. Hope this helps tim
Sep 02, 2010 | Speed Queen AGS28AWF Gas Dryer
Dryer does not heat. Electric ignition does not "spark" lighting
If you have a gas dryer2_bing.gif.
The most common problem with a gas and no heat is the ignitor going bad...
Here is a tip that I wrote about that problem...
Gas Dryer2_bing.gif not Working Gas Dryer Not Heating
http://www.fixya.com/support/r4398592-gas_dryer_not_working_gas_dryer_not
If your dryer is electric2_bing.gif..
There could be a number of different problems...
Check out this tip that I wrote about this problem...
Dryer Troubleshooting2_bing.gif Electric2_bing.gif Dryer won t Heat
http://www.fixya.com/support/r3866345-dryer_troubleshooting_electric_dryer_won
heatman101
May 04, 2010 | Speed Queen AGS28AWF Gas Dryer
Problem with speed queen 30EG. Dry ignitor turns on trying to turn on the burns but the dryer turns off in about 5 sec. If I turn off the gas valve the dry stays on.
Sounds like the thermistor. It is the whit plastic piece on the front of the motor - blower assembly with 2 wires going to it.
Aug 24, 2009 | Speed Queen CES68AWF Dryer
Speed queen gas dryer uses pay cards
overheating and shutting off,
usually is a blockage in the venting
check the exhaust lines to the wall vent/exits, there may be lint build up in those dryers that are shutting off
Aug 28, 2008 | Speed Queen CGS68AWF Gas Dryer
Dryers Logo
159 people viewed this question
Top Dryers Experts
