Question about HP Photosmart D7560 InkJet Printer
I displaced the encoder strip on an hp Photosmart
I displaced the encoder strip on an hp Photosmart D7560 printer. I'm looking for a picture of the internal parts so I can see where and how it goes back in. The part doesn't appear to be damaged.
Thanks to anyone who can provide a picture or describe how/where to reinstall.
  • sveach Apr 22, 2009
    I was incorrectly trying to clear a paper jam from the front of hp photosmart D7560 and caused the encoder strip to come out. It doesn't seem to be damaged at all. I want to put it back in but I'm not sure how to or where it goes. It has a small hole on each end so it obviously needs to hook on both the left and right sides of the printer.
    I was hoping to see a picture of the inside of the printer with the encoder strip in place but can't seem to find one. hp help desk was no help...
    Thanks!
  • Thomas F. Schneider May 11, 2010
    HP link  to your model
  • HP Master
  • 5,568 Answers
Typically, HPs have one fixed hook for the hole at the end and for the other end, a spring steel piece with a hook. Take a good look at the carriage; it will have a vertical slot, located toward the innermost part of it through which he strip needs to pass. Either take the strip (clean it gently while it's out), push it through the carriage while it is centered and look along its possible path for the hook arrangements. I don't know your particular printer but some of them require removal of the case to access those points. If you have a longish tweezer, you may be able to fish it into place (using a flashlight) anyhow. Be sure to fasten the spring-end first since the fixed end will not give and you risk tearing the mounting hole otherwise.
Posted on Apr 22, 2009
Ink system failure
Hi
Thanks for using FixYa. To resolvethe issue of display of error Oxc19a0036 you’ll need to reset the printer andto reset it please follow the step-by-step procedure on the link---
Howto Reset Photo Smart Printers
Please do rate the solution andrevert for further assistance.
Thanks
Rylee
Jan 21, 2010 | HP Photosmart D7560 InkJet Printer
I keep getting a mechanism error, stating that the cartridge cradle cannot move. When I lift the cover, the cradle moves just fine. How do I fix this?
Try cleaning the encoder strip with Sprayway Glass Cleaner, clean both sides till nothing comes off on paper towel. The encoder strip is the semi clear plastic strip that runs the width of the printer just behind the printhead cradle. You should be able to see through this strip but not like clear glass. This will also help with this printer if it is printing crooked images.
Jan 08, 2010 | HP Photosmart 8750 InkJet Printer
HP Photosmart 2610xi is printing but it does not keep the left margin aligned - it typically floats progressively to the right but sometimes wanders back and forth. Also about mid-way through each line...
You need to clean the encoder strip, that's the clear strip that runs behind the carriage assembly, you can clean it with a Q-tip damp with alcohol, the strip is fragile so don't press too hard. If you look with a flashlight you should see the area that needs cleaning.
Dec 31, 2009 | HP Photosmart 2610xi All-In-One InkJet...
Hp photosmart D7560 printer i'm haveing a problem with loading paper in very bottom load tray.the printer sceen says to load paper into tray or there is no paper in the tray. i"am using 8 1/2 x 11 inch...
Make sure the paper tray sensor flag has not been dislodged. Look up inside the tray area and also if the back door area opens up, check in there. The flag should move freely>
Dec 30, 2009 | HP Photosmart D7560 InkJet Printer
I have purchased the Photosmart D7560 printer. It indicates that the black (print) ink cartridge is empty shortly after installation. It also shows the color cartridges being utilized when the ''black ink...
take out the cartridges from the printer, then clean the contact points on the back of the cartridge with a clean piece oc cloth. unplug the power cable from the back of the printer and then press and hold down the color copy and cancel button at the same time. by pressing and holding them down plug back the power cable back into the printer.
the insert the cartridges one by one into the printer.
Nov 04, 2009 | HP Photosmart D7560 InkJet Printer
The power light just keeps on blinking. What does that mean? I can't get my printer to work.
this problem is due to the encoder strip which helps hp printer to find there home position. please change the encoder strip printer will work
Oct 08, 2009 | HP PhotoSmart C4480 All-in-One Printer ...
Hp c5280 strip encoder part #c9058-80029
Damampreet,
In all due respect, I have known a couple of people who have placed their encoder strips back on their printers and had no problems with it working again.
Jan 14, 2009 | HP Photosmart C5280 InkJet Printer
Plastic guide strip behind cartridge assembly broken
It can be bought from a service center, it's called "Encoder" or "Position Encoder".
To make sure it's the encoder, if you turn the printer ON it will say that the carriage is blocked or will flash the lights showing that problem.
Feb 06, 2008 | HP Photosmart 2710 All-In-One InkJet...
HP Photosmart D7560 InkJet Printer Logo
345 people viewed this question
Seeker5211
Seeker5211
